- Post Whoring - Part 2
I never got to play Mafia 2. This just makes me want to! After how Mafia 1 ended, I can't seem to think of a way of how they connected the stories. Guess I'll have to play and find out. I remember there was this race on the original Mafia game which was almost impossible to win. I must have played that mission for days and days just to win the race. After I finally made it to the next mission, I found out from a friend that there is an easier way to win the race. Not going to spoil it for those who have not played it yet.
Quick Trivia 3
Yay! Thanks for starting this again tiv! EDIT: Okay since no one seems to be taking the turn, here you go. Making it as difficult as possible because I have heavily under-estimated you guys on this thread in the past.
Sloshing/splashing Sound From The Fuel Tank
99% sure that there is water inside one or more of your doors due to the small drain holes being blocked. Take a small piece of metal wire and insert it to each drain line on the doors. Water should start pouring out from the doors that have blocked drains.
Fixing The Oem Spoiler
First of all, we already have a thread specific for Viva Elite Spoiler here and we also have a Viva Elite Community thread here as well. Please search before opening new threads. Secondly, most spoilers require drilling the body to install it. This doesn't mean that the car will start to corrode from where it was drilled. If the job was done properly, the drilled hole has to be painted (preferably with the body colour or something close) so that no bare metal is exposed. The surface on the spoiler that comes into contact with the body needs to be secured with double-sided tape. The tape prevents water from leaking into the gap between the spoiler and the body and into the car through the mounting hole. Finally, installing the spoiler isn't that complicated, all you really need is an electric drill, a set of basic tools and patience. More here. I was searching for a spoiler for my father's Demio on eBay and came across this excellent video about how to install it. The method used to locate where to drill (using cardboard stencils) is a great idea. Wish I had seen this at the time I did mine.
Cool Ebay Gadgets For Cars
Remove one bulb and take it as a sample. Check the ones they give you to make sure they're the right ones. Not sure if both bulbs (on one side) are double filament or not. Make sure before you buy.
The white Presea is in a significantly darker environment as well. So the light can be seen as brighter. The tail lamps should be 12v 21/5w ones I think, so you can maybe pull one out and see if the bulbs on the car are correct (wrong bulbs maybe the cause of a dimmer light). The rating should be engraved on the base of the bulb. Tungsten bulbs shouldn't fade over time in theory. You can also check if the tail light housing is dirty on the inside. A small leak can lead to carbon deposits building up on the inside of the housing that gives it a "smoked" look. This can cause the lights to look dimmer. Your lights look like they are pretty okay.
Lancer Service Manuals Available Here
Sorry for bumping up this thread. Thought of updating it with the manuals for the Lancer RalliArt (2009 onwards). Some of the manuals here might be useful for Lancer EX (and Evolution X) owners as well. http://forum.autolanka.com/topic/17191-mitsubishi-lancer-ralliart/#entry282923
Mitsubishi Lancer RalliArt
RalliArt Service Manuals TC-SST Service Manual [Download PDF] TC-SST Overhaul Manual [Download PDF] RalliArt Service Manuals (Sportback*): [Click Here] RalliArt Body Repair Manuals (Sportback*): [Click Here] RalliArt Technical Info. Manuals (Sportback*): [Click Here] Lancer/RalliArt/Evolution Reverse camera installation guide: [Download PDF] *Most of the service manuals are applicable for the RalliArt sedan as well. Will add manuals to this post as and when I can. I have also modified some posts above with more info.
- 108 replies
- cy4a
- twin clutch
- cy
- sst
Thieves Removing Side Mirrors On Vezel
Read Sampath's post above. It won't cost you 90K. It won't even cost you 1/4 of that.
Buying a new smartphone
Been using a OnePlus One for over an year now and I have no complaints and I love it! The OnePlus Two is out and... Dual Sim: Yes Android: Yes, 5.1.1 Screen: 5.5 inches Cost: 329 dollars onwards You will have to order and ship it to a US address by using a service like ComGateway and then have them ship it to Sri Lanka. You'll also need to get hold of an invite to be eligible to buy the phone. More info at OnePlus.net. If you just want to get hold of a phone without all the hassle, then this is probably not the one for you although this is the cheapest one with the specs that can be compared with other flagship phones.
Since this happens at your own home, you can also think about installing a CCTV unit or even a simple motion sensor that triggers a light or something as this is happening too frequently. A cheap Chinese CCTV unit can be purchased for less than 10,000. Cannot comment on their reliability as I have not used them personally. According to your first picture, neither riveting nor chaining will prevent from that kind of damage. The mirror appears to be broken off from the arm itself. Can't believe the bugger actually did that without making a sound. Even if the thief was interested in nabbing only the glasses while they are secured using cables, I think they can be cut using pliers pretty easily. If you really don't want to drill the body of the car to rivet the badges, What you can probably do is paste rivet heads on the badges so that they appear to be riveted. This was suggested by someone on the forum many months ago and I thought it was a good way to fool thieves into thinking that the badges are actually riveted.
- Axio 2008 Issues
Mitsubishi TC-SST Video Series by MRT Performance Here's a series of videos by MRT Performance - a workshop in New South Wales, Australia that does work on performance cars. The gentleman in the videos is Brett Middleton, a pleasant character whom I contacted before buying my car, for advice. He pointed out from where I can get my car serviced in Victoria (since NSW is almost 1000km away). A knowledgeable engineer. Mitsubishi TC-SST oil cooler and other info: TC-SST secrets (part 2): TC-SST secrets (part 3): Tried finding part 4, but couldn't find it. TC-SST secrets (part 5): TC-SST secrets (part 6): TC-SST secrets (part 7): TC-SST mechatronic solenoids: Their channel has heaps of other videos on the RalliArt (and others) and comparisons to the Evolution X and so on.
- 108 replies
- 1
- cy4a
- twin clutch
- cy
- sst
Mitsubishi TC-SST (Twin Clutch - Sport Shift Transmission) Articles Okay guys, since a lot of you have questions about the TC-SST transmission, here's an introduction to the SST. Intro (sorry I couldn't find a way to embed the video in the post): http://www.knoxmitsubishi.com.au/videos/video/61 One of the best articles I have found online about the SST (How it works, problems, upgrades): http://www.jackstransmissions.com/pages/sst-how-it-works-problems-upgrades EDIT: Adding more info Specs of the TC-SST (Model No. 6DCT470) by Getrag: http://www.getrag.com/media/media/press/english/2012_2/2012_02_01_presskit_6dct450/Press_information_6DCT450.pdf
- 108 replies
- 1
- cy4a
- twin clutch
- cy
- sst
Yes madmax, it's Mitsubishi's TC-SST that comes with the Evolution X. While the Evo has three shift modes (Normal, Sport and Super Sport), the RalliArt has two (Normal and Sport). There are places that does transmission ECU re-flashing that allows Super Sport mode to be enabled. Thanks isam. I wanted a black one until I set my eyes on this. Edit: Corrected typos
- 108 replies
- cy4a
- twin clutch
- cy
- sst
- W123 Restoration
- W123 Restoration
From your photos, it looks like there has been bodywork done on the car before as well (referring to the spot-welded panel inside the trunk and the patch panel attached to the wheel well). And it looks like the panels were not painted after being attached. Have the tinkerer remove the rust on the panels, and give a good seal (undercoating on the under side and a few layers of paint inside the trunk) so that they don't rust again.- Mitsubishi Lancer RalliArt
Thanks Reckless! You can have it as long as your driving is not as same as your forum username.- 108 replies
- 1
- cy4a
- twin clutch
- cy
- sst
- Engine Stops When I Put To Reverse (Sometimes)
- W123 Restoration
- Air Intake Cleaner On Nze141 Engines.
I assume you are referring to throttle body/carburetor cleaner. While it is okay for TB cleaner to be sprayed into some engines, some manufacturers strictly warn against doing so. Follow this thread and read up on the best way to clean a throttle body. Taking the throttle body out of the car, spraying TB cleaner onto a clean piece of cloth and then wiping the throttle body is what I would advise. If you must spray it, make sure your Idle Air Control Valve (IACV or ICV) and Throttle Position Sensor (TPS) are removed from the throttle body as they might get damaged as discussed in the thread to which I have provided the link above.
