Best Practices : Maintain your Car in Top Shape
(got it from the net)
On the Road: • Be gentle to your car when it's cold. Maintain a low rpm level (below 2,000) until the engine has reached operating temperature. This warm-up period isn’t just good for the engine & turbo-charger; gradual warm-up is also beneficial to other components (e.g. transmission, brakes, tyres etc.). If you drive a turbo-charged car (pretty much any diesel today),
• Develop a smooth driving style and don't be hard on the car. Your steering, accelerator, clutch, brake & gear inputs should be polished. In traffic, avoid tail-gating the car in front. Maintaining a healthy gap will allow your braking & deceleration to be a lot smoother. And yes, contrary to popular perception, you can indeed maintain a smooth driving style even when driving fast. On the other hand, if you drive in a rough manner, your car's mechanical bits will suffer additional stress and begin to wear prematurely. A well-driven 100,000 kms car will drive better than an abused 50,000 kms example. • Take it easy and go slow on rough roads. It doesn't matter if everyone else is just flying through potholes. Your car takes a massive beating on broken tarmac. The suspension wears out faster and rattles will seep into your cabin too. • Respect your car. Know when to high-revv and know when to take it easy. At the end of the day, we're car enthusiasts who enjoy our redlining experiences. You should redline only when the conditions permit it. The ideal time to stretch her legs is on smooth roads with scarce traffic. Preserve your car by saving the best for favorable conditions. It's just more fun that way. • Don’t lug the engine, don’t be lazy; shift down if your rpm is too low for the current speed. As an example, you'd move down to 1st gear if your car struggles to cross the speed breaker in 2nd. And yes, please don't ride or slip the clutch. • Slow down on speed breakers. They are there for a purpose. Cross speed breakers in as gentle a manner as you possibly can.
• If you encounter a mechanical problem that could further damage your car, don’t just drive on. Spend some time trying to diagnose the problem
Minimising Abuse: • If your destination entails very poor roads or horrible parking conditions, cab it up!
• Don’t allow bad drivers behind the wheel of your car. Be firm and polite when saying no, or just insist that you'd hate to be a passenger in your own car. Also, don’t lend your car out too often. No one cares about your car as much as you do. • Don’t overload your car with excessive passengers or cargo. Not only does overloading result in undue stress on vital components, it is also extremely dangerous. • Don’t make your car do anything it’s not meant to. Forget about your offroading aspirations in a FWD sedan.
• If you employ a chauffeur, restrict him to driving one car (and not all). Few chauffeurs ever treat cars well and most have rough driving styles. Their sleeping & eating in the car doesn't do the cabin any good either.
At the Petrol Pump: • Make it a habit to fill your tank up as soon as it reaches the ¼ level. Don’t wait for the reserve mark or low fuel warning indicator. Your fuel pump can get fatally damaged in a dry tank.
• Monitor your fuel economy. There’s no indicator of a car’s well-being as its fuel economy. If the FE nosedives, that’s your first clue to something going wrong.
Keeping her Mechanically Tight:
• Fix mechanical issues as soon as they crop up. Don't procrastinate. These problems are likely to intensify and could severely affect other mechanical parts or (potentially) your safety too. For instance, if there is excessive noise from the front suspension, get it checked before the ball joints give way and lead to loss of car control. Don't drive around with the check engine light on. Repair that faulty cooling fan immediately. A car is built of several wear & tear components that will need replacement at some point in time. The longer you delay the replacement of these parts, the more permanent damage you do to other parts in the system. Keeping your car mechanically perfect will give you a lot of satisfaction.
• When something needs to be replaced, it just needs to be replaced. Don't cheapen out of replacements that are absolutely critical. • Choose the right garage or service station.
Schedule, Parts & Labour:
Only use original parts, or parts with equivalent quality from reputable manufacturers. Avoid cheaper ripoffs at any and all costs.
• The single most important thing you can do for your car’s health is change the engine oil on time. Don’t ever overshoot manufacturer-recommended oil change intervals
• Clean / replace your air-filter at manufacturer-recommended intervals (dirt is bad for your engine & turbo). Ditto for all fluids (brake, transmission, radiator etc.). Importantly, respect the indicated min / max levels. Filling excessive oil can at times be as damaging as too little oil.
• Service / top up your battery and clean its terminals (white acidic build up) at least once a year. This is an area often ignored by authorised service stations.
• Get your wheels (including spare) balanced, aligned & rotated periodically.
• Use valve caps on all tyres. No, they aren't just for show. Valve caps keep dust and dirt out of the valve area and help in preventing slow leaks.
• Change your windshield wipers every year (recommended) or two (maximum). They harden with time and from being exposed to the sun.
• If you choose to modify, stick to proven, reliable & high quality parts and labour. There is a saying in the modifications world - "Cheap, Fast & Reliable. Pick any two."
• If you do get after-market electrical work done (e.g. headlamp or ICE upgrade), stick to a top electrical shop. Pay the premium and do NOT compromise on the quality of install. Ensure that the correctly rated fuses are used and properly placed in the circuit.
Keeping her Shiny & Clean: • Cleanliness is next to Godliness. Keep your car spic & span. Depending on your usage, you should wash your car on a daily / weekly / bi-weekly basis.
• A dirty interior says a lot about the car owner. Plus, it takes the fun of driving away. Keep your interiors absolutely tidy and have them detailed along with the exterior. Using a vacuum cleaner comes highly recommended. Avoid keeping excessive items that clutter the inside of your car. Neatly place in the glovebox or storage bins whatever items you need to have in the car.
• Don’t treat your trunk like an attic. • After every driving holiday, treat your car to a thorough exterior, interior & underbody wash at the local petrol pump.
• Get small to medium dents repaired at least once a year. This also helps to avoid rust formation. On a related note, eliminate any rust spots while they are still small. Stick to a topnotch body shop for all denting & painting requirements; ill-fitted body panels & parts lead to rattles and look ugly.
• At the time of repainting, it's advisable to choose the same colour. Changing the exterior shade requires a complete strip down. Factory fit is indeed factory fit. Thus, an overcoat is a far more suitable option.
Parking: • Choose a safe parking spot. Park under the shade as direct sunlight is harmful to paint, plastics and leather. If the area where you park is too messy, get a car cover. It might seem like a headache at first, but soon becomes a way of life. If you have a closed parking spot, consider yourself lucky.
