Everything posted by thou1584
- Nissan Presea
- Nissan Presea
Nissan Presea
Hello I got down exactly the same pair of bulbs from ebay last week but wasn't satisfied with the output, mine is a vitz 2007 model with H4 bulbs. The only difference is the colour is a little bit white, but other than that, the output is the same i should say. According to my opinion don't buy them.
Allion Gearbox Noise
Hello, I do own a 2014 premio with mileage 3K on it. When i engage the gear to D or R, i get a noise from the brakes because i use it very rarely After a few minutes it goes away. Check carefully, whether you hear the noise from the gearbox or somewhere else.
- Axio Hybride Mirror Auto Folding And Door Auto Lock
Toyota Hiace
Hi Nilantha Congratz On your new purchase. Don't believe exorbitant fuel figures mentioned by others. It should do around 8 km/l in the city. Highway fuel figures seem to be ok. I get 12 in the highway & 8 in the city traffic. These i mentioned from my personal experience, i use a 2007 model 2.5cc engine.
Clarification Of The Results After Engine Tune Up
Hi friends I presently use a 2007 Vitz 1000cc, mileage is 68,000km, did a tune up at toyota lanka since the vehicle was vibrating heavily, problem was sorted out vehicle is running smooth now. Highway run i used to get about 16 km/l, in the city traffic it gives me about 9 km/l. Personally i feel these figures are ok. Some guys quote unbelievable fuel figures that are really hard to believe
Toyota Passo Fuel Consumption Problem
Actually not related to the passo but i do own a vitz 1000cc, which i suppose is the same engine as the passo. Even i get almost the same fuel figures like 8-9kmpl in city outstation 12kmpl. Many people say they get extraordinary fuel figures, but personally i don't believe. This is the real scenario!! .
- Barrel Bbq Build
Engine Stalling While Slowing Down
Check the ECU, even i had a similar problem as yours. ECU was the culprit, got it replaced all works fine...
Smart Key Battery Draining
Hello I replaced the battery once again tried moving the smart key away from all the other electronic devices, & kept it a little distant from the vehicle, &, 3 days have passed & it seems fine now. I think the problem was hanging the smart key with my van remote key together. Finally sorted out the problem i hope Thanx a lot guys for ur help...
Yes I hang it by the side of my van's remote (normal), just thought of avoiding that & try for a few days. Lets see if it works.
Toyotaallion 260 Market Getting Lost?
- Smart Key Battery Draining
Thanks Mr. Sylvi, Will contact him & find out.- Smart Key Battery Draining
No,Its quite far away from the vehicle, but earlier it was working fine, this problem started recently. Couldn't figure out what could be the cause.- Smart Key Battery Draining
The other smart key is with the leasing company!- Smart Key Battery Draining
Hello My car's smart key battery (CR 2032) seems to be draining down within 24 hours, i replaced batteries more than 4 or 5 times, then works fine, but the next morning the battery is dead, & the bulb even doesn't light up on the remote when a button is pressed. I contacted some guys on the Hit*d & they say to replace the smart key unit, which is a bit costly. Please enlighten me on what I should consider?? Thanx- Toyota Kdh200 Van Buying Information
Hi I use the hiace new model, both the petrol & diesel versions as well, Like what supra said i too face problems with the engine being underpowered due to the clogging of the injector using normal diesel (2.5L). But I dont have any issues with the petrol version of the van 2 litre engine, it has enough power to go with a good load as well. One way its better to use petrol hiace comparing the fuel value to the diesel hiace, maintenance & service, etc... Even i too feel that its not reliable as the old hiaces engines. Super Diesel - 147 Petrol 90 Octane - 149- Reconditioning Emblems And Badges
Hey Davy your work is great & useful too!!! How come the badge in the first photo has no joints between the letters in "LANCER" & the pics after has the badge letters joined?- Estilo Or Indian Swift Or Passo
My advice is to go for a passo...- Chery Qq Worth Bying?
I may agree to all what you said, but i cant seriously take what you said about its BEAUTY & OTHER OPTIONS.- Auto Gear
Guys I have a small problem!!! I did a recent auto trans oil change, but the mechanic had overfilled more than the required level, now the gear changing has become a little late, especially from gear 2 to gear 3. My question is if i reduce the oil back to the normal level will the gear shifting become alright as before? please highlight me on this !!!- Enigne Vibrates & Brake Pedal Goes Down
No dude it isn't the way you thought, I personally imported this vehicle through the auction in japan without any agents doing their part in the middle. I have the auction sheet (although it could be faked) also I got the original JAAI & other documents which were perfectly correct. I have absolutely no doubt this was a clocked down vehicle. Even still all the mileage service stickers affixed in japan are still intact, with all emboss seals.- Enigne Vibrates & Brake Pedal Goes Down
Sorry Guys for the very late reply!!! Just wanted to keep you guys posted about the solution. Finally i had to tow the vehicle to the agents, & they pointed out something's gone wrong with the ECU, the current being supplied to the the plugs on top of the engine by the ECU, wasn't being supplied steadily, current was being supplied on & off. they replaced the ECU & finally it was working fine. Couldn't understand how such a problem arised in a new vehicle, mileage less than 70,000kms. Anyaway thanx guys for ur support!!! Once again sorry for the late reply> - Smart Key Battery Draining
