67Dodge
Everything posted by 67Dodge
  1. the center section after machining the inner & outer Dia to fit my 8-lug hub. pic isnt as clear as i would have liked. this step, was ~3k, Metal was scrap 8mm mild steel plate, so no cost. will grind it & clean it up later.
  2. ok 2nd try, my starting point is this, 8"x15" donor rims which im hoping to turn into 10"x15" splitting the rim & removing the center section more pics on the welded sections later. as for cost, my target is to do the entire thing for less than 20k. This step was ~5k, keep in mind the donor rims were free.
  3. ok, my net is too slow to upload pics, will do later.
  4. thought of adding some pics of the prgress so far. these were the donor rims, 15"x8", only two pictured. on the lathe getting sectioned & bored out.<p>
  5. thought of adding some pics of the prgress so far. these were the donor rims, 15"x8", only two pictured. <p>
  6. thought of adding some pics of the prgress so far. these were the donor rims, 15"x8", only two pictured. on the lathe getting sectioned & bored out.<p>
  7. i started on the project over the weekend, lets see how it turns out. i will add pics on the progress.
  8. thanks for the info Sylvi, no im not looking into this as a business venture. getting a TIG/MIG unit just for this as a DIY project is also not feasable. im looking at the possibility of carefully ARC welding the rims instead. balancing can be done after the work is completed. its the weld strength & penetraton that im worried about. also im pretty sure i may need to do a dye penetrant test just for peace of mind. still, its looking more & more like a worthwhile project for someone with unused steels rims around.
  9. Hi guys, Has anyone tried their hand at banded steel wheels? DIY or otherwise? all ive heard are rumors of a rumor that ppl here have done it & i would like to know more info before i jump in on a project like this.
  10. as far as informative replies go, urs is top-notch!
  11. ive got a link that may interest you. [http://www.gizmag.co...gasoline/12484/] its not exactly in ur line of experimenting strictly speaking, but u may be interested in it as it drastically improves efficiency of an existing diesel(at least for older eng's). Kudos for sticking it out in less than friendly/supportive environs. however, from what i gather on homemade bio-diesel production, there is more to it than just straining it & mixing it. there was one episode on powerblocktv - xtreme4x4 where they setup a complete unit with detailed step-by-step explanations of its operation. http://www.powerblocktv.com/player/show_player.php?ep_num=XT2008-13&ep_show=XT. gotta agree with the points made by others on comerciall viability though, everything boils down to economies of scale. best -o-luck!
  12. warlord, i had a look at the exact name & location of it, when coming from colombo to negombo side, past the paliyagoda roundabout, the ABANS auto is the closest landmak building before it (actually it is adjoining it, with all the chinese trucks outside on display). the yard is called "Nawaloka Construction Co, & Central Yard"(Land side). ill post up any more models i identify while passing if possible.
  13. im not a bike guy per-se, but i am fond of a few large displecement models. the Q i always wonder when i read something like this is, why dont our guys simply turbo or supercharge the engine on a legal 250cc bike??
  14. Hi guys, ive just recently seen a pretty large collection of cars in a nawaloka yard adjoining the Negombo road just passed paliyagoda roundabout. its a high walled yard, i only saw the cars b'cause i was traveling in a pretty tall A/C bus at the time. i only ID'd two cars, a black XJ & what looks like a Willys CJ-2A. anybody know anymore info on what the other cars might be?
  15. 67Dodge replied to Watchman's topic in General
    Just meant the cheapest Petrol & not the higher octane rated stuff. No disrespect meant to the Abnormal pump gas though! never know when they will pop up again,
  16. 67Dodge replied to Watchman's topic in General
    Vehicle : Mazda Tribute 2001 Transmission Type : Automatic Engine Capacity : 2000cc Fuel : normal pump gas Km per Ltr, City : 6 Long Distance : 10 (E01 run with hypermilling) Vehicle : Honda Civic Hybrid FD3 Transmission Type : CVT Engine Capacity : 1300cc + IMA Fuel : normal pump gas Km per Ltr, City : 11 Long Distance : 16/17'ish
  17. @ MD, dont know if you've heard about this website, but check out its vids. it gives the kind of real world info/tips/methods that are helpful to any build project. http://www.powerblocktv.com/ Its xtreme4x4 vids were real informative & helped me out alot. helps also if you got a fast net con.
  18. 67Dodge replied to KaluZ's topic in General Automotive
    this would be an intersting alternative. this weeks hitad had a guy who was selling an entire lancer body he had brought down. knowing the right process/Authority to go to would be really helpfull.
  19. Any idea on the history of these cars? pretty amazing that we had american muscle lovers back in the day who went through the trouble to bring it down.
  20. are you sure its pebbles? ie- not metalic particles?? forgetting the said particles, i dont see how engine oil could spit out of the exhaust. if you ingested them via the air intake, (assuming it punched thru the filter element), cylinder scoring could explain the engine oil, but that will give a tell tale sign of smokey exhaust. was the oil burnt? ur does it look dipped/coated? if so it could be a practical joke like Jdnet said.
  21. for those who are really interested in following this tech, a news snippet of interest by FOX news,
  22. read my 1st post again,... slowly this time..... you dont understand the concept with which FE is to be gained as described. the heat is simply a catalyst which breaks longer chains & then recombines/restructures the same molecules into a smaller chain. ever heard of catalytic reactions? happens everyday in any crude oil refinery. this process is said to simply increase yield of smaller chain HC's just google "thermodynamics of cracking".... "Turn diesel into petrol" ??? thats your understanding/analogy of this? jeez, small wonder your not accusing me of Alchemy!!
  23. have a look at the link below, its basically a discussion on "Smokey Yunicks Vapor engine" . particularly of interest to me was the 5th comment from the last.... where the poster, (possibly srilankan?) makes mention of a local angle. That really shocked me. http://www.eng-tips.com/viewthread.cfm?qid=78116
  24. wow!,... i dont believe in turning the right cheek, so, my turn,... your post is unbelievably scathing, im fine with objective criticism but i cant help but think what i did to deserve such a personal attack. i had hoped for a constructive dialog when i opened this thread. but that it seems, was my mistake. listen up chan5 & listen good, dont even pretend to know me, my education, my interests & what Ive done, you dumb ignorant sh*t.
  25. thats a misconception right there i think. its not so much a carb modification as a modification of the fuel before it is metered into the carb. just have a look online for the boiling point of gasoline. chances are you will get not a single point, but a range. this is due to its mixed nature of hydrocarbon chains, some need lower energy to burn, others need a higher energy to burn. all of us know that LPG burns cleaner & as a result e engines run smoother right? thats cuz its a small chain Hydrocarbon. cracking the fuel using HEAT or by a Catalyst is a documented process of creating methane & other natural gasses. IE:- we break GASOLINE --->> METHANE & Natural Gasses (Small chain HC) i added HHO into the mix cuz that proccess releases H2 gas, which is also an aid in Fuel Cracking. comon guys, im not really talking alien science here,... just plain fact. is it the Abhorence to any topic on fuel efficeincy on this forum that is the reason for the snubb? heres a link for those who are open minded, ive got plenty of em btw! http://www.hhoforums.com/showthread.php?t=6594
