raveeJaya
    3
raveeJaya last won the day on February 26 2019
raveeJaya had the most liked content!
  • Location
  • Interests
    Anything about wheels, Cricket, Badminton
My Vehicle Details
  • Vehicle Make
    Toyota
  • Vehicle Model
    Premio 2017
  • Engine Type
    1NZ-FE
2,618 profile views
raveeJaya's Achievements
  • Reacting Well Rare
  • Collaborator Rare
  • First Post Rare
  • Conversation Starter Rare
  • Dedicated Rare
Recent Badges
28
  1. I got them from the guy who bring down the Axio parts for me.He was so kind to exchange the parts for free !
  2. Update. I have replaced the Front door lock with the controller, now everything started to work as expected. Thank you iRage for your help
  3. Thank you Very much for your help. I really appreciate it. My Axio is a facelift model it was manufactured in 2009. The parts were imported from a 2008 Preface lift model. As you said there were some difference in the wiring. For example Gear shifter wiring was different so we had to change it to the imported one. Im not sure whether the system was working in the previous car properly.However it had done only 30k + on the Odo.Parts looks newer.I saw the original car pictures and it was in good condition (outer look) I will check the receiver and the oscillator. Thanks again.
  4. Thank you for your response ! 1. Yes it is a G grade, I checked the Model code. Anyway since I have changed the Full wire harness it should not be a problem I guess. 2. This is happening with both doors. But Passenger side door is having another issue. It will activate 4X Activation when I try to open by putting my hand, even the door is already unlocked. This is not the case with driver side door, it activates 4X time if it is only in locked state.
  5. Hello Experts, I need some help from you guys. Here is a brief introduction what I did. I have an Axio G grade vehicle with Key start. I wanted to convert it to a Puch start with Smart key. So I have imported the required parts from one of my friend. He brought down a complete Axio for me. I got Complete interior Wire harness and Engine bay wire harness except the Engine and Gear box wires. I have replaced the ECU, door handlers and wire harness of the door but did not changed the door lock(Motor and the locking mechanism). Replaced the Steering column. Dickey switch and handles. Now the all of the things are working as expected except one issue. When I try to unlock the locked door by putting my hand to the door handle, it will try to open the lock 4 times(I can hear 4 times it send the unlock signals to all 4 doors and blinking the signal lights 4 times), but it should be only once. If I unlocked the door from the smart key it will operate the motor only once which is the correct behavior. Is there anybody who could help me to find out the issue. Only thing comes into my mind is to replace the door lock motor and the lock, which I did not do. Thanks Ravee
  6. Hi Guys, I'm facing an issue with the Injector Nozzle plastic O-ring green color (not the rubber O-ring). When we try to clean the Nozzle the plastic O-ring kind of thing broken. Now there is a Petrol Leak from that Nozzle. Attached is the picture of the O-ring circle in Red color. Is it possible to find part for this and replace it or whether I need to go for a new Injector Nozzle. Thanks Ravee
  7. Ok Thank you for the information.
  8. Hi, What was the price you paid for the head unit?. Do you still have the link to the product you bought from Alibaba ? Please let share with me. Thanks
  9. If the front number plate close to the 2 Sonar sensor on the grill, this can happen,Just check that too.
  10. ICS - Intelligent Clearance Sonar having some issue it seems. (Asking to check with Dealer) This means your Clearance sensors having some issues. May be due to dust or something. Check all the 8 sensors in the Front and rear bumpers, whether they are covered with dust or something ?
  11. raveeJaya
    rpm problem
    Yes it may be due to battery replacement as well. Why dont you remove the battery terminal for about 10mins and re-plug it. 'Normally if you remove the battery and put it back the RPM goes high according to my past experience. In normally these vehicles should have 600 - 750 RPM at idle, depending up on whether AC clutch is engaged or not. Anyway if you have not done the Tuneup recently, better try a Tune up too. Do you see the Check Engine light on while the Engine is running ?
  12. raveeJaya
    rpm problem
    What is the RPM you see when it start Vibrating. Did you do a Tuneup recently ?
  13. Just read through the following thread.
  14. Ok Thanks. I ll check it.
