Coolant Issue...Suzuki HT51S
From what you have mentioned, I don't see any issues with the car. For now, fill up the radiator fully and adjust the coolant level of the expansion tank to be between min and max (almost touching Max). Drive as normal and keep an eye on the temperature gauge. The lower coolant level in the radiator is probably air that was bled out of the system after the repair.
If you have the original radiator lying around, compare the two caps and see if they are rated from the same pressure. The pressure rating should either be printed on the label on the cap or be engraved onto the metal of the cap. Does the car overheat?
Good DVD rental clubs to become a member of
My father used to rent from a shop in Liberty Plaza named NASTARS. This is from the VHS era through VCD and then DVD. They had pretty much any movie you could think of. But they don't anymore. I guess as online sources increased rapidly, they just gave up on video rentals. I believe a lot of other places did the same. As others have said, I wouldn't be bothered with video rentals. There are so many online services through which you can watch movies for cheap. Then there are the "free" methods as well.
Yes, this was my question. An aftermarket radiator cap with a low pressure rating might cause coolant overflow to the expansion sooner than it's required.
Do you have an aftermarket/different radiator cap?
LANCER EX ignition coil required
Yeah maybe. Most electronic parts in the engine bay are resistant to a little water, so a mist wouldn't do any harm. However, I just wouldn't take the risk. See in a hot and humid country like Sri Lanka, if the engine is warm and if a sudden mist of cold water settles on the engine, condensation can build up inside the components (say the engine fuse box for example, which is hollow, and even small sensors for that matter). This condensation can drip onto components and damage them. It's also important to know what's in the engine bay when you're pressure washing it. Like I said before, on the Lancer EX (basically all 10th generation Lancers), the main ECU is in the engine bay. And I personally am not comfortable with any water being close to it. Some engine bays are totally shielded with plastic covers and these could probably fair a lot well with a bit of water splash. This is all due to all the complex electronics on modern cars. I remember none of this mattered on my 1979 Lancer. After pressure washing the engine, if the car doesn't start, cleaning the distributor is all that was necessary.
That's just absurd! They should be knowing better being the agent. I got my CS3 serviced from them once after a repair and they didn't wash the engine bay. Although the plastic engine cover is covering the engine, there are so many other electronics outside the cover. The electronic throttle for example and on the EX, the ECU is also in the engine bay, next to the air intake. So high pressure washing is asking for trouble.
- LANCER EX ignition coil required
Vios power steering not enough
Old oil can be a reason for stiff steering when warm, because the oil loses it's viscous properties with age. However, before changing oil: 1. Are there any power steering oil leaks? Open the bonnet, remove the power steering fluid reservoir cap and start the car. Turn the steering from side to side while revving the engine and observer the fluid in the reservoir. If you see bubbles forming, it's likely that there's a leak. Of course check for visible leaks as well. 2. Check the tension of your drive belt. Specifically the belt that drives the power steering pump. If the belt is old or isn't tightened properly, it may not be driving the pump when warm as the belt expands when warm.
Toyota townace 1993 engine heat problem
Local Johnnies can make up all sorts of stories to snatch some money out of your pocket. I assume this is a CR27 DX? If yes, obviously the front AC alone can't cool the entire van if you have full seats installed (instead of just the one bench seat). I've driven and travelled in a few CR 27 vans (with and without Dual AC) and the front AC can feel insufficient to the back of the van on a warm day (more or less every day in Sri Lanka). First observe if the fan is pulling air through the condenser or pushing it through. If it's pulling (which I think it is), then you can't change anything. But if its pushing, you can look into the possibility of changing the fan. No there is no working temperature for the condenser. The cooler it can make the refrigerant, the better. Probably not a good idea, the metal shield with fins actually acts as a protector against rocks and stuff from hitting the condenser and causing a leak. It should be there. It just looks like it's installed backwards. If the fan is pushing air though, then it makes sense for the shield to be installed this way. I don't think you will find older types of refrigerant that easily. R134a is the new standard and it's in compliance with the CFC and environmental regulations. Older types of refrigerants have CFC and are harmful to the environment. Your van would have come with a CFC free refrigerant from the factory, given that it was manufactured in 1993. Again... my advise for you is to get the system properly re-done. Get the condenser installed the way it came from the factory. If you think cooling will be insufficient, then look into the option of doing a dual AC conversion.
Buying a new car
Please search the forum. The Yaris/Belta has been discussed so many times and in great detail. They're basically the same car. Yaris is the export model and Belta is the Japanese domestic model. https://www.google.com.au/search?client=ms-android-oneplus&ei=gzDyWorbNoqA8gWPib7wCQ&q=site%3Aautolanka.com+yaris+belta&oq=site%3Aautolanka.com+yaris+belta&gs_l=mobile-gws-wiz-serp.3...33872.34572..35065...0....396.749.3-2......0....1.........0i71.MvO3du6Asd8%3D
Tyre Prices
The factory spec is 81, so 82 is okay since it's on the high side. The tyre size is a bit of a rare one and this is the only one they had of this size. I had my father call the Dunlop agent and they've said that they can do Rs. 17,000 per tyre if we're buying 4. I'll probably get him to ask around a few other places as well.
CelerioX
Hi @Dhanu_Lena, Welcome to the forum! Please do not open multiple threads about the same topic. Also, you might want to search the forum to find out more information. The Celerio has been discussed (specifically about the transmission) before.
Tyre Prices
Thanks, I've sent them and email. Will see how it goes.
If I were you, i'd look into the possibility of getting it sorted out the correct way by installing the condenser and the radiator parallel to each other like it came out of the factory. Is the condenser a used one? Looks like it is because the ventilation fins are corroded and the paint is flaking off from the front. Also, I think they've installed the condenser the wrong way. The fins at the bottom should be pointing front of the vehicle to draw air through the condenser. And the condenser fan should be pulling air through it. Is that how the fan works? If the fan is pushing air (instead of pulling), then you can try reversing it so that the radiator gets enough air that's pushed out from the condenser fan. The other thing is, if you are using R134a refrigerant (which I'm sure you are) and if that condenser if a parallel flow condenser (tubes running in a zig-zag fashion from top to bottom), then installing it horizontally isn't recommended. This is because the lubricant that's in the system will eventually get deposited in the condenser (because refrigerant is lighter than the lubricant and will separate away) is and starve the compressor. If this happens, the compressor will fail prematurely. They're referring to getting your cooling system flushed and the radiator core cleaned. You can give it a try, but since the vehicle never overheated before the new condenser was installed, I don't think there's anything wrong with the radiator.
I agree brake fluid breaks down over time - especially in a country like Sri Lanka where it's hot and humid and where constant braking is required to drive around which heats up the system more. However, the amount of rust deposits (even on the "after" photo) is just a bit too surprising IMO. When I got my 2001 CS3 in 2008, the first owner had never done a brake fluid change and the reservoir was clean although the oil itself was a bit darkened. There is a lot more rust in that reservoir than I'd expect it to have even if the fluid wasn't changed at all. So I think either a brake cylinder had been leaking for quite some time without Sampath or the previous owner not knowing about it, and the leak would have caused moisture (or even water) to enter into the brake lines and corrode them. Quite plausible because our service stations remove brake drums and use high pressure washers to rinse the brakes.
I'm surprised how dirty that old brake fluid is for a car of this age. Looks like water/condensation was in the brake system at some point. Were there any brake oil leaks in the wheel cylinders at any point?
- Help With My New Cs3
Nissan 180sx
Not according to my knowledge. Probably only a handful in Sri Lanka, so pretty rare for one of them to come up for sale. This guy however, thinks he's selling a 180SX. http://www.autolanka.com/view/nissan/180sx/32649.html
This is exactly what I think it is. The airflow of the AC condenser fan is probably restricting airflow through the radiator core. Before you had the AC condenser in front of the radiator, it would have been easier for the radiator fan to draw air from the front of the vehicle. Now, when the AC is on, the fan on top the AC condenser is probably sucking in all the air and creating a sort of void between the condenser and the radiator. As a result, the radiator fan has no fresh air to pull through the radiator. I think you should think about placing the AC condenser parallel to the radiator. It looks like there is sufficient space in front of the radiator (given that the factory condenser would have been there). This way, the AC would also work more efficiently, because it doesn't have to rely on the fan to cool the condenser. The outside airflow would help as well.
Tyre Prices
Hi Guys, I'm about to get a new set of tyres for the Demio my father drives. It's currently running a set of Dunlop 185/55 R 15 82H SPTRGT1 (Indonesia) purchased in late 2015 from the Dunlop agent (S K Munas!nghe) for Rs 13,800 a piece. The tyres have been pretty good and have worn out well, so I thought of going for the same set again. A quick browse on their website now shows the same tyre at 20,000 LKR. So my question is, have prices really gone up by that much for the past couple of years? Sorry, I'm not really following these things as I'm out of the country. Bridgestone agent (Aut0dr0me) website also shows similar prices (23,690) for the same sized tyre (EP300 Thailand). Thanks!
- Nissan 180sx
- Trunk Central Lock Not Working
Nissan FB 14 Car Shutting down issue while driving
I still don't understand why a proper diagnostic scan can't be done so that the actual error can be discovered and addressed.
The All New Mazda 2 (2016/sedan)
Is this an issue specific to Sri Lankan driving conditions? It kind of makes sense considering how bad our traffic is with constant braking and accelerating all the time. Also disappointing that this is how people are forced to drive.
