Magnum
Everything posted by Magnum
  1. Ooops! I got that mixed up! Yep diesels have more engine braking, I had been mislead all these days by an Indian forum. but yes crawling is easier with diesels than gasoline engines, my Hiace sometimes crawls uphill as well
  2. KDH has D3 no O/D, the previous generation which is known as 'Dolphin' has O/D I understand what you mean by in your first point, If I remember right the KDH could run up to 110km/h in D3, I have used D3 at around 60-80km/h on a flat surface and when I stepped on the accelerator hard there was a difference in acceleration from D, it felt like the van was trying to run away from me And regarding your second point, I think I find D3 enough for hill descends cuz diesel have a shorter a gear ratio/rev band, the gearing ratio/rev band probably plays a role in engine braking, Hiace(KDH) red lines at around 4200PM On the topic of engine braking petrol vehicles start engine braking the moment you let go off the gas, diesels dont which is why its easier to crawl with diesels without accelerating
  3. He could have hooked the chain block to the front tow hook, he ruined the fender To lift the car fully up you need more gadgets attached to the crane
  4. How did they get a cow inside the boot? LOL and that doesn't look like the proper way to tow a car
  5. Are they legal?
  6. I was told it protects the lens from turning yellow or losing its color(tail lights) I got a 3M clear sticker done for my Hiace tail lights surprisingly it turned the red color more reddish lol I left the headlight as it is cuz the fellow ran out of 3M sticker and dad didnt like what was done to the tail lights
  7. DIdnt the engine in the F30 320D/ F10 520D have a major timing chain issue? or does it still have the problem? As far as I know earlier Mercs and BMWs are more reliable than the present models
  8. Magnum replied to james's topic in General Automotive
    Thats surprising! normally its the other way round, did you check with another agent?
  9. I once went to an accessories shop and similar looking Hiace pulled up then those guys at the shop went like " patta! fully modified van ah" to each other I was trying my very best not to burst out laughing That sticker though! Overconfidence much!
  10. To be honest I would burn bit more fuel than wearing out the brake pads excessively, I heard of an incident where smoke started coming out of the brakes when he went down a long decline on D with all the work given to the brakes, the vehicle was a Nissan Vanette. Anyway on the user manual it states to use the D3 when going downhill, atleast it does on mine Something I have noticed about automatics is that when we are going downhill in D especially when we let go off the brakes it straight away goes to the last gear where as in a manual we stick at the 3rd gear or maximum 4th. On the topic of brakes those aftermarket pads are rubbish. I once used them on my car and ended bringing a genuine set from Japan before the aftermarket set was worn out
  11. wait...are you saying D3 and O/D are different?
  12. Meanwhile...why would someone do this
  13. Its not that I dont like it...if it had a grill above the bumper it will look better
  14. I have brought down HID kits which come in big boxes but never had a problem, then I bought volt stabilizer and that was held up at the Kandy post office, worst thing was I had to explain to the guy what it was, he probably thought its some bomb, it kinda looked like one As you're in love with the car and planning to keep it why dont you go for a full paint job?
  15. Magnum replied to james's topic in General Automotive
    Is you invoice FOB lower than this value? I highly doubt so
  16. Am I the only one who thinks the Prius GS needs a grill above the bumper?
  17. Magnum replied to james's topic in General Automotive
    Sooo in that case arent there cars advertised for a lower price than what you will be paying?
  18. Magnum replied to james's topic in General Automotive
    Did you get that CIF value from the seller or the agent?
  19. Maybe you can take all those color codes in that link to a paint shop and find out which one the green is bdw its always best that you buy the paint by yourself when doing a paint job and that too from a well known place the mixing of the paint when you are buying it plays a big role in getting the perfect color match
  20. Im not sure how it is on a car, but on my Hiace it makes quite a difference. Once while going down Kadugannawa I had it in D3 and shifted to D4 to see the difference, it felt like as if I lost the brakes all of a sudden
  21. my inbox was full cleared it, try again
  22. Oh thats bad! you couldnt find another car of the same color? and did you buy the paint from a proper place? If the paint isnt mixed properly you will see a difference in color too The name of your car paint is 'greenish silver,' I'm trying to find the color code, if i come across it i'll let you know Edit: I found all the color codes for your mode, pick the one which resembles the one close to the code marked on your car, you can atleast some part of the code isnt it?? http://www.jp-carparts.com/nissan/partlist.php?maker=nissan&type=75&cartype=16&fig=999
  23. Then you better get the bonnet repainted, use Sikkens if you are after quality, mind you it will be expensive
  24. I dont recommend using that paint thing on such a large area cuz it will show a clear difference in color. bdw does you car have the original paint? or was it re-painted? or not sure?
  25. Let me make this simple when O/D is deactivate/off light comes on the instrument cluster , when O/D is active/on light on the instrument cluster stays off You keep O/D on(light off) during normal driving you turn O/D off(light comes on) when going downhill if needed when going up hill as well or when towing If you are speeding on a flat road with O/D off its gonna put a strain on the gearbox
