Everything posted by udayap
- Gps Navigation System ?
Sun Roof Issue Kia Sorento 2013
One of my friend had a very bad experience with KIA agents as they entertain, repairs under warranty "only on Tuesday". He went to agents all the way from Kandy for a minor repair and they refused to attend to it since it was a Monday. Be careful with these people.....
Drive Belt
Hi All, Sudden failure of drive belt (breakage) would be a very unpleasant experience especially in a mid of a long drive. Same happened to one of my relative during his visit to my home. However, he managed to come to the destination since this occured just 3 km away from the destination. Guys: What are they symptoms of failing drive belt (the drive belt concerned has done 58000 km (kyron), without a a significant belt noise, cracks - not checked in the last service) Is there a time interval for replacing the belt If somebody experience a drive belt failure at a very crucial situation, is it good to drive the vehicle keeping eye on the vehicle temp-gauge. regards
Vitz - Engine Check Light On
Finally it turned out to be a loose connection of the wiring. After 1 day of tedious work at the garage the problem was fixed.
Korean Car News
Since Korean Vehicles are gaining their popularity nowadays, why not some updates on korean cars -Face-lifted Korando C
Cant' be because the ECU is located near to the engine (not under the dash board!!)
I doubt that a sensor would be the culprit. Because, once the charged battery was fixed the engine check light disappeared (but other symptoms remained the same). But, after a short drive the battery got drained again and engined check light popped up again. Anyways, i'll update you once the problem is solved.
One of my friend's Vitz NSP130 (done 6000 km only) started to give engine check warning just two days back. With that following symptoms came up 1. Could not move the gear lever without pressing the lock release button 2. Reverse lights did not light up when the gear lever in R position 3. Today the battery warning light came up and subsequently the battery got fully drained (could not start the car). Now, we gonna fully charge the battery and expecting to bring the car to the agent. Hope, it will work, otherwise need to tow the vehicle to the agent. We are not dare to seek the help of "Maka-Base" to make things worst!!!! Guys,,, what has happened here. Similar experiences!!!! Only modification done was fixing a reverse camera few months ago. Just bit suspicious that these guys might have messed up the wiring system. we are bit surprised about this problem occurred in a very new car...
Where Can I Buy A Car Inverter
I do agree with you. Problem is Galaxy Tab does not support the 12V --> 5V USB adopters available in the market. That is why i thought to plug in the Tablet AC adapter to the Inverter..
Yep, this is an eyewashing term for a square wave....
Guys, Just thought of waking up this old thread to clear up my doubts. I purchased a car inverter (12 to 240 V ) very recently (Cheaper one for 4000.00 rs). The manual says that it gives a modified sine wave and after going through the net, I found that such modified sine wave could damage sensitive electronics like Switched mode power supplies. After the purchase, I have used it for charging my phone without an issue. Now i want to use the same for charging a TAB but bit afraid to do so, after going through the net. Guys, have you got any experiences with the the use of invertors.. regards
Micro Rexton
I have been using a ssangyong for one year now. Nothing to complain. Cheap to maintain since spares such as air/oil filters are pretty cheap compared to Japanese vehicles.
Buying a new smartphone
Guys, This is just FYI. I got a broken screen of my galaxy s duos (6 months old). Though, i could not get the advantage of the warranty, the company charged me 6500.00 Rs to replace the screen. But, in the same time they made the warranty void since i dropped the phone. I think this is a rubbish policy of J__ K____ to get rid of their responsibilities on a product that they sold.
Car Black Box
Guys, I just want to know that whether Car black boxes (such below) are available in Sri Lanka and what would be the price. I am in a short trip to europe and just wondering its worth to buy the below for rs. 23000 http://www.mediamarkt.de/mcs/product/ROLLEI-Autokamera-DVR-110-Car-Black-Box,48353,286663,589159.html?langId=-3
Engines With Dpd Or Dpf - Which Engine Oil To Use ?
seems they haven't removed the DPF but only the sensors. I am in contact with them to sort this out.
- 54 replies
- Navara
- Engine Oil
- CJ-4
- DPF
Fixzit, Actually what they are doing is conversion of euro5 to euro3. I got it done with last service. After the conversion I inspected the vehicle and found that they have removed all the sensors from the DPF (temperature and pressure) and have done ECU update (still the DPF is there). When I inquired about it, they also confirmed that they did so. Now, since there are no sensors attached to the PDF, the regeneration will not happen and also the ECU will not identify the level of sooth collection in side the DPF. I am wondering, will this lead to unnecessary problem (engine failiar due to DPF blockage) Actually, what has the AGENT done in this euro5-euro3 conversion.?. Its a puzzle to me!!!!
- 54 replies
- Navara
- Engine Oil
- CJ-4
- DPF
Micro Rexton 270 Xdi
Recently, I came across a (in H*t A**) garage specially doing repairs of ssangyong vehicles . Why don't you try that place.
Stuff You Put In Your Car? (Fuel + Engine Oil)
Done, I hope this will not lead to an increase of the price of super diesel
- How Do I Use "shift Lock" - Suzuki Swift
- Engines With Dpd Or Dpf - Which Engine Oil To Use ?
Thanks, So i decided to get the DPF of my vehicle cleared through the Agents , they do it for the vehicles they sold those came with a DPF. interesting article: http://www.dieselnet.com/news/2013/01epa.php
- 54 replies
- Navara
- Engine Oil
- CJ-4
- DPF
Glad to know that you got that Dpf removed. it would be helpful if you could share your experiences on vehicle performance, fuel consumption, emission test results after the removal of the DPF.
- 54 replies
- Navara
- Engine Oil
- CJ-4
- DPF
How To Use Sim Card Slot In A Pc
Thanks all, This is brand new notebook. As crosswind stated, it seems that i need to add a HSDPA card to use this facility. As Kirala pointed out, the web information motivated me to search about this non-existent facility. Probably, web information give high-end specs. thanks all
Hello all, I cam across an availability of a sim card slot in my notebook. Is it meant to be support as a HSDPA modem?. There is no software pre-installed to use it as a HSDPA modem!!!!!. Guys have you ever used this facility. if so, what is the software i should use. My note book model is "Dell Latitude E6430 ATG".
