The Stig
Everything posted by The Stig
  1. "Sonali" type "meril" da ? i heard those run good
  2. Wow i feel so sad for the Germans and Japs who spend who spend millions of $ on R&D to get better fuel efficiency and performance when all they needed to do was to put in a 12$ electronic circuit. If you are confused, here is the short answer; Bull$hit !
  3. Youp and i have seen more Toyota axios crashed than Nissan GTR's. Hmmm oh wait
  4. The Stig replied to GTAm's topic in General
    Ha Ha that looks sick !
  5. Dayum
  6. Check this out, it looks like its the same. http://####/en/car-mp3-modulator-cymp3-for-sale-colombo
  7. This is true, diesels have much better lower end torque than petrol cars. You can reverse a diesel without pressing the accelerator at all, on some you can even start from a standstill in 2nd gear without a problem. But they do suffer at higher RPM's though.
  8. Selfie level : Calculator
  9. Batman has gone bankupt, now drives a lorry for a living in daytime and uses the same to fight crime at night
  10. Shouldnt bee too hard, and make sure to carry a toy pistol.
  11. Yes its the same, but point being that by the time your detector beeps its already too late since the gun (LIDAR) has to be pointed directly at your vehicle for this to happen. When using radar the waves bounce off objects and other cars so even if the cops are aiming at other cars your detector will beep and give you enough time to react.
  12. Actually now cops are shifting to LIDAR guns, pointless to have a detector since unless the gun is directly pointed at the detectors exact position on the windscreen there is no way it can be picked up.
  13. And here is a counter argunemnt "Myth No. 5: It's best to shift an automatic transmission into Neutral at red lights. This myth stems from the idea that keeping the transmission in Drive while stepping on the brake wastes fuel and causes unnecessary wear on the driveline. In fact, actual engine wear and fuel loss are minimal. Regularly shifting from Neutral and back into Drive when the light turns green, then immediately stepping on the gas, can wear — albeit slightly — on the transmission, driveline and engine mounts. Ultimately, these stoplight antics probably won't amount to any measurable harm or good; they're likely just a habit by folks who need to keep their hand busy with the gear selector. Our advice? Get a stick shift." Source : http://www.cars.com/go/advice/Story.jsp?section=yd&subject=yd_myth&story=ydMyths There is no correct answer to this problem
  14. And i wonder why ceypetco is making losses
  15. Acceleration is because of the electric motor, electric motors have instant torque as oppose to gasoline engines which need to reach high rpms to get the max torque. Actually any electric car would have better torque that gasoline motors, not just the prius. The mclaren P1, la ferrari ... all use electric motors to fill in the bottom rev range torque gap of petrol engines.
  16. Because it has an Atkinson cycle engine as opposed to the ottoman cycle engines of the rest, need to improve on your google skills. Aerodynamic design here doesn't mean better handling, it means less "Drag" ergo less resistant from the wind. What a good handling car will have is less weight, stiffer suspension, more downforce, better weight distribution, stiffer chassis, good differential etc. None of which the Prius has !
  17. Well for starters there is no car called "Honda Fit Area" its "Honda Fit Aria" Secondly the difference is that City is the export version where as the Aria is the JDM version. The rest has been discussed extensively, do a forum search.
  18. Any one interested in a Samsung "Hard D*ck" ?
  19. You need to explain in detail what the noise sounds like, no one can identify the issue by you just saying "noise"
  20. So what exactly are you smoking ?
  21. Everyone here is talking about Jag reliability, you are talking about pros and cons of Indian cars. Whats the relevance ? This is basically a "yanne koheda ? malle pol" kinda statement
  22. Government earns its highest tax revenue from Tobaco taxation, highly doubt if they will ban it. On a different note i think we should impose a fine or a tax on people who are admitted to government hospitals for medical conditions related to tobacco. We are wasting public money on helping people who dont value their own life, money which could be well spent for some deserving cause.
  23. The Stig replied to monty's topic in General
    If you plan to change the tires change both tires at once, most tire shop will buy back your good tire and give you a discount.
  24. I have seen 2 Guiliettas, a red one and a black (maybe dark grey) one very recently. The new Giulia seems very interesting with RWD, but have to wait till 2015
