Buying an Axio x Limited 2007 vs Lancer ex GLS 2008
Welcome to the forum @Metta. Did you search the forum before opening this thread? We have a thread identical to this and the two cars have been discussed and compared extensively already. By the way, please don't create duplicate threads. You have created two other threads with the exact title and content.
Dash board repair
DIY solution for the vents if you are up for it: Not sure what's wrong with the storage compartment, but if the latch is broken, it might just be easier to replace the whole thing. Finding spares will be a bit of a challenge though.
Nissan SB 13 Cam Cut
Also, it looks like the "cut" you're referring to inside the red circle is actually a bad photo editing job.
Noise from rear when breaking
Sorry to hear that. There's a good chance the drum shattered due to a very small crack that gave way as the resurfacing bit was cutting into the drum. This explains your noise as well although a crack in the drum is felt through the brake pedal more than it is heard. Anyway, you should search the Viva Elite Community thread as well. There are specific shops that bring down Perodua spares that you can try.
Guys Please Help Me .
You realise this question is 10 years old right? I highly doubt he is still waiting at office for a mobile battery service.
Nissan FB15 Battery and Pickup issue
The battery indicator on the dashboard is not a "low battery" indicator but a "charging system issue" indicator. This is a common misinterpretation. Anyway, did the indicator go off after the car started? If not, just replacing the battery will not solve your issue. If the battery completely drained because you left your parking lights, interior light or simply because the car was not used for months, there is a slight change that the ECU (engine and/or transmission) was reset, causing the car to behave a little differently until the ECU re-learns. Highly unlikely because only a very small current is required for the ECU to maintain the values. The battery has to be be producing almost no current at all for this to happen. So I think first replace the battery and get your charging system checked if the indicator is still on. Allow for the ECU to lean by driving a few kilometres. This should tell you if the issue is due to an ECU reset.
Good mechanical workshop
Welcome! Please search the forum. This is the thread to ask/discuss mechanics and workshops. As for your problem with the oil leak, any competent mechanic should be able to fix it. It's just the replacement of an oil seal and making sure your ignition timing is properly set after the repair.
Sri Lankan Traffic Violations
4 to 5 seconds might not be sufficient for the GPS to catch up. The final speed is determined by calculating several speed readings (based on distance and time), and averaging them out. And most GPS systems "ping" satellites only a couple of times every second. So try maintaining a constant speed for about half a minute. If your car has cruise control, use it. My opinion is that speed calculated by GPS systems are far more accurate than vehicle speedometers. Wheel size, tyre wear, gear ratios and even meter calibration can lead to vehicle speedometers being not-so-accurate.
Not really. It just takes a bit of time to catch up (communication delay) like asrock said. You'll notice that if your speed is constant, the GPS speed and the actual speed are more or less the same. You'll be surprised to know that even car speedometers are also about -5 km/h less than the actual speed.
The first time I came back to Sri Lanka, I made it a point to bring a dash cam for my father's car. After seeing videos in that Facebook group, and numerous incidents faced by me and my immediate family members, it only made sense to have one because there are so many morons out there. Believe it or not, it only took 2 weeks after my departure for my father to realise the value of the dash cam. The right hand side mirror was knocked off by a moron overtaking on the oncoming side, and the guy fled the scene. My father had to produce this footage to claim the insurance and get a new mirror assembly. The insurance company (SLIC) didn't make a fuss at all given that we had video evidence. So yeah, get a dash cam. Two if you can afford it (front and rear kit). Get one with GPS so that you can have it detect and print the vehicle speed on the video. Might come in handy if you are accused of speeding when you were doing less than the limit. Might save you from having to pay a 25,000 fine. https://dashboardcamerareviews.com/
Honda fit gp1 2010
It's actually site:forum.autolanka.com gp1
Ceylon Motor Show 2017
Had the exact thoughts as I was reading the question. You can't really put a price tag on something that's one of a kind, so I agree priceless is the right word. Even if importing of classics is allowed some day, I don't think any of them would be as unique, due to the history and authenticity of the registration of this Mustang. Also, every time I see this car and the Camaro, they look better than they did the last time.
Engine gives a gurgling sound
So is it correct to assume that the "gurgling sound" was in fact pre-ignition?
Engine Swap - Volvo S40 Turbo Diesel YOM-2000 (Project Volley - Volley the Naughty Forty)
Good stuff Sampath! Glad to see her get a new lease of life with the right parts. More happy that you didn't go down the path of using an engine from a Japanese car. Since you have invested in an original engine for the car with the greatest difficulty, why not use a new timing belt as kush has said above? At least get it thoroughly checked before installation. I personally would get it replaced for peace of mind. The pulleys on the old engine would have caused the belt to wear out in a certain way, so the belt might not sit perfectly on the pulleys. Highly unlikely, but just pointing it out the possibility. Also, this once again shows how amazing our community is. We have great members on the forum who would go the extra mile for others. I myself now personally know many members on the forum because we have helped each other out in good and difficult times. Kudos @The Don. Wish you were more active here. Good luck with the project Sampath! Keep this thread posted.
The Mazda Demio Thread
Congratulations! Good car the SX4. Was Suzuki's Rally car for some time too. To keep things organised, I think it would be better if you can share photos in one of the SX4 threads. Maybe this one. Once you've shared, just drop a link here to that post.
- The Mazda Demio Thread
You can tell if it's a CVT or not based on how the RPM moves with the speed of the car. It behaves differently to a conventional auto. The needle rises and stays in one point while the speed of the car keeps increasing. Did you take it for a test drive? If it's a guy trying to make a profit out of the car by doing a "sale paint" job, I doubt he even knows if the car is actually a CVT or not. As for minor things like remote not working, door lock not working, those things can be easily repaired. It's a 10 year old car after all. Plus, you can bargain and get the seller to lower the price even further. When I got mine, the antenna was broken (got a genuine one from eBay), the driver's side mirror was not auto folding (got it repaired for 500) and there were a few scratches on the front bumper. Don't let small things like that stop you from buying a good car. Not saying ignore everything, and go for it, but you really must learn to draw the line appropriately by weighing the positives and negatives. Anyway, you saw it personally, so I'm just going to give you the benefit of the doubt. If it's as bad as you say it is, then well... poor Demio. Being a fully loaded one too.
Toyota Vitz 1000cc Vibration issue
People have the tendency to replace engine mounts using aftermarket ones which may not be as durable as genuine ones. Especially for a gel mount which is bound to be expensive at the agent and other genuine part dealers. I wonder if this is the reason for the vibration to recur so soon.
That's a fully loaded Demio and I bet it has CVT as well. It'll be gone soon because the price seems to be quite okay too. It has the optional spoiler as well. I'll not comment on the colour because that's actually a personal preference. I personally wouldn't mind it.
Duplicate Certificate Of Registration
This is a six year old topic mate. Please be mindful when responding to old topics.
Toyota carina idle rpm issue
If they disconnected the battery before the tune up, it could be that the ECU was reset and is still learning. How many Kms have you used the car since the tune up? Usually the system learns within about 20 Km depending on how the car was driven. So if it's only been a few Kms, put a few more and see if it solves the issue. If not, it's probably due to the idle air control valve sticking. Some mechanics have a habit of spraying throttle body cleaner directly on IACVs and some units go bad as a result. You just need to properly clean the IACV using a clean rag dampened with TB cleaner and making sure the motor operates normally without sticking. I wouldn't assume it's the ECU without even checking the above and performing many other tests to eliminate other causes.
2-year brake fluid change
During a brake fluid flush, the new brake fluid is added, and the system is bled until the old fluid is flushed out of the system together with a bit of new fluid as well. So you don't have to worry about them mixing. Besides, DOT3 and DOT4 can be safely mixed and I'm sure it doesn't cause any damage to the system.
Get your engine mounts inspected.
I wonder if OP is referring to pre ignition sound as "gurgling sound". While in complete agreement with all responses above which seem to have lead to the discovery of a possible head gasket leak, OP might be referring to pre ignition because the sound is heard when shifting gears at a "lower RPM". So, in addition to the questions asked by @Rumesh88 above, I have the following. This is just to eliminate the possibility of pre ignition being described as "gurgling sound". 1. Does this mean you can control the sound being heard if you shift at a higher RPM than normal? 2. Can you replicate the sound when the car is stationary and when in neutral while the engine has reached operating temperature? If it's actually related to a gasket leak, I assume it should still be heard whereas pre-ignition sound is mostly heard under load.
Clutch Kit Replacements !!! Help ....
Was a brake or clutch repair done recently? Does your car accelerate normally when the engine is cold? You can search the forum/internet to find methods of checking for a possible worn out clutch, yourself, without taking apart anything. Example. If the above test doesn't reveal anything, I think you first need to bleed the system out to see if the problem was due to air trapped in the system, causing the clutch to slip. When this happened, did it feel like the car struggled to accelerate?
