maheshw
Everything posted by maheshw
  1. i would suggest you to do a search mate....
  2. Kandy > Hatton > Ginigathhena > Kithulgala > Balangodaroad can recomend you. i used it in january. also you can use kandy > colombo road warakapola > Ruwanwella > avissawella road as well Kandy Avissawella road via Kegalle is pretty bad to drive few months back. dont know how it is now.
  3. and thanks every one for valuable comments.. i dint had much time to check this on weekend. will check on coming holidays & update ....Tc...
  4. Happy birthday Sampath .......Hope you had a grat day .....
  5. Happy birth day Bro......
  6. Fans are ok. it seems in this car too some one has closed that heater lines
  7. Thermostat is working since in cold start its running above 1000rpm & settle down after few minits. yes it's blowing air when switch to hot but not hot air.
  8. @ pug306xsi yes. it's working. but any simple method to check? @ GayanR Bro this is one of my friend car. actually this was told by me one of my friends this car heat option is not working dont know why ?? so we didnt check on that. anw will try this & post..
  9. Guys, Seeking some assistants to identify an issue having in a Nissan N16 Auto car. What actually happen was water in extra tank reducing even in a 30-50km drive. Initially we thought it can be due to a leak but we couldn’t find any leak. We clean the radiator to check this but issue not solve. Replace the radiator cap as well. 1.1 as i can remember. Heat gauge is in half mark all the time but if run in High RPM it goes to red line. What can be the issue? Anything in head gasket? Or can it be a tiny leak in a water line? How to identify exact? Is there any way to check leaks in water line? like pressure test ? Thanks....
  10. + Have you done the Atf on proper intervals? how it's act in cold start? D & R ?
  11. Congtratz Brother...wishing all the best for little princes and parents...
  12. i guess that is from Kundasale auto works
  13. well not an expert. did you chek whether the alternator out put? is your car overcharging? is battery water split over the bettry ?
  14. recently fixed a pioneer for my ek. Sounds are really satisfied even with my ex pioneer speakers all the options are there. HD TFT quality touch screen is superb....
  15. Get some assistant from a good electrician or mechanic who knows what he doing and what he needs to do. Starting problem might be due to ignition coil.cant u find a similar one from a known shop just to confrim this before you replace as u have already replaced few parts?
  16. Happy and prosporous new year for all members and their loved ones !!!
  17. What next ? Axio ? Aqua ? or any other
  18. Thanks bro was able to solve it today luckily by replacing only all four plugs. no miss at all.
  19. Well I am Seeking some advices from experts to identify a similar issue which am facing these days. what actually happens is car is start to miss when climbing hills and its very bad sometimes, earlier it’s only for hills but now on all road conditions randomly. And it’s really difficult to start some times after parking for few hours from few days back. Need to press gas paddle few times for that. What I initially suspect was it’s due an faulty petrol pump. I met my mechanic and he changes the plug wires to check this but no use. Next we change the petrol pump and that also failed as car is still having the issue. His next plan is to check the head gasket as above two failed and plugs also seems to be good in conditions. What he said was when engine comes to working temperature even if there is a tiny leak in head gasket it might give this miss. What you guys are think on this? I need to confirm this before I open the engine. Model Honda Ek3 V tec auto Fully efi tune up done replaced the petrol filter as well. Fuel consumption is ok
  20. does this model comes with hill start assistant? why u r worrying about this aqua this much? non of the automobile manufactures still couldn't make any model of vehicle which can run with out any single fault. if you visit to any reputed plc you can c lot of merc,bimmers,volvos are under repair for certain fauilts the subject was very similar to when ppl start to use auto vehicles. haven't heard anything bad on aqua as most recommend it as a good hybrid than others..
  21. yeah can recommend willies for you as well for any repair.that plc is very busy & its better if u can make a prior appointment. only problem for me is to go there is up & down 50km @ Schiffer yep you're correct bro..
  22. Oop's my bad.i did a tune up from him few months back on my ek but i feel good on that. true he is good on hondas not for others.
  23. yep honda priyantha.
