Lancer Cs3 (2003) Octane 92 Or 95?
91 octane or higher. That's what the owner's manual says. I believe this was shared on the forum before. Edit: During the time only 90 and 95 was available, I kept using 95 and switched to 92 when it became available. No problems encountered and the engine behaved normally. You might want to check if this applies to the 2003 - 2007 facelift CS3. The below post suggests that the manual for the facelift says that the recommended fuel is 95 octane. I've seen a 2004 facelift manual and that too said 91 octane. Maybe later models require 95. http://forum.autolanka.com/topic/15687-help-with-my-new-cs3/?p=253444
Any Place For Alternator Repairs - Not Pala Please
Before doing anything, I suggest you check if both your battery terminals are properly tightened up. If they are, get the battery and charging system checked up from a good place as Crosswind said. Car bogging down could be due to loss of power from the battery (loose terminal).
- Rat Problem, Advice On Next Steps
http://forum.autolanka.com/topic/60-how-to-attach-images-to-your-post/ You need not rewire the entire car just because a couple of wires were damaged in the engine bay. However, you should get the wiring checked thoroughly to ensure that there are no damaged or exposed live wires touching the body for example.
New Models Launched By Uml
Read this a few weeks back when I was looking into the Evo - Final Edition: Source So it's going to be a SUV with an "Evo" badge... if you call that "making a comeback".
Brake Disk Facing
Pretty much the same here as well The Don. In my case, the rotors were okay, but the car had not been used for almost 4 years - belongs to my cousin. The rotors had surface rust and only a very subtle resurfacing was done. It was part of putting her back on the road until I can buy a car of my own. Luckily, I have a Sri Lankan friend who owns a workshop here, so labour charges are okay; Obviously not as cheap as it is in Sri Lanka. Looks a bit different to the one that was used on the Holden, but did pretty much the same job. Glad that these are available in Sri Lanka. That is a result of the brake rotor being balanced. Don't worry about it. When rotors are manufactured, sometimes irregularities exist right after the rotor is removed from the cast. Each rotor is put on a balancer and parts of the rotor is shaved off the inner side to balance it.
Brake Disk Facing
Did this on the Holden Nova I was using for a couple of months and what's done is the brake calliper is lifted off the rotor (only one nut was removed and the calliper assembly was hung on the strut spring using a cable). The car was on a hoist about 2 feet off the ground. The resurfacing unit was secured to the wheel studs so that it can spin the rotor as it resurfaces it. Then the cutting tool was positioned in the same place that the brake calliper was located - because the rotor is exposed from both sides in that specific place. The cutting bit was correctly positioned after some fine tuning and then at the flip of a button and about 10 minutes, the rotor was looking brand new. Pretty good piece of machinery. There is of course nothing wrong with doing it the traditional way because the rotor actually just slips out of the hub and only the calliper needs to be taken out. Wheel alignment or any other adjustment is not affected. A competent guy at a good machine shop will be able to do an equally good job IMO.
My opinion is that a properly serviced and repaired alternator is better than a used one. I'm a bit surprised that the genuine rectifier costs that much though. Did you personally check with the agents? Also, I don't see how the alternator itself can go bad due to a faulty rectifier. If the winding is intact, then the chances are that it will continue to work fine after a new rectifier is installed.
Most Easiest Way Of Restoring Your Head Lights
Can't believe we are going into this level... Just use some 3M rubbing compound or a similar polish. Much more effective than toothpaste.
I Cant Change Gear When The Engin Start
My first guess is that your clutch slave cylinder (also called the clutch fork) is faulty. This is located in the gearbox and is coupled with the release bearing. It could also be the master cylinder, but the CS is known for slave cylinders giving trouble (as per UniMo) after about 60,000km of running. Try this: - Put the car into neutral and start the engine - Press and release the clutch about 5 - 6 times in a pumping action (fully press and release) - Press and hold the clutch - Try shifting into first gear if it shifts normally, then there is definitely a master/slave cylinder problem. Again, I'm guessing it's the latter. The thing about failing slave cylinders is that the clutch starts to feel a bit too soft. I'm not quite sure why yours is normal. Did you do a brake repair recently? How's the condition and level of your brake fluid?
Project Capri
Hooray! I remember this conversation from the beginning of the project. Good move.
Come on dude, at least give a detailed answer without copy pasting my own question to you... If you need people to help you, help people by explaining your situation.
What do you mean exactly by "can't change the gear"? Is the lever stuck? Does the clutch feel normal?
Project Capri
Love the Duck Tail spoiler! The front looks badass already!
Bmw 320D Swirl Flap Blanking
Please stop opening multiple threads on the same topic.
Rectifiers are specific to the model of the alternator and therefore the vehicle. So electricians may not stock every model with them and you might have to buy them separately. The alternator in your Presea is probably shared across many other Nissans, so the rectifier should be easy to find.It takes time to remove the alternator, service it and put everything back together. 2.5 hours seems just about right.
It's actually called the "rectifier". Because that's the circuit that converts the alternating current (AC) generated by the alternator to direct current (DC). Older cars came with 4 separate diodes which could be replaced individually, but most cars after the 80s or so came with a integrated rectifier which has to be replaced as a whole unit. Simple job as stated above by Crosswind.
After An Engine Tune Up
Asnu does have all equipment that tests all aspects of injector function. I haven't been there personally, but I know that they have got their equipment. They actually have the ASNU ultrasonic injector cleaning equipment and the injector testing machine (this one) which tests if all injectors deliver the correct amount of fuel etc. I knew that the owner of Asnu had an arrangement with another garage to get things done, but all this time I thought that it was the garage situated right behind the Asnu place. Another place that did this is Nalaka Wheel Alignment Centre in Hyde Park Corner. I have been there once and they did a superb job (there was only one mech doing this job and he was a former A*W guy - knew his stuff and was very good. I don't recall his name now). Cleaned the injectors with ultrasonic, tested them, cleaned the throttle body, replaced plugs and ran a full diagnostic scan and did a trial run. Not sure if they still offer the service.
Mitsubishi Lancer Cs3
I'm guessing this is a facelift. The price is okay. The interior rexin cracking up on the doors is a common, if the car is left in the hot sun regularly and mostly for the dashboard polish our service stations use. I have had to re-upholster them. See the thread below: http://forum.autolanka.com/topic/15984-reupholstering-interior-panels/
Shock Absorbers
Wait.. Nalaka has been closed down?
Old thread, but since this is still a valid question, the simple answer is "no". I wouldn't call tappet adjustments to be part of a regular tune-up. What is usually done is: - Injector clean up/testing (some use the 3M or Wurth fuel system cleaner and run the car until the can is empty, but I personally like to get the injectors cleaned using ultrasonic and then tested) - Throttle body clean up (includes cleaning the throttle body, Idle Air Control valve and related components) - Spark plug clean up/adjustment/replacement - Diagnostic scan if applicable (Optionally attend to issues revealed by the scan) The interval to adjust tappet clearances is usually specified by the manufacturer. For a brand new car, the first adjustment may need to be done after a few thousand Kms (usually at the first service), but does not need to be done at every tune up unless obvious tappet noise is heard.
Honda Fit Gp5
Tried searching the forum before opening the topic? http://forum.autolanka.com/topic/16129-fit-gp5-or-aqua-g/ http://forum.autolanka.com/topic/16016-honda-fit-hybrid-gp5-vs-toyota-axio-hybrid-2014/ http://forum.autolanka.com/topic/16417-honda-gp5/ http://forum.autolanka.com/topic/16485-honda-fit-gp5-inquiry/ http://forum.autolanka.com/topic/16599-toyota-aqua-gs-or-honda-fit-rs-gp4/ http://forum.autolanka.com/topic/15181-toyota-aqua-vs-honda-fit-hybrid/ http://forum.autolanka.com/topic/15480-honda-fit-hybrid-maintenance/ http://forum.autolanka.com/tags/forums/Aqua/ http://forum.autolanka.com/topic/16119-prius-c-vs-aqua/ http://forum.autolanka.com/topic/15962-breakdowns-on-toyota-aqua/ http://forum.autolanka.com/topic/13161-toyota-aqua-2012/ http://forum.autolanka.com/topic/16327-toyota-aqua-s-grade/ . . . and I'm too tired of copy pasting...
- Ek3 Rear Brake
Tyre Prices
Brand: Dunlop Model: SPTRGT1 TL Size: 185/55 R 15 Country of origin: Indonesia Price: 13,050/= (valid for 30 days) From: S. K. Munasinghe (Dunlop agents) EDIT: The final price ended up being 12,900 per tyre because all four tyres were purchased at once.
- Post Whoring - Part 2
