Davy
Top Contributors
  1. Hi Rohan, Thanks for sharing your experience and thoughts. Agree with you on the points I've made bold above in your post. I have seen many local paint shops use sophisticated paintless dent repair equipment, but the personnel who handle the equipment are regular tinkerers or painters. This obviously leads to the job not being perfect. As you said, this is definitely a different avenue of body repairing and proper training and experience is a must to handle real life scenarios. With this thread being nearly three years old, I hope the situation has changed and I hope members who are aware of places that carry out professional paintless dent repair, will share information about them.
  2. This how the electrics went in: Servo installed: The receiver is pasted on the servo with some double sided tape. The ESC was pasted onto the chassis with double sided tape. All wires connected and tied: I got to painting the spoiler again as well. Three coats of metallic blue followed by two coats of clear. I'm going to install it on the car like this and give it a good cut & polish a couple of weeks later. Painted the battery bracket and the front bumper with the same blue as well. Just because.
  3. HI MADZ, The issue seems to be in one of the forum plug-ins used for spell checking. It appears you guys are using Grammerly to do spell checking, but the CSS associated with the buttons don't seem to be working properly. Please see the screenshot below. There are random numbers appearing on the right pane of the page (particularly on this thread). This is what The Stig highlighted before with a mobile screenshot. The number appears to be associated with the number of grammatical errors in quoted posts. Removing the inline style highlighted in blue above brings the text back into the middle pane (I believe that's where the text should be) which should fix the blank space issue in mobile. Hope this helps.
  4. Davy replied to Le Sabre's topic in NISSAN
    Can't you just Google for a good photo, print it and frame it? Basically the same thing.
  5. I can confirm that I'm having the same issue as The Stig. Although the issue isn't there on every page, it definitely is there when viewing this thread - if that makes it easier for you guys to reproduce it. Device is a OnePlus One with Chrome running Android 6.0.1.
  6. Hey MADZ, Check this post for example, still broken links to attachments. Not sure if this is because this particular post was made on the 29th of June which was close to when you guys carried out the upgrade.
  7. Not an expert since I have not owned any of these cars, but I've driven some. So here's my two cents about them: - The Evo VII GT-A is automatic. Pretty sure you will miss that third pedal. If you can go for a Evo VII GSR instead, then yes. - The 1998 Evo VI GSR and 2001 Subaru STi have pretty much the same power and the cars weigh almost the same. If you can find an example in good condition, then either car will be fun to drive. Depending on where you are located, you might be able to find one of those rare Tommi Makinen editions of the Evo VI and they're awesome! - The BMW E46 is the slowest of them all, so I'd look at the other options unless you're referring to an M3 No experience with the other cars, so I'm not going to comment on them.
  8. Davy replied to SANCAR's topic in Mechanical problems
    That's correct. I think OP was expecting pulling power to increase as a result of the distributor oil leak being fixed.
  9. Davy replied to SANCAR's topic in Mechanical problems
    The oil leak near your distributor is probably due to the distributor o-ring being bad. Replacing that will solve the leak, but I doubt it will improve pulling power. By the way, what's the mileage of the car? As part of your tune-up, were the injectors cleaned as well?
  10. The reason why you couldn't see your BitTorrent running when you scheduled it through Task Scheduler is because you checked "Run whether user is logged in or not". When this is checked, tasks are run only in hidden mode. If you opened up Task Manager, you could have seen your BitTorrent app running at the specified time. But yeah, using Windows Task Scheduler when there's already a scheduler in the torrent app is a bit overkill. What I usually do is start uTorrent and select "Shut down when downloads are compete".
  11. Your notification settings might be messed up. http://forum.autolanka.com/notifications/options/
  12. While the forum was offline, I actually finished my build! So after the paint job, the next part was to stick the decals and stuff on the body shell. This took the longest of all. A good pair of scissors and a knife is essential for this part. Some stickers needed to be positioned perfectly, so I used tabs of masking tape to position them first and then peeled off the back of the sticker from underneath. Made it much easier to paste them. For smaller decals, I stuck them onto the craft knife and positioned them on the body: Halfway there... Note how different the colour of the spoiler is in the above photo. I will paint this again. And we're done! I didn't paste all decals to be honest. There were some that I left out because I didn't want to covert the whole car with stickers. I might change my mind later. Here's the actual car for comparison: Will share photos of how the electrics went in next.
  13. Awesome stuff MADZ! This is great! Looks like we had quite an old version of IPS forum. I had trouble logging in because my display name (Davy) was not what I have been using so far to login (I may have requested my display name to be changed in the past). And this new version did not let me in when I used my old user name. I just tried "Davy" as the user name and it worked. If there are users who used a different user name from their display name on the forum, they'll probably have the same issue as me I think. Also, I think previous user attachment images are gone from the Profile > My Attachments. Some users still use this and I saw a few broken links while browsing. But wow, the attachment quota now is nearly 1 gb! Earlier it was just a few megabytes. Anyway, the first thing I checked was whether the search function is better than the old version and guess what? It is! At least now we can hope members will search before posting new topics. Great work again to MADZ and the AL team!
  14. While paying close attention to the advice by others, I think you should get your clutch checked out as well. Although your car has a cable operated clutch, "hot spots" on the pressure plate and flywheel can cause clutch slippage when the engine and transmission is hot. I was once faced with a situation where a leaky crankshaft oil seal caused oil to come into contact with the clutch plate and cause slippage. What was done as part of the clutch inspection? Was your gearbox taken down to inspect the clutch? You can do a simple check to determine if your clutch is actually slipping. When the issue pops up, - Bring the car to a complete stop - With the engine still running, press the clutch and shift into third gear - Try to take off as you would do if the car was on first gear If the car stalls, then your clutch is probably OK. If the RPM increases and the car starts to move, then you have a slipping clutch. I suggest this because you say that you have control of the vibration when you ease up on the clutch.
  15. The paint job went pretty well. After masking the windows, I sprayed three even coats of blue. A light coat at first, followed by a bit thicker coat and then the final one being pretty thick. First coat... And the final coat The spoiler. Since I used the same colour that was used for the body (ignoring the manual's instructions that said, "use a different colour"), the spoiler appeared to be different from the rest of the body. I might have to spray it with a few coats of clear to get the same shine as the body. Rear view mirror painted in semi-gloss black Unmasked the windows and painted them in the smokey black colour. Looks like all windows are tinted now. Next was the biggest surprise. I removed the polythene on the outside after the paint dried up and dang!! look at that shine! A few more shots with the painted body mounted on the chassis Really happy with how the paint job turned out...
  16. Posting this again since all posts made after June 30th are gone after the recent forum upgrade attempt. So I thought of moving on to bodywork since I wanted to get the body painted during the weekend. I marked the body using a permanent marker and then used a pair of scissors and the crafting knife to cut the excess plastic out. Cutting along the wheel arches was the most difficult. After that I installed the body mounting posts onto the chassis and positioned the body to where it would sit. Although this is a rally car, I didn't want it sitting higher than normal, so I settled for a 5mm gap between the wheel arch and the tyre. This way the front wheels were able to turn left and right without touching the body even under full suspension travel. I washed the body with soap and water as instructed in the manual and then masked the windows. I also got the charger and a battery. Having heard of horror stories of batteries catching fire and exploding, I decided to buy a good charger. Went for a SkyRC B6AC + V2. Capable of charging/discharging NiMH, LiPo, NiCd and even balancing LiPos. The battery is a VENOM 5000mAh 7.2V NiMH. The charger came with all sorts of adapter cables for different makes of RCs. The charger even has a micro USB port to connect to the PC and monitor stats on a PC app. The battery also came with different adapters, so I can use this battery on almost any car that supports 7.2V NiMH. Running a series of charge > discharge cycles on the battery.
  17. Thanks mate. The springs on the stock shocks are really stiff, so I'll definitely be switching to a good set of shocks. And yes, the plastic bushes need to go. I also noticed that the drive shafts have a bit of horizontal free play near the wheels which I don't like because it can cause the wheels to wobble. There are aftermarket upgrade kits which cost more. Like this one by Yeah Racing. Still thinking which way to go. This one here costs more than the car itself.
  18. The servo, receiver and the ESC go on the side of the motor. So the space on the other side of the prop shaft is totally for the battery.
  19. I also got the Finespec 2.4GHz Transmitter system. This kit has an ECS too. So I've now got a spare TBLE-02S ESC. The ESC that came with the car is set to brushed mode off the factory, and the one that came with the transmitter is in brushless mode. The setting (amongst other settings) can be modified. The transmitter in the box (ESC and servo in the bubble wrapped bags). The Tamiya TRU-08 receiver: The Tamiya TSU-03 steering servo. I have installed the arm that came with the car onto the server here. Electrics will go into the car next. I've got to buy a battery for the car and a charger. Thinking of getting a 5000mAh NiMH battery with a good charger that allows balancing of LiPo batteries as well.
  20. Shocks assembled. Each strut came in 5 separate parts. Assembling the drive shafts... And we have something that looks like a complete chassis...
  21. Rumesh is right. Your car has a manual choke, so it wouldn't be trying to automatically operate like the IACV on modern cars do. When you accelerate from a standstill on first gear, does the car still vibrate if you release the clutch slowly compared to normal?
  22. I started the build! The link below is to the instruction manual I’m following. Gives a clear picture about each step of the build since I couldn’t capture each step. Assembly manual + body specific manual (8mb PDF) The first step is to assemble the spur gear at the back of the car and then the propeller shaft. Lube the plastic bearings with grease and then put ‘em together. Note that the prop shaft is plastic too – something that I didn’t like because there’s actually a bit of flex to it. Then came the differentials – both front and rear. Filled the diff housing with a liberal amount of grease. The kit came with two types of grease. Regular grease for bearings and the diff and Anti-Wear grease for suspension links and even between the prop shaft and the spur gear. Next – the motor. The motor itself came with a 19T spur gear, but the kit had a 17T one. The instructions for the car said use the 19T one, so that was what went in. Here’s the motor installed. Suspension arms were next. And after a couple of hours, this is what I ended up with. Done for the day
  23. Very neat! Well done!
  24. That is sick terra! Very nice! Was so tempted to go for a Traxxas Stampede 4x4 VXL, but even the 1/10 scale ones are so expensive! Is that graphic on the body a sticker or a very complex paint job involving three colours? Shhhhh! People will hear! But yeah, couldn't help it. Just glad I didn't buy one of everything from the "tools" section of the hobby shop.
  25. The photo I've shared is of the ESC, but yeah, the receiver is pretty much the same size as well. The receiver circuit in my Ford F-150 is also pretty huge. I guess that's the difference between the 90s and today. Would love to see your 911 Targa. Please share some photos in this thread if possible.
