Need to try twice to ignite the engine when the engine is cool.
Sounds like a fuel pressure problem like others have mentioned. Do the following test just before a cold start to confirm: 1. Turn the ignition to the ON position (don't start) 2. Leave it on for 30 seconds 3. Start the car If it starts first time, then it's definitely a fuel pressure issue.
Lancer Ck2
Hi @Dasun Sanjaya, welcome to the forum. Please refrain from posting the same topic across multiple sections of the forum. The CK Lancer has been extensively discussed, so you might want to search the forum as well. Click here for search results. Threads merged.
- ## Post Whoring - Part 3 ##
- [Mitsubishi] [Lancer] [Cs3] Timing Belt Change
- Quick Trivia 3
Lancer EX Running Repairs and Maintenance
Oh I see. I don't remember seeing this in the workshop manual. Good to know. Yeah you should be fine draining just the radiator. I don't think even the agent drains the block.
- 399 replies
- spares
- service
- repair
- maintenance
I'm a fan of body coloured mirrors and less chrome on cars that have a sporty look. But that's just me. It looks alright. ? More or less. But since I don't use the flushing chemical, I don't do most of what's mentioned in step 2 and 3 (leaving the engine running with the hose running water into the radiator). As I mentioned earlier, there's no specific way to drain the engine block. When you drain coolant from the radiator, most if not all coolant in the engine block will flow to the radiator under gravity and exit the system. So you are draining the engine block as well. In summary, this is what I do: 1. While the engine is cool, remove the radiator cap and expansion tank cap. Remove the drain plug and let all the coolant drain out. Prior to doing this, it's good to have left the car idle with heater on so that the coolant goes through the core and the thermostat opens. But do not open the radiator cap until the engine is reasonably cool. Use an old rag to open the cap if it's warm, incrementally opening it to vent the pressure. And be careful. 2. Plug the drain and fill the radiator with water. Drain again. Repeat until you see clear water draining out. One or two repeats would do. 3. Empty the expansion tank and rinse well with water. On the EX, the expansion tank can't be taken out easily, so removing the rubber hose at the bottom of the expansion tank is how you'd drain it. Keep the hose off while you rinse with water. 4. Once done, connect all hoses, plug the radiator drain and fill the radiator with coolant. Fill the expansion tank halfway in between the min and max markers. 5. With the radiator cap off, start the car. Let it idle for 20 minutes with the heater on. This will bleed the air out. 6. You're done. Keep an eye on the temperature gauge and expansion tank coolant level for the next 20 - 50km.
- 399 replies
- 1
- spares
- service
- repair
- maintenance
1. You can keep your existing shock struts and just swap out the springs. This is the cheapest option. If the gap is all you care about, this would be the way to go. Obviously you won't get the adjustable height and rebound/stiffness settings that you get with a set of coilovers, but this is a good way to lose some height. 2. Agree 18" is the way to go. And the wheels @K.o.N.o.S has on his EX are the stock RalliArt rims which are 18" 7JJ wide and +46 offset, wrapped in 225/40 R18. You will feel a difference in comfort as soon as you go for the bigger wheel with narrower sidewall, but the car will handle much much better. Especially after being lowered. The compromise in comfort isn't much. I hope @K.o.N.o.S will agree. My setup is much more aggressive, but she's a weekender, so I don't mind. 3. Tyre size mentioned above. I like the cleaner look without it too.
- 399 replies
- spares
- service
- repair
- maintenance
That shine! ? Did the chrome side mirror covers come with the car? I doubt they did. Ooh I had forgotten that yours had an Evo spoiler! Love how the wheels fill those arches - just the right amount of low. ? I just noticed that the body coloured moulding that goes across the middle of the doors are missing in mine. Searched local classifieds and found out that none of the cars here have it. By the way @Hyaenidae, here's a DIY thread for you if you want to attempt it yourself. Note that a flushing liquid is used here, but you can skip that step. I'm sure you can pull it off. I have lost count of the number of times I've done coolant changes myself - it's that easy.
- 399 replies
- 1
- spares
- service
- repair
- maintenance
Okay let's see if this works... Convinced yet @trinity? Also this is why you need the high spoiler as well.
- 399 replies
- 4
- spares
- service
- repair
- maintenance
When the radiator is drained, coolant from the engine block will flow into the radiator under gravity anyway. Although your coolant looks good to the eye, over time, coolant loses its pH level and turns slightly acidic and loses its rust prevention properties as well. There are coolant test strips (basically a pH test against a given scale) which is probably an option for you if you want to make sure. My advice is to get a regular coolant change (not just the expansion tank) done if you're doing it. Don't worry, if you keep the engine running as explained above, air bubbles will be bled out of the system. If you are concerned, just keep an eye on the temperature gauge for a couple of days. ?
- 399 replies
- 1
- spares
- service
- repair
- maintenance
- Lancer EX Running Repairs and Maintenance
Depending on the pressure rating of the radiator cap, coolant (and air) will push it's way out through to the expansion tank eventually. However, this doesn't happen as easily as when the radiator cap is open. By the time the radiator cap's pressure relief valve is ready to open, the coolant is under high pressure, and it's boiling point has rised above the value at normal atmospheric pressure. So there could be very hot air bubbles still in the system that are unable to escape for quite some time. If the air bubbles are deep within the engine, it can cause hot spots and even damage the block. So it's best to do it it beforehand.
- 399 replies
- 1
- spares
- service
- repair
- maintenance
I did it myself at home. So I didn't use any special tool. Just followed the conventional method of replacing coolant. To bleed out air from the system, the engine was started with the radiator cap off and heater on for about 15 minutes until the thermostat opened up. This causes air bubbles to be pushed through the system and out the radiator filler port. The tool suggested in the manual makes it quick and easy because you don't have to run the engine and just wait until the car does all the bleeding. But it is not mandatory to use it.
- 399 replies
- 1
- spares
- service
- repair
- maintenance
What is this subtle noise?
Agree with @TheClutch. Sounds like worn out wheel bearing(s) or CV joint(s). An inspection will confirm. Hard to think bearings would give way on such a low mileage car. So maybe check if one of the CV boots has a tear that's caused all the grease to leak out. Also, high pressure water from the server could have gone into the CV boots causing the grease to soften. This happened to me once due to a broken CV boot clamp.
Mazda engine sound problem
Welcome to the forum! Sounds to me like your mechanic has taken you for a pretty good ride. He's basically replaced the entire drivetrain (not to mention with recon parts) without checking simple things first. For example, did you get a wheel balance done? It could be something as little as a missing or fallen off wheel weight causing the wheels to resonate more at a specific speed range. It could also be a stuck brake caliper binding one wheel at lower speeds. If you hear a hum from the front wheels at high speeds, it might even be excessively worn out wheel bearings. It's hard to diagnose things like sounds and vibrations on an online forum without seeing the car in person. The best would be to take your car to a different mechanic and have them inspect the front suspension and brakes first.
Project Moggie - Painting
You sir, are a legend! Made my day seeing how beautifully that has turned out.
- Car Recommendations
KIA Vehicle repair
@Imeshuvithanage, welcome to the forum. Please refrain from opening duplicate threads across different sections of the forum. You might also want to search the forum before creating new threads. Threads merged.
- Quick Trivia 3
Quick Trivia 3
