Everything posted by hatharasinghe
Frameless Wiper Re-Fill
very good work and nice explanation thanks for upload
Lets Talk The Truth About Kia Cars (Please Share Your Real Experience)
Dear All, I tell you all what my real experiance of KIA SPECTRA 1.6 AUTO car which i bought 7yrs back .It is full option car interior leather and it came from Singapore i paid 1M for it (second hand) so far it droves every roads in srilanka specially hill country many times as my hometown is Badulla .Normally fuel consumption is 8 to 9 in traffic and oustation it has around 12 and so to consider the parts (i.e oil filter air filter cv joints break pads etc.. ) cheap i mean genunie parts and engine smooth no vibration.and can go around 120Kmph with comfotable. Here i tell some bad point also. 1.Its power antenna is not suitable for here as once dust and oil particle sticky on antenna and soon it not working properly. 2.Head lights are not enough then changed to HID 3.The main issue is specially until 2007 models the fuse box (Main) as its has lot of loose connections so had to replace to a Japanese one as it created big problem after driving long distance due to heat and all factors sometime automatically ac not working then acceleration has problems so did lot works and finally replaced it then ok.I discussed with this sometime ago in here pls refer. 4.Idont know how ohter vehicals this one ac cooler is inside the dash board and i had to replaced it and to do had to remove dash board carefully and refix it is not easy job. Other than this issues i didnt have any matters still i use it .this is real experience what i have so pls and i dont want to bias to KIA.
Stickers For Head Lights
yes its correct now it like a brandnew condition i bought clear sticker
Accleration Problem After Long Drive
thanks for your comment yes checked all above at L*L A* placed last month finally found out the reason is there was a leakeges at the main fuse box and once do long run due to the heat some slots expand and loosen so then the current pass to the relavent sections are not the rated values so though it took week finally could repair it first divided fuse box two parts and re wire now its ok.
No i paid 3500 for both lights ( first he cleaned then cut and polished finally applied this sticker) the place is at Idigahamula near kirillawala Chamara Sticker yes he has light blue and some more colour.
I went one place to check my HID light system and the car head lights are alreay little yellow colour and the owner of that place told me after cleaning the lights ( removing yellow and polished) there is a sticker transparent and it prevent further discolour and keep it shiny looks they did it so far it seems good but anybody experiance of this as any bad effects ? it costs 3500.
Proton Waja -Battery
thanks crosswind.
Hi all, could you let me know the correct battery for proton waja car as my cousin bought one and it has 45Amp battery but the space to keep it too large seems the original battery capacity is hagher than 45amp. Pls update me.
Godd 7 Seater Vehical
thanks all comments i have a permit and want to buy 7 seater but economical max i can go 65lks so around this range i want good reliable one
Hi all, pls update me whats the best economical 7 seater vehical ( im not looking a van) and the how about the PRIUS PLUS 7SEATER any exp hope your value ideas.
- Diy Scan Your Own Car
Hi , Again this happen thistime i went badulla last friday nothing wrong and drove lot of hill sides but could drive as usual and today back to colombo and it starts at Avissawella as before only speedup upto 40Kmph and once i push the Acc paddle car speed goes down almost 0 but release the Acc paddle and re push it then again speed to 40 so had to drive releasing and pushing Acc Paddle and once engine switch off and re start can go some distance but speed not exceeds 50 and again it comes down and same way. so pls update me what may be the reason and i noticed even push Acc paddle seems no gear change it keeps same and pushing Acc occurs speed down once release Acc paddle and re push then speed upto 40.
Did the scan at carplan but no error so still nothing happen after that so no idea but next week has to go again badulla so will it be a problem hesitate to go
the thing is today evening also i drove but no any trouble it drives as normal so now no one believe there is a problem so does it happen only after long drive or even without any problem at the moment , can mechanic find the problem or may he ask to come with the matter as i have some exp sometime they ask to come when the prob exist.ok ill check the ATF also and my case no any engine miss but though i paddle the acclelaration paddle either rpm or speed not increased.
no any dashboard lights on as i told earlier post (What else to be done ) did the scanning and replaced air flow sensor and Ignition coil after that no issues and still no warning lights on then i checked the radiator coolent level, engine oil all are at correct level today morning it works as before no worrires thats why the worry its happen time to time ( after long drive )
Hi all, Weekend i went Badulla by Kia Spectra Auto Gear Car and no any issues.And once i back to colombo and after Avissawella i feel that vehical not accleration as i want and only it reaches 40Kmph and i noticed rpm at 2000 but couldnt speed further at all and sametime there was a AC issue as knew that the blower not working properly so i stop the engine and start again then it acclerated as normal but only could go nearly 2Km then same matter again stop the engine and started then ok but very short distance then i switch off the AC and tried to drive but the same results anyway came home lately and after overnight today i started and drove to colombo but no issue and AC also working properly . i feel that after heating the engine something wrong on electrical or mechanical pls advice me to recover this matter. Thanks all.
Kyron Turbo Problem
there is a small hose to turbo(from vaccum modulator) just a small tube ( little more size than drinking straw ) and it has a T junction and from that it was loosen and tide to wrong side so my cousin didnt go to any garage he fix it himself so again thanks all for your advices and great help.
Kyron Turbo Problem
thanks yes it was the problem as one hose damged and tight then repair it . thanks all
Kyron Turbo Problem
thanks i'll check this also sure tomorrow plan to do all necessary checkups once finish the job update for all
Kyron Turbo Problem
badulla to kandy shortest way is via badulla, randenigala to kandy and distance is 138Km only for one direction
Kyron Turbo Problem
even try to acclerate engine not moving than 20 and no sign of turbo on and i'll check the diesel filter also.
Head Lights Not That Bright
Dear Mr.Amila,i think you got enough answers for the questions by chan5 anyway there is two types of HID if your current system has 2 seperate lights for HEAD and DIM you have to install 2 HID bulbs system or as usual both in one bulb then HID also 1 and the full system include conversion kit and all they do the installation just remove the bulbs and add the conversion kit for each side and other units and again do the alignment (beam) and total lowerest cost is 6000/= with one year warrenty i did it at the kirillawala place (chamara sticker you can find him at ##### ) but all are chinese no brand but to the cost its ok and sofar no problem you can check it to your car before you pay as they show .and the wattage is 35W so no current issuses .
Kyron Turbo Problem
No as i told the service done at normal service station at badulla not at the MICRO agent as the nearest is at Kandy (140KM from Badulla) and he noticed and told me the turbo is not functioning anyway engine cant get speed more than 20Km/hr engine oil level is ok .
Kyron Turbo Problem
Dear friends, My cousin has a Kyron jeep and he wanted to change the engine oil and oil filter (he lives in Badulla) the nearest agent at Kandy so he went to a service center at Badulla and replace Mobil (the oil for 5000Km) but they unable to replace filter as they didnt have proper tool and tried using chain but couldnt then without replace oil filter he came out from the service centre .Now the CHECK ENGINE LIGHT ON and the vehical unable to pickup it moves only around 20Km/hr speed and seems TURBO is not functioning so to go nearest agent at Kandy 140Km from Badulla pls advice. 1.Is it ok to go such distance with this condition. 2.Pls help whats to be check (DIY) or atleast advice to Mechanic to check the parts.as there is no good experts as col and hard to find computer scan also. Pls help me.
How Can I Install Gps Maps Software To A Gps Unit Bought From Ebay
ok thanks for your advice nextime if i ask some matter regarding vehicals from you i use your given words and so far if anybody hurt for the word " dear" im sorry for them.
