DIY Climate Control Troubleshooting.
Spray some WD40 and leave it for a couple of hours and try. Or be REALLY careful and put a drop of brake fluid into the thread if you haven't got WD40. When you're pulling the arm out, make sure you life the wiper off the windshield and then pull it out perpendicular to the spline. Pulling it at an angle might cause the arm to get stuck.
- Toyota aqua
- Engine Stop in the Traffic
- Plastic Upholstery Repair
Retractable mirror issue
For OP's question, it should be a worn out or broken plastic gear inside the mechanism. Only dismantling the mirror will tell as Rumesh88 said. My father's Demio had the exact issue and it was due to a broken gear. Motor kept running continuously. There's a chance it can be repaired. Try the mirror shops around Delkanda. My father got the entire mechanism swapped with a recon one from Delkanda.
toyota hiace
Welcome to the forum. This has been discussed before. Search the forum and you'll be able to find detailed information. Our resident KDH expert @Magnum should be able to point you to the correct threads and answer any new questions.
How's the cold start - does the car rev a bit over 1000 RPM and slowly come back to a stable 750 RPM when warm? Do you see any RPM fluctuations when the car is idling or when the AC kicks in or when you step on the brake pedal? If cold starts are not normal and you see RPM fluctuations, it's probably due to a sticky idle control valve or a vacuum leak. When was the most recent tune-up done?
- Thermostat replacement
The system is filled with coolant, so the moment you remove the thermostat housing or the hose that connects to it, there'll be coolant spilling everywhere in the engine bay which will lead to a big mess. To avoid this, use the radiator drain plug and drain some of the coolant until the thermostat area is free of coolant. You wouldn't have to drain much because the thermostat sits right at the top of the loop.
Formula 1 - 2017
Missed posting a few updates on this thread, but last weekend's race was something spectacular to watch. Ricardo takes the win while Hamilton and Vettel go through a bit of an incident. Many exciting moments and a great race overall!
Fiat Punto
Search the forum. The Punto has been discussed in quite detail here.
AC sometimes doesn't switch on
Sounds to me like an electrical issue. It could be due to a loose connection or a faulty relay. When you get the issue, open up the fuse box (engine compartment) and locate the AC relay. Give it a couple of taps to see it that causes the AC to work. If it does, the relay is faulty. You may also try switching it with another relay in the fuse box temporarily to check if it's actually the relay at fault. Make sure you use the same kind of relay. If this isn't successful, take the car to a good auto electrician and get the system checked out for lose connections or faults.
Honda Front Bumper Parts
Try amayama.com, parsouq.com or eBay.
Autolanka Rc Build Thread
Top left photo is all the parts that went into the build: - Adjustable front and rear upper arms - Front and rear lower arms - Main prop shaft and prop shaft joints - Front and rear knuckles - Drive shafts and related components - Steering bridge - Adjustable steering tie rods Top middle and right photo: Deconstruction, and cleaning up dust, dirt and grime. A good blast of WD-40 and a wipe did the trick. Bottom left photo: All stock components removed from the car. Bottom middle photo: Installation of the prop shaft and joints Bottom right photo: Completed rear end More close-ups of the parts: And the finished product: It took me close to 4 hours to strip the car completely and install everything. Spent a couple of hours on top of that performing wheel alignment (now that upper arms and steering are adjustable). Following the specs in the installation instructions caused the car to be lowered. Since this is a rally spec chassis, I had to make sure I didn't deviate too much from the original height. The following photo with all parts installed according to the upgrade part specs. This is a bit too low for my liking. Would be ideal for a drift car though. The specs even gave the wheels a lot of negative camber and toe-in which I later corrected. After hours of adjusting, this is what I ended up with. Outward appearance is still the same: Hoping to take it for a spin this weekend! One thing yet to do is upgrade the bushings and bearings, I noticed that the stock plastic bushes had a bit of wear in them and thought of upgrading them to a ball bearing kit. The steering bridge kit already came with ball bearings (and is now so smooth - even the turning radius is shorter now), so the only bearings I need to upgrade are the 8 bearings on the drive line. Upgrade #1 for the future. The kit also came with 5.5 mm hex nuts for the wheels, but once they were installed, the wheels didn't sit flush with the wheel well, so I decided to go back to stock ones. Will probably go for a set of 7 mm ones later. This is upgrade #2. Also coming up is another build! During my recent visit home, I pulled out some old boxes of mine that were in storage at home and found my good old Ford F-150 truck! From memory, I got this truck when I was 12 years old or so. The circuit is fried and I couldn't source a battery for it, so I had to stop playing with it. After being kept in storage for over 2 decades, the tyres have become so hard, I had to use a hacksaw to cut them out of the rims. This truck has a two speed transmission. Hoping to bring it back to it's former glory. Will share updates when I begin the restoration.
Bumping up this thread again to share some updates! It’s been exactly a year since I got my Tamiya TT-02, and I’ve been loving it! I’ve mainly been driving it around on empty car parks, roads and my most favourite – a basement car park that has a polished concrete floor which allows you to do a lot of drifting! I have used it for about a hour every fortnight or so, have crashed it several times and have had to clean the mud, dust and debris on occasion. It’s been running quite well for an all-plastic entry level RC car. From the start, I always wanted to upgrade it as I may have mentioned in my previous posts and I finally got the chance to do it. The stock shocks were basically two plastic rods put together and a very stiff spring. This was not the best and contributed towards a very bumpy car and vague steering. I wanted to upgrade them first. So I got hold of a set of aluminium oil-filled dampers by Yeah Racing. I matched the length of the dampers to the stock ones to make sure I have the same level of control over ride height. The top right box (on the second photo) has all the parts required to assemble one shock. They’re to be assembled, oil filled, air bled out and installed. Took me about 3 hours to assemble everything, mainly because the shocks were to be left upright for air bubbles to float to the top of the oil and then removed. Once they were installed on the car, handling was improved dramatically. I just couldn’t believe how well the car hug the ground compared to how bad it bumped around before. The video below which I recorded shows how well the dampers absorb the shock. With the stock ones, the car bounces multiple times before settling down. I also got a stack of other parts that I got down from rcMart and a few sourced locally. Stuck to one brand – Yeah Racing because I was so pleased with the dampers. Stay tuned!
Failure In Emission Test
Answer to your last question: "If the owner of the vehicle confirms that the engine of a vehicle has been repaired, a receipt is issued by charging the annual revenue licence fee so that the vehicle could be run on the condition of completing 2000 kilometres forward from the number of kilometrers depicted on the milometer of the vehicle or 02 months forward from the date of repair of the engine, whichever comes first. Once that condition has been met the owner of the vehicle should obtain the revenue licence by producing the vehicle emission certificate." Source: http://www.motortraffic.gov.lk/web/index.php?option=com_content&view=article&id=123&Itemid=149&lang=en I doubt a faulty injector and the fact that you drive short runs are proper excuses to be exempted from doing an emissions test. Shot journey or not, your car is still not suitable to be driven with a faulty injector.
Kenwood Car Audio - Bluetooth Set Up
What's the model number of the unit?
Toyota Vios(e) Fuel Consumption....
If you live close to Battaramulla, try ASNU Lanka. Search the forum for more information.
Welcome to the forum and congratulations on the car. Get a tune up done (throttle body clean up, injector clean, spark plug clean or replacement, diagnostic scan), especially if you're unaware of when the last tune up was done. When you say you pumped a full tank, did you follow the full tank to full tank method to calculate consumption? Also, what type of petrol?
- Help With My New Cs3
Is there a person who rode panda tiptronic?
I'm not sure about the Panda, but automated manual transmissions usually come with hill start assist. This works with the aid of a slope sensor that detects if the car is sitting on an incline. If the sensor is functioning properly (assuming that the Panda has one), then the car should stay stationary for a couple of seconds between the time you take your foot off the brake and step on the accelerator.
[Q] JDM Starlet, uncommon gauge cluster.
Yep, aware of that. I should have probably worded that differently. If he had a car with these sort of options, he wouldn't call it (excuse my language here) "The shitbucket".
http://www.jp-carparts.com/toyota/partlist.php?maker=toyota&type=121140&cartype=4&fig=8301 EP82-AGHNU? And I think I found @terrabytetango's exact EP82: http://car-pricenet.com/cars/view/3437 Mods, please remove the second link if inappropriate.
