I did a lil research on why diesel engines have more torque and gasoline engines have more HP, i came across these two articles thought of sharing with you guys
Why do diesel engines deliver more torque than gasoline engines? .A gas engine compresses a fuel-air mixture and then ignites it with a spark. A diesel engine compresses just air, to such a high pressure and temperature that when fuel is then injected, it ignites automatically with no need for a spark. This is the fundamental difference between the two engines.
....so, a diesel engine has to do more compression than a gas engine does, to get the fuel to ignite. Conversely, a gas engine cannot do as much compression as the diesel engine does, because the fuel-air mixture it is compressing would ignite too early, at the wrong moment. Remember the diesel engine just compresses air, so it doesn’t have that problem. ....so, the piston in the diesel engine has to travel further, in order to compress the air more. So the piston stroke is longer in a diesel engine. ....and, a longer piston stroke means a larger diameter crankshaft. Assuming the force coming from the gas piston and the diesel piston is equal, then the diesel piston has a longer lever arm and is turning its crankshaft with greater torque (but, necessarily, at fewer revolutions per minute). The gas piston may be delivering the same power, but it is delivering it by turning a crankshaft at more revolutions per minute, with less torque.
In fact, the diesel engine burns up the fuel a bit more efficiently, and diesel fuel has a bit higher energy content than gasoline, so a diesel piston should actually deliver more power from burning the same volume of fuel. But this is less important than the above argument in explaining the torque difference.
If and when you do want less torque and more speed, or more torque and less speed, than your engine is naturally inclined to give you, you can get it by gearing the engine up or down. That’s why cars have gears, and why big trucks have lots of gears. But of course, transmissions don’t come free, in any of various senses of the word “free.”
The following example made me understand why gasoline engines have a higher BHP
Lets take 2 different engines for example.Engine 1 : is a 2 ltr engine producing 200nm or 147.49 lbft of torque at 2500 rpm. Engine 2 : is a 1 ltr engine producing 100 nm or 73.74 lbft of torque at 5000 rpm. But see what happens when we calculate the power at the rpm where peak torque is produced. engine 1 : bhp = torque * rpm / 5252 = 147.49 * 2500 / 5252 = 70.20 bhp. engine 2 : bhp = torque * rpm / 5252 = 73.74 * 5000 / 5252 = 70.20 bhp. As you can see, engine 2 which is just 1 ltr produces the same amount of power as that of the bigger 2 ltr'd engine, inspite of having half the torque. This is pretty much the concept used in F1 engines. When engine capacity is limited, the only way a "Naturally Aspirated" engine can produce more power is if the torque is got at a much higher rpm. Such engines are not the best when it comes to day-to-day use but can be fun to drive if you can manage to keep them within the "meaty part" of the power band.
So gasoline engines must be having more BHP cuz they achieve their peak torque at higher revs
