whmsujith
  • Location
    Negombo
  • Interests
    Cricket, Cars
My Vehicle Details
  • Vehicle Make
    Toyota
  • Vehicle Model
    Premio
  • Engine Type
    NZT 260
2,912 profile views
whmsujith's Achievements
  • Reacting Well Rare
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Conversation Starter Rare
Recent Badges
25
  1. Problem was with tails lights, due to the aging of the car there had not been any proper earthing. Separate earth wires were fixed to car body and now ok.
  2. Hi Guys, I am experiencing same thing in wife's car March AK12 from yesterday as reverse gear "beep beep" sound coming when applying breaks. I was told by a friend that there is unit in the gearbox which gets a signal when applying breaks and put gear box into neutral mode, now it erroneously recognizes it has reverse signal. Is it true? Last month service done at Pitstop Negombo and by there was no issue in the break pads and only driven 1000km from then. Also, After seen @CAMANpost I will check that as right hand rear break light having a crack for last 5 years
  3. I am not sure dude, just do it and see or when things gets back to normal show it to a good auto electrician and see.
  4. I had the same issue in my car, but I didn't see any light coming in the setup. Only 2 days I could park the car, battery was draining out. I took the car to TL and they found that set up was the culprit as it was drawing a small current. Since it was after market fixture they refused to repair it and instead did some changes so that I could on the set up only after car engine starts. So, I had to tune up radio every morning and ran like about one week and fixed a new setup. Problem solved.
  5. Atlantic Ref Engineers, Kadolkae Road, Negombo (road parallel to railway line)
  6. Ok, Thanks. Sounds good.
  7. Is this only a black and white and what would be initial cost? regretting not having a printer at home these days as no place to take a print out
  8. Don't do that. This is one incident as IRage mentioned, a Premio with 9 on board.. http://www.ft.lk/news/6-killed--3-injured-in-accident-in-Wennappuwa/56-671270
  9. Checked at agents in Negombo, nothing wrong with the fuse. Motor had stopped working due to not frequently being used, they said. Now it's ok, but I was asked checked the motor, if again same thin happens.
  10. Hi Guys, My Premio's rear wiper stopped mid way in cycle and now it is not working at all. Can anybody help me regarding this? Thanks
  11. There are Vietnam made once as well. I thnik they are not good as Korean once.
  12. I think when you pump full tank, it will get reset automatically
  13. Yes, after seen this, only ran about 2 km from home to garage Tuesday evening. it will be fixed today tomorrow. I am afraid, I don't have time to be in the garage when the repair is going on, only telephonic conversations with the mechanic.
