June 17, 20179 yr I'm having a panda AMT car and I'm new to AMT. I have experienced a bad feeling while traveling in a hill road auto or manual mode. It was easy to manage a manual vehicle but this one does not contain a clutch lever. Situation is like this, 3 passengers in car, in a hill road, in the mid of it one passenger got off. behind me there was a 3wheel. I have to go top to finish trip. I chose accelerator vehicle came down 3 or more feets. I used breaks again and tried with hand breaks. Hand breaks cannot stay against that load and slope and it also came down so I alerted the 3wheel to pass me and I went to begining of road and started in M mode 1st gear. Is there more than that to do for me like that kind of scenario. Please advice. Thanks.
June 17, 20179 yr Never driven an AMT but Left foot on brake + accelerate using right foot --> let go of the left foot should work right?
June 17, 20179 yr Author Tried once it doesn't work for me. And its another class because have manual and amt to drive. Thanks anyway.
June 17, 20179 yr I think the 1 liter panda is underpowered on hills. With an Auto it must be worst. I once rode a Nano to Dedugala hills (Bulathkohupitiya area), u had to push the car to get going if u stopped the car midway in a hill!
June 18, 20179 yr I'm not sure about the Panda, but automated manual transmissions usually comeย with hill start assist. This works with the aid of a slope sensor that detects if the car is sitting on an incline.ย If the sensor is functioning properly (assuming that the Panda has one), then the car should stay stationary for a couple of secondsย between the time you take your foot off the brake and step on the accelerator.
June 18, 20179 yr Author I checked with A*W person he told me that celerio also has the same. And I contacted a celerio guy while on the way, he told his one also same. I think that sensor not available here as this is an economy one not sure about that. I think this was happened due to I'm not totally familiar with this car yet. Will see.
June 18, 20179 yr 9 hours ago, Davy said: I'm not sure about the Panda, but automated manual transmissions usually comeย with hill start assist. This works with the aid of a slope sensor that detects if the car is sitting on an incline.ย If the sensor is functioning properly (assuming that the Panda has one), then the car should stay stationary for a couple of secondsย between the time you take your foot off the brake and step on the accelerator. Budget AMTs available here such as ones in Celerio, Alto K10 definitely doesn't have such. Not sure about Panda though.
