What Is The Best Road From Kandy To Balangoda
Guys,
What is the best road to go Balangoda from Kandy at the moment. (Best = no ongoing road work + minimum pot holes).
Thanks...
Recently I took the road from Kandy -> Kegalle -> Ruwanwella -> Avissawella -> Ratnapura -> Pelmadulla -> Balangoda. That time road was so pretty bad from Kegalle to Avissawella as the road constructions were going on. Do not really know the current situation of that route.
There is another route which u can take from Gampola, Nawalapitiya, Ginigathhena, Hatton -> Balangoda, but I have never tired that.
Kandy > Hatton > Ginigathhena > Kithulgala > Balangodaroad can recomend you. i used it in january.
also you can use kandy > colombo road warakapola > Ruwanwella > avissawella road as well
Kandy Avissawella road via Kegalle is pretty bad to drive few months back. dont know how it is now.
  • Author
Thanks guys.. Google maps suggested via Hatton road. Wanted some feedback from someone went through that road :)
try hatton balangoda road through bogawanthalawa.. you will never regret...the hatton- bogawanthalawa road is 60% good in shape..typical estate road.. and then the bogawanthalawa - balangoda road..road condition 90% good...I would say its the best scenic road i have traveled in sri lanka ..you will need around 2hrs to travel the 40 kms ..
caution - always be alert on bends when there is an oncoming vehicle..specially buses..
Edited by TheClutch
Kandy - Awissawella road was in very bad shapre due to slow constructions work. Better avoid it.
Next best option is Hatton - Ginigathhenda road. However there are lot of bends and climbs. Trip will be slower but roads are fine.
Final option is Going to Warakapola (Pasyala Juction) Atthanagalla, Hanwella, and Highlevel road, then go to Awissawella.
  • Author
What about Kandy > Gampola > Nuwara Eliya > Haputale > Balangoda ? Given most are A grade roads ??
