Nissan cdj
Everything posted by Nissan cdj
  1. When i had to buy a new set set to my van the proprietor of tht seat shop said do not take it to service stations to clean/wash ur seats it will lead to rot the seats soon due to the chemicals they use as i hv bn adviced by him i am afraid of doing a full interior cleanup from a service station as schiffer said its okay bt stilll i hv the doubt
  2. Thnx for the helpful reply crosswind.will say tht we can do the interior part wht abt the seats ?
  3. Interior cleaning is good since it gives back the original interior condition if the interior was as it is.and my problem is i got to know that the chemical they use to clean the seat's velvet and the interor velvet are not good for the velvet.I mean due to use of such chemicals it will lead to rot the seats and interior velvets soon. so i wanna get clarify about this doubt from you experrtise whether. it is so or not ? Thnx in advance
  4. Where's this Don and Isam
  5. Both carrs have unique body types and options and this.will depend on ur budget too.just let us knw ur budget and use of car for what purpose ?
  6. <blockquote class='ipsBlockquote'data-author="isam" data-cid="245901" data-time="1377097504"><p> Nissan cdj, with more power from the engine, you will need better breaks to stop the vehicle. You might have to upgrade the breake system too.<br /> <br /> Ask yourself is it worth doing the mod. Were you unhappy with the performance of the old engine? if not why change?</p></blockquote> Isam thnx for ur idea.i think its a good idea and if it is going to be so it would be better but u knw both non turbo and turbo vanetees which came in Vx and Sgl versions though its turbo or non turbo both the vehicles have identical break system with similar option therefore i hope no need ryt? Even i don't know it exactly wether i need it to be done if u knw the scene or the thing please be kind enigh to explain me about this further
  7. <blockquote class='ipsBlockquote'data-author="The Don" data-cid="245885" data-time="1377083055"><p> Don't know if you can give it to the original directly. You will have to figure out the mrchsnism as to how it works with the turbo engine and apply the same to non turbo. The rpm Meyer needs a feed from somewhere and in petrol cars you can get it from the distributor etc. Not sure on diesels. There could be a sensor or a unit you might have to install. Personally its a lot of work for a reading which is not much use in a diesel van. I mean you as an experienced driver can sense the rpm anyway and know when to change gears. What benefit will an rpm Meyer give you apart from it being purely cosmetic. Also be aware if you are changing the instrument cluster the wiring harness might be different.</p></blockquote> The don thnxc for the reply again in my case i hope it would be very easy to fix rpm since there are turbo and some non turbo vanette vx and sgl came with factory fitted Rpm and Don what do u think as isam said do i need to uphrade my brake system too both non turbo and turbo vanettes sgl vx came with same options with same brake system ryt i hope therefore no need of upgration of brake system ryt ?
  8. Cyclist thnxx for the info and u knw most of the vanette turbo owners used to say that their vanettes are fuel efficient than non turbos they say that turbos ld 20 II T engines does abt 16 per litre and their pulling power is soo good that non turbo so isnt it wise replacing a turbo engine since. the current is also about to go out what do u think
  9. Don thnx for yhe info and here vanette engines have no ecu and u knw same engine. same cylinder capacity which interprits just a T as u mentioned and as u said its clear that we can set a rpm externally i mean after market therefore iys obvious tht i can give that line to a orginal vanette rpm meter in the dash so no probs ryt ?
  10. And theres original dash board meter panel with rpm which can fix in the same slot in every vanette and i wanna know though it suits can we make the rpm meter to work ?
  11. Jdnet thanx for the info and i need to knw the abt the fuel consumption of a turbo engine ? and u knw its not just a vanette its passenger vanette Vx with full option and but no rpm since my van is a non turbo and turbovanette vx's came with rpm and turbo.so i need to knw if i fix a turbo engine can i fix a orginal dash board meter with rpm which will gives us the oem condition of the vehicle
  12. Meheshsw that post was not helpful i am up to totally different thing apart from that i am asking pros and cons of replacing a turbo and is it worth ?
  13. Is it worth replacing a turbo engine for a Nissan vanette which has a non turbo engine if so what are the pros and cons as u experts know ? And as i knw itwill cost some more bugs to buy a turbo than a non turbo so i have never used a turbo before and i am more obliged to know it from u expertise thanking you
  14. i am asking if a vanette 1993 which has LD20 2.0 engine and a Susuki grand escudo 2004 which has a V6 engine if both the vehicles are travelling at the speed of 60 kmph on the both speedometers would it be the same speed both the vehicles are travelling.and i am not bothering about the start up pick up Thnx in advance
  15. If we take a vehicle which is old yom 1993 and a new vehicle yom of 2008. if the old vehicle is at a speed of 60 kmph on its speedometer is it same on the new vehicle too or not ? which boh are in the oem condition which is not modified even by changing tyres and all etc thnx in advance
  16. U searching for what kind a purpose is it for home use or wat ?
  17. Thnx don i will check it out
  18. Thnx don and if u hv any idea of price ?
  19. My van is a Nissan Vanette Vx which is 2wd which came with horizomtally mounted oem leaf springs and its really nt good coz as it frighten. eve o comcrete roads so its mt comfatable ridig o this i hv heard tht there are fibe leaf sprigs to be boughtat themarket and i hv no idea about this so i need advice from u expertise to get to know about this is it okay using this on my van and is it compatible with vanette c22 and i hv heard it gives more comfort and nt frightning as oem springs is it true ? Thnx in advance
  20. Currently using 165/70*13 tyres which 2 ceat tyres on back 2 good year tyres in front so i hv heard tht ceat is not good at all for the comfort unless it is being using for a lorry and i need to know wht are the best outta tyre to be used in this van which wull give me higher comfort +higher mileage thnxx in advance
  21. Hope its ferio ryt if nt correct me
  22. Hey people i wonder who chamged the topic ? thanxx a lot guys u ppl are awsum and i ll drive my vanette as cyclist said and try to get the maximum
  23. Hey people i wonder who chamged the topic ? thanxx a lot guys u ppl are awsum
