harshansenadhir
  1. any ordinary diesel filter would have this. Only challenge you would have is sourcing a 24V one.
  2. Looks like there's no issue to worry. Did you also check whether fan operates even after the engine switched off? ditto Don. It's always a good practice to run the engine without cutting off all of a sudden. Not a must for a non-turbo though
  3. regardless of the coolant temperature, fan would kick in the moment you switch on A/C and then will increase speed as temperature and pressure of refrigerant. 307 has single auxiliary fan. Hope this helped
  4. Peugeot 307 has an inherited heating issue, specially in our kind of driving and climate conditions. Almost all of the 307s I've seen and experienced had temp gauge hovering between 90 to 100 and if it doesn't go beyond 100, they consider it to be "normal" ! having said that, your issue of temp gauge going beyond 100 after the car is stopped is anyway happens as there's no water flow and water trapped in the area of temperature sender (one of two sensors in some models, i think the blue color one or in some models it's just one green color sensor) gets heated. However, the moment you start the car, it'll drop a little and fans should kick in at high speed. Reason is water trapped in radiator core gets a bit cooler and they gets into the water circulation means overall temperature will drop. few points to note 1. Does your fan keep running even after you switch off the engine? if yes, it's an indication of some abnormal condition and therefore ECU / Fan control module decides to keep the fans switched on for 5 more minutes or so. 2. To test the fans and high speed, start the engine, preferably from a cold start and keep the cap of the expansion chamber (water bottle like thing in 307) open and fill with coolant up to the mark. then let the engine get heated up till 90+ and make a note at which point the fan kicks in. Coolant level will rise and start overflow just before fan kicks in. As the fan operates, the coolant level drops. let it run for a while and again fan will stop. Again coolant level will rise and start overflowing before the fan kicks in and will drop when the fan operates. refill up to the mark and close the cap. When closing the cap, tighten it to the max and then turn 1/4 circle towards loosening side and leave. Tell us your observation in this. 2.1 at which point the fan kicks in (reading on the temp gauge, make sure to get the reading while you're on driving seat, if you look at it from outside, you won't get the correct reading (good if you can hook her up with Peugeot Planet to get the most accurate reading). If it starts at 92 (slightly passing 90 mark) means your temp sender and fan control module aren't faulty. However, let us know. 2.2. do you see water boiling and splashing up before the fan kicks in ? or just smoothly overflowing and gradually goes down as fan starts operating ? if it's boiling and splashing up, before the fan kicks in isn't a good sign. may be there's a clog in your water channels including radiator, blocked thermostat or blown head gasket to be the worst. to test the fan high speed, when the car is started, remove the green color temp socket. Fan should kick in at highest speed and warning should come engine temperature too high. If it operates in normal speed, either the high speed relay or fan resistance (fan speed control mechanism in 307) is faulty.
  5. quality of leather interior and options package offered compared to the brand new import isn't the same
  6. I'd say better go for a manual. That way you can get 12kmpl or even more if you're not a heavy footer on accelerator. Nice comfy car in it's class. Try to get into a second generation brand new import, avoiding English and Singapore imports.
  7. Issue with duplicate CR went into a different magnitude due to assembling of cut & bud vehicles with fake registration. lot of people ran into problems after buying one with duplicate CR coz the one with original CR was running somewhere else. Since RMV taking time to transfer vehicles with duplicate CR books, finance companies could not provide financial facilities in one day. We cannot blame car buyers as their perception was based on experience, it's not baseless entirely. It's the stupid system, which cannot recognize a forged CR from an original
  8. It isn't normal, It could be due to a little layer of rust (ferrous oxide) foaming (due to moisture gets in after exposing to rain water) on internal parts of the locking mechanism. Try spraying WD40 through the opening of the key insert. as for the drainage veins, if those are blocked, you can find water on floor boards as doors are not water tight.
  9. if its for chrome or any metal paint work I highly recommend Jayadan Electro plate. They're around Wattala area. 717757547
  10. Filling this pressurized struts/dampers is very tricky and this small tube contains about 20 atms of pressure. i remember, once my self and an uncle who's a mechanic, tried to give it a try without knowing, with what we were messing. It was a worn out strut/damper which wasn't holding the tail gate and we only could drill a hole on tube halfway. Next we heard a loud bang, like a firing sound of a rifle and a smoke of pressurized gas released in a fraction of a second. I doubt this can be pressurized, though shock absorbers are being done. Different between shocks and these struts/dampers is dampers always try to extract push the shaft out with highly pressurized gas where as in shock absorber moderately pressurized gas cartridge controls the movement of the shaft. Best would be to roam around delkanda then panchikawatta and give it try.
  11. I didn't have a SB13 but have plenty of driving experience of a manual one. once we filled her up from kottawa and went to kataragama with floored throttle on galle road. returned via udawalawa, rathnapura road, ended up in Kottawa with 1/4 tank left. I think it did around 17kmpl with AC and 4 adults, luggage on board. generally autoboxes of that generation doesn't do well on fuel as torque converters didn't have lock up function. So engine revs higher almost all the time.
  12. thie made me to remember the face of the driver in a KK plate red Allion who desperately tried, to tail gate the 407, let alone overtaking. Sigh, i can understand feeling of being outsmarted by a diesel wagon
  13. I almost replied "count me in"
  14. if it was stressed slow cranking, there's a higher probability that engine was over stressed / heated. Check your water level both in radiator and expansion tank. Plus check the oil level as well. Did you notice any unusual reading of the heat gauge ? also check for operation of auxiliary fans as well.
  15. whilst you're at the diagnosing of fuel feed related issues, also look for any coolant losses and signs of overheating. How was the engine response when you were cracking after it stalled? was it a free cranking or stressed slow cranking ?
  16. most probably the culprit is the clutch mechanism. If it's a cable clutch, yes you can adjust it, check the ratcheting point whether the outer holds on to mounting/fixing points without moving here and there. if it's hydraulic, then you have to check both master and slave pumps for leakages plus the pedal mechanism (to see whether the pedal pushes master pump sufficiently) and the rod between the slave and the clutch fork (to see whether the rod pushes the clutch fork enough to disengage the clutch) if all of above are ok, then there are other possibilities such as 1. issue with the clutch fork and release bearing so that it doesn't push the pressure plate enough 2. aged pressure plate 3. hubs and synchronisers are troublesome.
  17. first get a wheel alignment done and see whether this can be rectified by adjusting rack end lengths. If it fails, inspect the rack to see whether rack is mis aligned due to some reason. If not most probable cause is, someone adjusted the center position of the steering rack during a repair. usually the teething of the rack wears out fast from the center position, therefore as a remedy mechanics do shift the center postion of the rack by couple of teeth and adjust the rack ends accordingly.
  18. agree with Watchman of all points except this. Newer cars equipped with variable load compressors where they load the compressor (hence engine) depending on the demand from the system. So technically speaking, in such systems, setting higher temp and lower fan speed will create less demand on compressor and saves fuel.
  19. Ditto that. I think the same when it comes to Peugeots.. glad that it's nowhere to be seen in this so called list.
  20. congrats on your purchase and from the face of it and pictures, it looks like a good car. i don't think you should transplant the engine and gearbox with something else and i doubt it'll justify the cost and the effort. Rather you can get this into good condition using original setup. It all takes to find a good competent mechanic who knows Peugeots of this generation. There's a good mechanic in Piliyandala area, unfortunately I don't have any contacts or known garages in your area. Probably give him a call and try to understand what exactly the issues your car has. For spare parts, this post on forum won't help much, but if you happen to call around following places in Panchikawatta name and contact detail of mechanic : Mr. Navarathne 716 899 882 Subasinghe motors 112 449 604 Dharshana motors 112 438 748 as for paint and tinkering, there are mobile tinkers and painters but their quality is a question. I've been there done that and learnt a bitter lesson.You won't regret if you get a quality job done from a decent garage.
  21. for sure the 4WD gear knob was replaced by a normal one
  22. yes the bill jumped up by that amount as we have an incremental charging slabs. What marketing guys have done was, calculating the total number of units to charge the car for a month and multiplied by just the unit price. But in the real picture, these units would be added on top of your current household electricity bill. That's why it's highly impractical to charge these cars from the household electricity unless otherwise you have an alternative power source such as solar pannels. on my diesels, one is a van which runs back and forth to school to drop/pickup kids and the other (1.7 ton (1635kg) 407 SW HDi with 2.0 ltr intercooled turbo) is crying for super diesel and only does about 7kmpl in city limit. well said Rumesh!
  23. Charades are known for it's ultra superior fuel consumption which sometimes un believable. I remember seeing a version with an electric turbo charger and I doubt it's a slow car either. However, finding one with proper body shape and less cataloy is very difficult. Another disadvantage is 3 cylinder engine wears out while you stare at it..
  24. it could be as simple as badly worn out tire or tires. best is to isolate which tire has the noise and check with a different tire (i.e spare wheel ) to see whethe the noise disappears. Then you can get into other diagnosis such as checking hub bearings. Most probably this should be from rear wheels.
