Magnum
Everything posted by Magnum
  1. Is there any particular reason for this? Why not just paint a thing layer over it
  2. Potenza is currently one of the best or the best performance/track tyre at the moment because it shares some features of F1 tyres. On the downside I read somewhere that it isnt ideal for everyday usage as it wears out pretty quickly and excessive grip could cause problems to components attached to the wheels
  3. I don't think the system can determine the oil quality. The system probably works on a set service interval for UK.
  4. Happy new year guys! Hope you all have a great motoring year ahead!
  5. Jimny, if you are okay with a 2 door SUV
  6. It would be cheaper to buy a duo pack than buying two single packs
  7. This is the latest model of Nightbreaker bulb. I have not tried them yet. Both links you have posted are single bulb.
  8. Magnum replied to Le Sabre's topic in NISSAN
    I just noticed that you are using aftermarket speakers, these require more power than factory fitted speakers. You would get issues in your sound system if the speaker wires are not of adequate gauge also. Also, if your head unit is not providing enough to power to the speakers, it would be better to use a 4 channel amplifier rather than replacing the head unit. You can get them from parts shop
  9. Magnum replied to Le Sabre's topic in NISSAN
    Have you got a pic of how the speakers are fixed? I'm not entirely sure how to check the head unit wiring, probably you could test it using a voltmeter, you could do the same for the speaker wiring also. In addition, you could test the speaker wiring by running a new wire with adequate gauge
  10. Magnum replied to Le Sabre's topic in NISSAN
    Based on your description it sounds like there is a short circuit in the sound system or your head unit is not receiving enough power from the battery/alternator which is why the music stops for heavy bass. Another possible cause for this problem is that the wires running from your head unit to the speakers could be too weak or the wires could have deteriorated over time hence they are not able to send the required power to the speakers. What sort of vibration are you referring to? Was the second Pioneer tested with same equalizer and sound settings? The vibration you are referring to could be caused by hard bass, it could be coming from your side board or the whole speaker could vibrate if they aren't mounted properly.
  11. I assume most people can relate to this
  12. They both seem to be using the same speakers. Whats confusing you? It is better to take a look in spare parts shops before you go down the route of buying from eBay. Also there is a person in the quick site selling bunch of used speakers from Japan for 4000 you might want to check that out too.
  13. The part number for the original door speaker is 86160-52330 It does not mention a specific brand, it is a 20w 6.5 inch speaker I found this on ebay: https://www.ebay.com/itm/OEM-Toyota-Prius-Rear-Speakers-86160-52330-20W/142883410344?epid=672050689&hash=item214483d1a8:g:S7AAAOSw4ZxbWZXg:rk:10:pf:0&vxp=mtr
  14. The CS reminds me of NFS Underground
  15. I dont think that's an easy job, My KDH206(AWD) looks far different underneath around the front of the van compared to a KDH201(RWD). Also only Japan got the KDH206/KDH205 version, all the other markets got different variants of RWD models and Japan imports are bit pricey in Australia.
  16. Notice the reflection, it does not look like a photoshop job. The have also moved the wheel arches forward and the way they have merged the wider commuter body is pretty neat
  17. Meanwhile in Australia
  18. Magnum replied to varotone's topic in MITSUBISHI
    Nightbreaker has a colour temperature of around 3900k, it's whiter than regular bulbs but yellow than OEM HID kits The fog lamps and high beam are Nightbreaker
