hrm
Everything posted by hrm
  1. Great information. Can you please put some cost breakdown for major parts that got replaced + labor if possible ?
  2. You could consider 1300cc Vitz for that budget.
  3. I thought Allion 260 came with one grade at least in SL. Never seen a basic one. Key start, normal AC are the only differences? (for 1500cc variant)
  4. hrm replied to AMI0755's topic in General Automotive
    Well. A-Star has a proper conventional auto gear box sourced from Japan. It won't do so much on fuel in city like other Indian cars for the same reason.
  5. No offense but using this would be a disaster for Premio 260. I think you have to use genuine Toyota CVT TC. For models starting from 2013 on wards it is CVT FE. Better to call T*Lanka and get it confirmed.
  6. If this is your very first car I would suggest going for a bit newer one like Viva Elite. No doubt that FB15,110, BJ5Ps are good daily runners but still you might need to do some occasional garage trips due to their age and wear-out. (That's how I started btw).
  7. As I know from 2010 on wards Allion/Premio has it at least as an option. Even Vitz has this since 2005 if you buy an ILL grade car.
  8. hrm replied to Nisan's topic in General Automotive
    About plastic sump, A*W claims the car has GC of 180mm so it won't be a problem. But owners have pointed that this GC reduces significantly when the car is loaded with 4 people.
  9. hrm replied to MADZ's topic in The Lounge
    I knew you will be worried after seeing this
  10. hrm replied to TBN86's topic in Feedback & Suggestions
    Allion is a compact sedan and Belta is sub-compact. Commonly sub compact sedans are made by extending their hatch back variant where as compact sedans are purposely built. For OP, similar alternatives would be Lancer Ex, Civic FD, Mazda 3 etc.
  11. hrm replied to MADZ's topic in The Lounge
    Any idea how this happened?
  12. We had a similar issue in our old Nissan cab sometime ago. There I can start it normally when engine is cold but could not start if it's warm. Only a click sound come and has to wait for engine to cool down a bit to start. It was traced to solenoid too.
  13. Yes. I've watched a lot of Australian crime documentaries and according to them you can easily rent and transport a dead body in a Ute to a dump site perhaps. Less suspicious. In would prefer Mitsubishi pickup trucks and I think they are little bit cheaper than Toyotas.
  14. Found these in an online forum saying one of them causes to indicate the P shift light. I suggest you to check the simple things first like the 12v battery.
  15. It depends on the car model too. Mine being a 1300cc idles at 600-650 and it is mentioned in a sticker pasted inside the engine bay. Earlier had an Alto K10 that idled around 900.
  16. CVTs doesn't have a strong creeping function like normal autos and in the morning this is very noticeable. After CVT oil warms up this would go away just as you mentioned. But usually you don't have to push that hard to get it going after start. I don't know what's the recommended CVT oil for your model but putting the correct oil is very important for CVTs.
  17. I think the car is a CVT. Have you changed CVT oil? At this mileage it is very due.
  18. You might need to overhaul your suspension system. Unless you have excessive engine oil burn,white/blue smoke issues you do not need to overhaul the engine. Do an engine tuneup as Rumesh mentioned if there's a need.
  19. You said it can happen anywhere and obvious that they didn't do it willingly. I don't see anything wrong mentioning it as they did some good deed afterwards. It's up to you anyways ....
  20. Was the service place Dr*ve and Sh*ne by any chance?
  21. That's correct but mileage could be altered at any time right? I had seen cars in car sales that were driven less than 20K in odo but engine is so much worn out that they burn oil like hell.
  22. What do you mean by broke down? Engine stalled or gear box failed with warning? To fail a gear box car should have driven alot (in Japan perhaps) or maintenance should be very bad like wrong ATF used. Do you guys absolutely sure about that gear box has failed indeed?
  23. Check whether the compressor is the correct type for your car. It should be a variable load compressor (Denso) I believe. Can you hear click sound when compressor engage/disengage?
  24. hrm replied to MADZ's topic in The Lounge
    I think so but could be anything. Car following the alto would have seen the whole thing.
