Everything posted by abiman
SLT ADSL data limit on old Home package
Hello, I have SLT ADSL home package bought about 10 years ago. At the time package was advertised as 512kbps down and 64kbps uplink. There was no data limit applied at the time. Today suddenly my speed was reduced to 64kbps downlink and when I called to complain, telecom told me, now there is a 40GB data limit on my connection. Clearly the original agreement didn't had such limit (there was no fair usage policy at the time). Can they one sidedly change agreement with customer to impose data limit? I know many people had this and similar connections at the time. Do you guys have any experience about this? is there any thing I can do to get what I originally paid for? Thanks.
Ford Laser - Re-Condition Gear Box
My CE110 had similar issue and Nilwala fixed it. The cost was about 25k including Toyota ATF. They took 1 day to complete the task. After doing the work, the shifting problem was fixed. But later I heard some sound like metal parts hitting each other inside the GB. They fixed this problem for free. This was done about 3 years ago and up to now shifting seems OK. However, soon after the repair was done, I had to go aboard and for last 3 years car was used for less than 15000km. First day afternoon, they removed gear box and stopped work. I asked them the time they will start work next day and went there about a half hour early. But when I go there, they already done the repair and was half way assembling the GB again. That was the only thing happened to me that I don't like during the repair. If they told me that they would start work 6am, I will be there at that time. (there was no other work at that time too) They probably start early because they have to replace small parts and could not justify the charge. I felt that way during the conversations and body language for my questions during the assembly. (I had no problem with the charge and paying for the expertise they have. Just wanted to see everything myself because I'm mechanical engineer too.)
Dash Cam
I measured over 50C inside the car when it was under direct sun for about 2hrs, while windscreen shades are in use. While driving, average temp inside will not exceed 25C. But unit might feel little more due to direct sun exposure. The problem is I have to park directly under the sun, almost every day, 9am to 5pm approx.
Dash Cam
How safe is it to keep this unit inside a car? I measured the inside temperature of my car to exceed 50C. So when parked under direct sunlight lithium battery must be heating up. What about repeated exposure? Is there any fire risk due to operating environment temperature? Usual commercial devices are rated up to 70C operation. But can we really trust Chinese to keep this in mind?
Duty Officially Increased (October 7Th) Gazette Notification No. 1933/16
As far as I know Aqua is around 12~13mil JPY for auctioned cars in japan. (damaged due to accedents and repaired by SL people in Japan and sold. auction grade R). I think Aqua brand new goes around 20~21mil Yen (not sure) here. So does this mean I have to pay tax for 24mil yen, even if I buy for 12mil yen in japan? if I can afford brand new in japan, once imported to SL there is no difference in tax paid regardless of price in paid in Japan?
Import Personally Used Car From Japan
Will DO. But I'm not allowed to work under my visa and I never sent money home. I just get scholarship money and using that for car.
These links discuss about working visa. Seems like I cant do this. I'm in Japan under long term student visa.
Hello, I would like to know the procedure and documents needed to import a used car (registered under my name) to Sri Lanka from Japan. I want to register this car under my name in Sri Lanka. I searched through AL but haven’t found information regarding this specific situation. questions are, If car registered under my name in japan, bought brand new, will the invoice issued by japan car seller be enough to customs for tax purposes. (There is no money send to japan from Sri Lanka to buy this car. I have only commercial invoice issued by car seller in japan and car is used for about 3 years by me.) Do I have to pay normal tax rate or are there any increased/decreased tax rates for this situation? If car registered under my name for about 1 year, will there be difference? (Thinking of buying a new car before come back) Thankyou
Anti Puncture Liquid And Wheel Balance.
Hello, I'm not expert in cars, but according to physics, achieving dynamic balance on wheels with dynamic geomatry (assuming your liquid is travelling inside wheel) ( hence mass) is physically impossible unless you connect controll system and sensors which measures dynamic imbalance of wheel in realtime according to wheel speed and adjust position of balancing weights at same time.
Car Security System
From ebay. 296.55USD
Car Security System
I,m Using viper 5902. No problems at all for last 2.5 years. However installing all the features took me 3 months, little by little. I did it my self with my spare time. There is lot of features and configuring them are easy.
Leak From Diesel Injector Pump
Hello, Please tell me good place to diagnose and repair leak in diesel injector pump on toyota 2C engine. Looking through, AL I found place called Abeysekara diesel engineering in kaduwela, but could not find any contact details or location. I'm located in Malambe so some place around malambe would be ideal. Thank you.
Not Charging Battery
Hello all, Thanks for advises and it was indeed a fuse. It was located under dashboard near steering wheel. fuse was rated at 10A.
yes it is. But i have unmessed it long ago and it was working fine since then as intended. battery charging voltage is listed as around 14v when engine is running in many al threads. Schiffer, it is not abs bell, just the bell which warn about open door. I will check fuses and thanks for tip.
hello, my car is toyota ce110 1997 auto today suddenly following symptoms occured gear indicators not working. But gears work normally meter panel lamps for heaters, abs not working but airbag , door lamps works when door opened, with key in key hole, bell works voltage of car after starting is about 12.2v. Usually this goes to about 14v car starts normally ac, ac fan not working. But lamps behind them are working. Bulbs which illuminate Instrument panel works ok head lamp and dome lamp and parking lamps works ok reverse camera not engaging on reverse gear. But radio set works. this started when i put car to reverse gear. Reverse indicator on meter panel turned on briefly and then turned off. can you help me to diagnose thanks
Good Tyre Brand....!
I have used 185x70x13 GT Radial (classiro) type 86H Indonesia, thread wear 340 set of tires for 50000km on my CE110. Had to replace because tires are worn from two sides but center thread still good. [lack of air pressure on front wheels ]
- Toyota Oil Filter Housing Wrench
Car Wont Start Please Help
Hi thanks all for help. I managed to start car. Still I have questions. Because most of votes are for heater plugs, I have disconnected heater plugs from their copper wire/[bar] and measured resistances. I measured all of them have around 1 ohm. So I thought heater plugs are ok. Then as soon as heater light goes off, I tried to touch plugs and see whether I can feel heat. I did managed to feel burning heat near one plug, but others had no detectable heat! Then I tried to manually operate pump on diesel filter and then tried to start and never worked. when I'm operating pump I heard some "chuoos" sound near injector pump. then I disconnected fuel out line from diesel filter and when I operate pump diesel came out from this outlet. after connecting diesel line I tried to start car and it never did for some time. then suddenly engine started and died with in 10 seconds. then some help came and he just operated diesel pump thing for about 20 seconds (I did it over 3min earlier) and now car works fine. So please help me to figure out what was wrong and what needed to be replaced. and also I would like to know where the electric diesel pump located in this car. (if it has one!) thanks
Hello, My car is toyota CE110 and has 2c engine with mechanical injector pump. I drove this car from home to office for about 100km on monday morning and parked there. Today night I tried to start (after 2.5days) but only starter motor works and engine wont kik in. I tried to start many times but same thing happens. so far I never had engine issue and car always starts with in 2 seconds even after kept it parked for over five days and tried to start early morning. Now it seems like starter motor rotates engine but engine wont start. heater lights comes up and turn off as usual. please help me to diagnose. thank for help.
Insurance Claim - Consequence Of Telling Truth
Hello, I thought of sharing one incident happened to me today with S*i L**ka Ins…. Company. Last night when I came home at around 1:00 AM night, driver side mirror of my car hit one of concrete beams and broke. Since it was too late I didn’t called insurance that time. (my bad). I called insurance company at about 7:30am next day and told what happened. They asked me to get a police report and estimate and then come and show car to them before repair. Simply they asked me to drive car to garage with broken mirror and then to their office (16km) So I explained them I don’t want to drive car illegally without proper mirror which is dangerous to me as well as others. Then they told me to get estimate and police report. Later I found, to get police report, it takes about week, (I didn’t knew that earlier) so I’m supposed to keep car in home and use other method of transport next week. Then I called lady again and explained this is just broken mirror and please send somebody so I can finish repair this weekend until police report is ready. Lady told me they can’t do that because I haven’t called them as soon as accident happened and I have to follow the legal path. So I learned my lesson for telling truth. Now Hypothetically following could happen with some one else 1. Get car repaired and keep broken mirror. 2. call insurance and tell don’t want claim and show them repaired car, (because already told insurance what happened.) 3. re-fix broken mirror in a month and call them and tell them just broke mirror!!! 4. then probably: no police reports, no estimates,
- Model Number For Bulb
Hi, This is Sprinter CE110 1997 XE vintage with CE110-BEPNS chassis. Model number is to buy several from ebay. I don't have near by shop. so ebay is easy. thanks
Hello, can anyone tell me model number of this bulb? It came from CE110 car dash board. (bulb used to light up dash board AC switches and nobs) thanks
Corolla Ce110 Engine Mounts
Hello nano31 , I bought 2x lower arm bushes on 2011-07-22 for Rs635 each. it was RBI brand and came in nice sealed bag. I had to change these two RBI bushes on 2012-08-11. By then I used them for about 21xxxkm. 2012-08-11 I bought TEZUKA brand and I was told this is japan made. I haven't noted down engine mount brand. But will try to find out
