zareekz
Everything posted by zareekz
  1. Hi, I want to fix a alloy wheel to my car. The issue is that a part of the wheel that i have is brushing against the brake caliper. A single spacer is not doing the trick either. What can I do?
  2. Vonmek is now Closed down. Any other reasonable place who do a good job and give it ASAP?
  3. there is a product by eagle one, where the water just seeps off the body after washing. No wiping required... - cannot confirm though as ive not tried it... Best one to wipe is the chamois cloth by abro or a old t-shirt..... the 3M cloth is not that effective...
  4. can get you the pair. will cost about 8.5k
  5. One more Q. can you send a pic of the buffer you have? I should be able to get you a set for about 8.5/-
  6. whats your budget for the fog lights?
  7. if im not mistaken, your headlights should be made of glass.... Also, what was the price you paid for it? if you dont mind me asking, coz, i have one too and am tryin to shift it....
  8. Which year of manufacture is it BTW?
  9. 1) Its very difficult to find fog lamps for the corona premio. usually recon ones are sold with the buffer. if you find a place to get only the lights, you might have to pay almost the price of the buffer just for the two lights. In colombo, you'll have to try delkanda, nugegoda. 2) Sorry, cannot recommend 3) take it to a known electrician in your area and get it checked. sometimes, you might be able to fix it. failing which, only option is REPLACE.
  10. did you try maruichi motors in delkanda?
  11. Hi, What is the current market rate for a 1996 toyota corona premio AT211 E-Limited? Info would be very useful. Regards
  12. zareekz replied to SeanD's topic in General
    the mats are anyway more that 12K at any 3M reseller. but worth the price
  13. maintenance is costly i guess, and parts will also be difficult to find.. i guess Toyota AE100 is a good buy.. might stretch your purse a bit to get a well maintained car..
  14. Try Vonmek Engineering, does a good job... Advance Car also does a great job
  15. Try Nishani Motors in Narahenpita, Korean Auto Parts in Maradana, Ajantha Motors in Panchikawatte/ Nugegoda
  16. may if it hasnt been taken care of properly... overall very reliable engines
  17. CT's are usually diesel, AT is petrol. its all different grades, transaxles and engines...
  18. Check the car carefully before buying...usually 5A, 4A & 7A engines are reliable. saying that, when it has run quite a bit, oil tends to burn more, unless the engine has been taken care of carefully...
  19. Try Car Care in Wellawatte, Opposite Savoy. They do a pretty good job..
  20. Thank you very much for the links....
