Warning About An Agent And Some Advice
They have a better performing brand with tempting volumes so they must be too busy to focus on other brands same is the story with Nissan agents as I heard.
Converted To Diesel
converting should be possible unless otherwise there has been a regulatory change. There's no issue in the current reg number you have. However, existing number determines what would be your new number. You got this feedback from RMV or just here-say?
Answering both Sifaan and Ripper: So far it wasn't useful or worked. Went to the extend of writing to mother company (not Mazda ) but nothing seemed to have changed, but we must continue to do it. When the management does not treat employees well and care about sustainability, customer satisfaction and brand development, results of this nature would be expected.
Accelerating Issue
oiling the cable and related moving parts should solve this 'issue'
Daylight Extortion By The Traffice Police
This should be escalated to IGP and at the same time all who got copped should avoid taking a spot fine ticket (if you do so, you can't challenge it in the courts) wait till they file the case and defend it. With the number of witnesses the group has this should be a piece of cake for an experienced traffic lawyer. However, I understand there's a bit of time wasting here but someone has to protest this as it's a sign of bad, indeed very bad system around the corner. As motorists we are abide to follow orders of a traffic cop, so if he asks to proceed/continue to drive, we have to, unless otherwise it's heading to a collision. This is the email address published to send complains across. Make sure it goes with the proper timing of the incident, location, from which police station they were and were there rankers/officers or just cops and the names. Officers should have the name tag and cops should have the numbers. [email protected]
Thanks for sharing this and knew this fact for a long time and never had any experience with a Mazda at them though. These two brands are suffering in Sri Lanka thanks to them. It's my personal opinion but I'm sure there are many who would agree on that. They're very very famous for asking to replace everything. Peugeot 406 2ltr engines develop a similar random miss and it could be one of injector rail, ECU, ignition coil pack or the fuel pump. If a customer get there with this issue, they propose to change everything I've mentioned above. Same happened to jd it seems. I pray that these dealerships will get transferred to either a different company or different management who believes in sustaining long term business relationships, customer satisfaction and branding rather than making a quick buck and bugger off.
Happy Birthday Jdnet
belated b'day wishes man.. hope you had a good one.
Undercarriage Washing
Spot on about harming rubber boots and parts. Further, I have never washed the engine nor under carriage of my 406 for more than 4 years, nothing bad happened to the car and it doesn't have any corrosions. Only replaced the links and suspension parts about 3 years back and though they say links fails frequently that didn't happen on mine, probably last long due to no oil and kerosene ?
Happy B'day Peri
Many happy returns of the day Peri.. Have a good one
Magcity Service Sucks
went to Kandy Tire House, close to Punchi-Borella to replace the tires of 406. Took the elder fella with me on the day so had to stay away from the vehicle merely for about 5 minutes, just to rock the fella as he started crying. Came back to the vehicle and saw the bonnet hasn't closed properly and thought I forgot to close it properly and pushed it down to see it was close properly and locked but it was looked like popped out. Later realized some jack a$$ jacked the car or tried jack it up from the cross member found beneath the radiator. In 406, this mount aint that solid and shouldn't suppose to use to jack the vehicle up. Entire radiator panel lifted up causing the bonnet locks to lift. Not to mention the slight damage to the condenser and one radiator fan was squeezed on to the lifted radiator panel and it gave up working. Made a scene there and took the vehicle back to them on the next immediate working day and got it fixed under supervision of the guy who usually repairs my car. Knew them bad and experienced their ill work and diagnosis sometimes back, but never ever thought they could be that bad. A supervisor fellow had a chat with me while they were fixing the car (glad they accepted the fault though none of mechanics were ready to accept that it was their mistake) and told me they've done the same to one of 406s belongs to a minister and ended up replacing the radiator and spending about 39k from their goodwill budget. P.S - Sorry, I couldn't mention that Kandy Tire House, Mag Wheels(??)next to it and Mr.Paint in the same group? Yes, I was referring to the place almost in-front of acquinas borella.
New Headlight Law Xenon / Hid Lights??
count me in.. the second one I obtained is now almost white after using for one and a half years despite I laminated the damn thing the same day I got it.
Indicator Lights
not intending to take this any further on OT. I was replying in general context there are indicator lights which changes color and comes in different colors depending on the severity, only quoted an example. Jeez
Lighting Problem After Insgtalling Leds In The Speedometer
That's exactly the issue with LEDs since they're light is pointed, explained the same thing in thisthread. Did some searching around sometimes back when I thought I'd go for LED's and after much effort gave up the idea. Solution gave up was fixing many LED's to the back panel of the meter cluster as it covers the entire cluster evenly where there's no dark spots and ultra bright spots. BTW what type of LEDs you tried? with on LED on each bulb or many LEDs on the same bulb, say at least 3 fixed to different directions?
Restoring Dashboard Meterset For Dx Wagon
LED bulbs will merely help improving the visibility of the meter panel as meter panel lighting requires a light source which spreads the light around. LED light is pointed towards one direction rather than spreading, so you'll have few bright spots than making the entire cluster bright. That is if you go by the original bulb positions. Assuming the only change you have done was changing bulbs, I suggest you better do following .. 1. Split open the meter cluster and clean up the reflectors and transparent plastic components which carries the light around. 2. clean the contact points of the meter cluster and bulb fixing points to the cluster. However, if the circuit diagram like wiring lines found on the meter cluster are worn out and doesn't pass the current to some bulbs (check this whether all bulbs are lighting up when you switch on the parking lights) If so, solder a new set of wires from the meter cluster connecting points to the bulbs which are meant to light up the cluster. I have done this to one of 504's I had and results were superb. You have to be very cautious to identify feed lines for these bulbs and is there any other indicator/gauge which gets power from the same feed line. If you're not sure of how to do this, obtain some professional help, preferably from an auto electrician. 3. If this gives some improvements, try to fix a silver/chrome color sticker on the inside of the meter cluster back panel which will further improve the light towards the facia panel by reflecting. Will further elaborate with a diagram if I get some free time. Hope this helps.
Flashing Abs And Hand Break Indicator
Why don't you check the ABS sensor connector of the wheel went into that gaping hole ? Chances are high that impact might've loosen the connection and it doesn't send the signals to the ABS 'computer'. If it doesn't get a signal from at least one wheel, it won't activate ABS.
Indicator Lights
just wrong. In fact there are indicator lights which change color to indicate different conditions. Simplest example I can quote is Glow indicator of Mitsubishi Pajero/Montero. During heating up it lit in amber color and changes to green once pre-heating is done.
Shock Conversion
That's best if you care to stretch your budgets a bit, rewarding throughout a time though.
Toyota Axio And Allion
two thumbs up for that.. Wondering why people dumping helluva lot of money on these .. leave the new/unreg ones out, a used 97 110 at close to 2 mil, how about that.
Shock Conversion
+ 1 , it'll make the ride rigid and bumpy. Try to keep the leaf springs straight or in the original shape and increase the height from the shackle. Further, replace rubber bushes found on the shackles with grease-able ones with grease nipples. Makes the ride extremely comfortable.
Break Light Not Working Properly
your park lights (rear) having a loosen up earth (-ve in Japanese cars) connection.
Lancer Cs1 Rpm Over 2.5 @ 70Kmph
first of all get the clutch checked, try releasing the clutch in 1st or 2nd gear with handbrake on and see whether engine stalls or keeps up. If it keeps up, chances are high that the clutch is worn out. Remember, this test might further weaken an already worn out/weak clutch, so do it or get it done from a mechanic when you're really ready for the repair. If the clutch is cable operated, you can adjust the tentioning knob usually found on the engine room side of the firewall where clutch cable entering into the cabin. If not final mounting place of the cable on the gearbox or where it connects to the clutch fork shaft. If it's hydraulic, you can adjust the shaft which pushes the clutch fork. If you're lucky, you can escape by adjusting or replacing just the clutch plate, if not entire clutch kit (pressure plate, clutch plate and release bearing) should go in.
Whats The Option
few members here gave the answer already. Not that it's suitable, but only can be used with/for an auto box. In manual, you should have all three buttons with you, registered in your brain
I assume it's a manual since you specifically mentioned it's on 4th gear (correct me if I'm wrong) If it's a manual, only one way is there to develop a significant difference between the rpm and speed (what shows on speedometer) that is worn out/slipping clutch. If it's an autobox there can be various reasons/issues varying from over used gearbox oil to worn out friction plates and not changing to O/D or appropriate gear,due to malfunctioning valve body.
Find A Month Of Manufacture
That's correct, provided that the windscreen is the original one fitted from factory.
325-**** No
adding few points to clarify certain misunderstandings. 325 is given for petrol to diesel conversions and registering of non-registered (but locally used by armed forces specifically)auction vehicles. Non used auction vehicles (customs auctions, etc) will be given the running series number. 325 is no longer issued for conversions and fuel type will be printed on the plate with existing reg number. eg:- 18DXXXX. FZ - is used only for re-registering 98-XXXX and DP-XXXX plates. Now they're issuing plates for diplomat vehicles with DP instead of the province code and with the running number ex:- DPKF-XXXX. In case of a transfer to a civilian it will be changed to the relevant province code and the same number will continue.
