Lancer Cs1 Suspension
You can find the manual in this thread: http://forum.autolanka.com/topic/9732-lancer-service-manuals-available-here/ Look for the FM42 manual transmission manual. Fluid levels, service intervals are all in the manual.
Buying Mazda Axela 2014/2015
Are you kidding me? Axela is the JDM version of the Mazda 3 and should be pretty similar. There are enough and more places to get the Axela serviced and repaired. C@r M@rt has lost their game after C0l0nial stepped in. They seem to offer better service than C@r M@rt. There are many other places like Mazna @ Pepiliyana that does Mazda specific repairs - Axela included. Not sure whom your friend contacted, but the "service engineer" doesn't seem to know about their own brand. Search the forum for more info. The Axela has been discussed many times.
Yes I do. And I will.
I sure do machan. That's the day we did the Katunayake Expressway run. I also got the transmission oil changed at about 90,000km (@HashanJay, mine was a CS3, but same transmission) because I felt like the car had a problem shifting down to 2nd gear. It was sorted after the oil change.
I remember the workshop manual saying 100,000km. Check it out in the manuals thread. The oil is SAE 90. The "W" specification is irrelevant in Sri Lanka.
Cool Ebay Gadgets For Cars
You can check this yourself. The port should be located under the dashboard (close to the steering column most probably). I think the Nissan OBD1 port has 14 pins whereas the OBD2 is a generic 16 pin port.
Misfire With Burning Smell
Glad you got the issue sorted out Schiffer. 10k is pretty reasonable.
Brake Fluid Resistant Adhesive
Can you please share a photo of the exact place that this is leaking from?
Car Paint Color Change
Procedure: - Strip the interior (seats, carpets, dashboard, upholstery etc.) and exterior (windscreens, trims, lights, badges etc.) components. For a proper job, the engine bay will also need to be emptied, so that the bay can be painted. - Do body work (repair rust, straighten out panels) - Prepare the body for paint (this will involve sanding down the old paint so that the new primer/paint will stick properly. Doesn't have to be stripped to bare metal IMO). Then prime the body. - Apply paint and clear coat. - Re-attach all components - Do initial polish (a final polish will need to be done after a month or so) Legal issues: - You need to change the car registration with the new colour. For this you will have to submit a "Change of Particulars" form to the DMV. I believe the form is CMT 72 which can be downloaded from here. Search the forum for more info. Problems for insurance: - There shouldn't be any. However, you will have to submit the car for inspection at the insurance company, so that they can update their database with the new appearance of the vehicle.
Foot Board Protect Stickers
No worries. Thanks for understanding.
Hi rush9975, we understand that you have bought a new car and that you want to keep it nicely. But please don't open a thread for everything that pops up into your head. It makes the forum cluttered with redundant information which makes it difficult for newbies like you to search and find. - Search the forum (here's how). If you did, you would have found the following threads that would help you: http://forum.autolanka.com/topic/16500-anti-scratch-sticker-for-door-step-interior/ http://forum.autolanka.com/topic/15467-installing-scuff-plates/ - Open a thread titled "Help with my Honda GP5" and ask all your questions in that (like this one) What can happen is that the sills can get scratched and damaged as footwear of passengers strike or rub against them. If you want to protect the sills, go for the sticker or scuff plates.
Car Roguh Idle
The carburettor has an idle air control mechanism. It is probably this that is messed up. Not sure about the EG8's carb design, but the idle air control valve should be attached to the carburettor body. You can remove it and clean it using some carb cleaner - safely. Doing so should solve the idle issue if the rest of the carburettor is in working order.
I'm going to assume that the "tank" you are referring to here is the master cylinder housing. If so, what you are saying is that you replaced only the pistons and stuff from another master pump which is not identical to the one on the car? Not a good thing to do. My suggestion would be to just replace the entire master cylinder (this time with the housing as well!) with one that is compatible with your car. You don't want to play Frankenstein with the brakes.
Engine Stops When I Turn The Ac On
Adding fuel system cleaner to the tank might have caused dirt and gunk in the tank/fuel pump assembly to get lodged inside the fuel filter, causing low pressure at the engine end. Verify if the check engine light (that came on during the second occasion) is related to low fuel pressure. If so, the fuel pump assembly should be taken out, the filter cleaned/replaced.
The error code that resulted in the check engine light should be saved in the ECU error log. A scan will reveal what the issue is, so better get a scan done as soon as possible. The check engine and AC compressor issue are two different issues IMO.
- Peugeot 407 Turbo Repeatedly Fails (4 Times)
Not all rubber is brake fluid resistant. You should look for one that is specifically designed to be used on hydraulic systems as Rumesh has mentioned above.
My knowledge on turbochargers are limited, but I'll share some comments based on my experience and what I think might be the cause. A turbo can fail within minutes if the shaft isn't lubricated properly. Since oil starvation was observed by the Garret turbo repair shop, your friend's mechanic might want to first check if the oil feed does supply adequate oil into the turbo, without repeatedly changing turbos expecting a different result. The oil feed line might be blocked (sludge, carbon or even a bent pipe). EDIT: Just read your post again and saw the part about the oil pressure. May I ask how the oil pressure was checked? Was it by tapping into the oil pressure switch plug hole or by checking the pressure on the oil feed line to the turbo?
Ford Mondeo
That indeed looks like it's very well kept. Congratulations! A light polish and a clean-up of the headlights and it'll start looking like it just left the factory. Good luck with the car.
I wouldn't recommend cataloy because the brake fluid will slowly weaken it. Plus, cataloy is meant to be kept moisture-free after application. Not sure about Araldite either because there is no guarantee of how the chemicals will react once it comes into contact with brake fluid. The best thing to do is to find an o-ring which will seal the gap between the reservoir and the master cylinder. Should be pretty easy to find. Just take the plastic reservoir with you and look for one with the matching size. A temporary fix would be to apply a few rounds of Teflon tape (referred to as "thread seal" in Sri Lanka). Doesn't react with brake fluid.
Allion 240 Noise Under The Dashboard
Rattles and random noises are difficult to diagnose without experiencing the noise in person. But the grinding noise could be the fresh/recirculate flap opening and closing. If you have an automatic AC (and if you have it set to "auto"), the system occasionally opens and closes this vent to maintain the air condition inside the car. Try manually pressing the fresh/recirculate switch to determine if you hear the grinding noise. If you do, then this is probably due to the lack of lubrication or dust accumulation between the moving parts of the flap. A simple clean-up should eliminate the noise. Please note that this is just a guess.
When To Do Oil Change / Services In A Honda Fit Gp5 And From Where ?
These threads should answer your questions: http://forum.autolanka.com/topic/17344-honda-fit-gp5-car-service/ http://forum.autolanka.com/topic/15480-honda-fit-hybrid-maintenance/ Please search by following the guidelines given in this thread.
Japanese Car News
Only seeing this today. Nice set of photos. Thanks for sharing iRage.
Problem With The Brakes
Agree with Rumesh about the possibility of a vacuum leak. The duration within which you feel the loss of braking power the time where the vacuum is trying to overtake the leak, but is still behind. Is this a new Cerato Crosswind? If so, I think the vacuum for the booster is not supplied by the intake manifold, but by an electrically controlled vacuum pump. I'm pretty sure that this is how it is on the Sorento. You should be able to verify by following the booster vacuum line and inspecting where it is affixed to at the other end. If vacuum is supplied through the intake manifold, then try racing your engine as soon as it starts (so that vacuum builds up faster) and see if the 30 second window closes up. If it does, then there's a high probability that it is indeed a vacuum leak. By the way Rumesh, this is the first time I'm hearing about the "notch" on the booster. I have in fact removed a KE20 booster, but I didn't notice this. However, I have seen boosters with a check valve.
Good Mechanic And Workshop For Toyota Ae100 @ Matara
Sorry for having to go OT here, but a few things need to be corrected. Not true. A wheel alignment should be done in any situation where the suspension system has either been worked on, or had to be even partially taken apart for another repair. This includes, changing tyres, rims, replacing wheel bearings, shocks, CV joints, transmission repair (on vehicles that has a front axle), power steering or any suspension repair. As for EFI tune-up, Waiting long enough until your car develops "significant pulling power issues" is not a good idea. If you want the engine to run optimally (which in turn ensures fuel efficiency and a smooth drive), you need to ensure that the car undergoes a fuel system clean-up every now and then. Garages in Matara: I remember trinity getting a repair done from a place in Matara and was quite happy with their work. Not really sure if that was UniMo in Matara. Also OP, we have the thread below. You can use it to find/share info about good workshops. http://forum.autolanka.com/topic/15974-good-mechanics-technicians-workshops/
