Import Tax Slashed By 50%
hope everyone heard Kabral says this will remain unchanged for sometime. Are we to believe or still continue to refrain from purchasing a vehicle from elsewhere and to see taxes sky rocketed once it's landed.
Tune Up For Fuel Economy
wrong way of looking at injector cleaning. Cleaning helps to regain the optimum pressure and pattern of the spray which will help the optimum burning of fuel since this type of pressurized spray will separate it into particles. Also what others mentioned about maintaining the optimum ratio is another reason and it further ensures what is sprayed into the combustion chamber is the same amount of fuel that ECU "asked" injectors to spray and "thinks" it did.
Mitsubishi J44 & J32
3 forward floor mounted gearbox is originally came with J3 and it was 4 forward floor board in J54/56 if I'm not mistaken. Also any floor mounted gearbox came with two lever unless some modification carried out to make it floor board. As for anything else it was steering column mounted and single lever 4wd control. Gearbox is more specific to the model, say short wheel off road versions came with floor mounted and with two levers. All other models designed to carry three passengers in front including the driver, had steering column gear lever and single lever 4WD operation. That is for the ease of the passenger in the middle. Further, almost any part of these models can be interchanged easily, that's the beauty of good old stuff
J32 is the long wheel base Petrol/Gasoline version where as J44 is the diesel variant. Someone correct me if I'm wrong. Answer for the second question is No. Being used and driven one of the very last produced specimens of J44, yet with steering column gear and 140kmph box. J56 is the one came with floor board gear and two lever operated 4WD case.
How To Get A Lease
It is possible to obtain a pledged loan by pledging the import documents. But usually leasing companies and banks provide this for reputed car importers, not for individuals. Having said that, if you can pledge another asset, then there's a chance of obtaining an asset backed loan. Just check with any leading leasing company or a bank. Present lease rates are around 3200/- per month per 100,000 for a period of 4 years and around 9,300/- for the same amount for 1 year.
exactly my point was VVTI, further this 'current' market value on their books could be lesser than the actual.
OT lol, my 28 year old 504GR had better features I honestly think they shouldn't do this. It's showing how poor specifications these cars having over Japanese and even Chinese vehicles. Being curious, I haven't seen the room lamps/door lights, parking lights and instrument panel on the spec list. may be optional, yeah
Guys, while we're debating about prices, market conditions, some companies known or famous for cheap advertising on this forum had started the same again it seems. Reported the post already.
Peugeot 406 Gear Selector Wheel
are you referring to the 3/4 synchronization hub? buying just the wheel of the synchronization hub brand new may not be an option. However, this can be taken from a used or dismantled gearbox. What's the model of the car D8 or D9 and what's the gearbox type? I'll PM a contact which might be useful.
Y This Is So Cheap ??
amen to that. Interior looks almost brand new. I'm sure this would yield more than 15000USD had it put on eeebay
wrong school the bugger had been attending to it seems Predicted this scenario would happen and contacted our insurance unit. What they said was in case of a write-off they consider sum insured, YOM and hence depreciation, then the market value. They do consider the present market value even if the vehicle is insured at previous market value. Say after depreciation value is higher than present market value as predicted, but insurance will pay the damage at present market value, which could be theoretically (on the books) lesser than the actual market value.
Dipstick
now I'm clueless. I thought the reason would be that, there's a block/obstacle in air cleaner/in-take so it tend to suck some amount of air from crack case. Why don't you give another check to see whether the air filter installed properly including intake pipes to confirm there aren't any obstacles in the air intake.
Dear Mazda Experts. Pls Help
it's not about getting the autobox checked, determine this occurred to that tune up? #1 was this issue there earlier? #2 if answer is no for #1, was your engine over-reviving in idle before the tune up? #3 if answer is no for #2, is your engine hesitates and shudder excessively after the tune up? #4 if answer is no for #3, may be someone kept the engine idle at a higher speed to overcome this issue and your tune-up guy set it to the proper speed and this issue is back. #5 answer for #3 is yes, your tune-up guy had set a lower than optimum engine speed. you have to decide whether you need to check your engine RPM first and if it's optimum then move onto fault finding of the autobox. may be another member can recommend a good autobox repair/service place around Gampaha or Colombo, not in my contacts.
Fb15 Suspension Issue.
yeah, he mentioned mounts in both sides and mounts in a suspension repair is shock mounts precisely
Dipstick
never heard this type of behaviour as usually dipstick blows air out. Check whether your air intake has any obstacles or the filter is severely blocked? or your rings are very very good and doesn't blow a single drop from compression and thus has a vacuum in crank case.
This issue could occur due to one or few of following 1. Engine is not idling at the manufacturer recommended RPM. 2. ATF pressure of the gearbox is not sufficient due to less oil volume than recommended 3. ATF pressure is not sufficient due to viscosity of the oil is reduced. 4. Issue in torque converter/propellers inside if this happens on an incline and car slowly goes downhill on D/3/2/1 positions with brake/hand brake released it could be due to worn out brake bands of the autobox. this case is more likely point no 1 to me. If yours has a RPM meter, check for idle speed, it should be somewhere between 800-1000 but again depends on the model.
I don't intend to be rude here, but hadn't this guy complained about a bumpy ride than noises? he said no noises now and changed everything in the front suspension including shock mounts, not engine mounts.
yeah, shock mounts is a b**ch if you don't know how to diagnose Yours is let's say broken mount, how about a loosen bolt which secures the front shock from the upper side? it was huge "thud" and small rattles all the time and guesses all possible things on front right hand side suspension to discover it's due to a loosen bolt. this guys problem is not noises but bumpy ride if I'm not mistaken. Learnt this lesson very expensive way about 2 years back when I replaced shocks of the 406 last time. After replacing the ride was bumpy in the sense slight hump will give a sudden jerk to see I've replaced them with GAS pressurized type where shock itself has a resistance/pressure which adds to the tension/pressure of the coil springs. however handling improved significantly and i'm now running with compromised comfort till the next shock-absorber replacement. Oil pressurized type gives you more riding comfort than handling and road holding also does not last longer like the GAS type in contrary to what we tend to believe.
What's the type of the shocks you installed? are they GAS pressurised or Oil pressurised? If it's GAS type, yes there's a chance of giving you a bumpy ride.
Hyundai Spare Parts
is it due to reliability issues or petrol to diesel conversion or just going by the popular sort of method to gain the advantage of availability of spare parts. I know very very reliable motors elsewhere are being thrown away and putting 2C and all sort of engines due to the availability of spare parts fact rather than the reliable factor.
How Take Out The Starter Motor On A Cbr?
if this is the set up definitely it'll have a lock securing the wheel as I told you in the previous reply. Something like this. So better you remove the other panel and get yourself ready for a gasket change.
demand in Sri Lanka to impact japanese auction sales of used cars? hell no. If this demand triggered from African continent I can understand but this is not significant for that market. Having said that, there are Sri Lankans who runs some of these auction sales. Imagine the rest
so all who buy an old jap considering better options, comfort, safety, better resale, less wear and tear are uneducated and you're the only or among handful of educated guys who go and buys a mighty maruti. Dude, wake up, you call lot about being practical but you yourself missing some points and may be lack of experience about sri lankan vehicle market and how it behaves. I don't wanna turn this into some maruti bashing thread. As i previously said maybe some fleets buy marutis but now that trend too has far gone. This claim is backed by the company rented out one of largest fleets in island. Recently another multinational bought helluva lot japanese altos from the same company refusing safety less 800. So the decision makers of those companies are of the majority of uneducated fools i guess. Hmmm.
no comments, let's wait and see , as you said we always can bump this thread up and see.
yeah, true for all other importers except A*W where even with economic downturn they had the best selling brand at some 70 vehicles a month(?). They too didn't have stock means something more than the factors you just mentioned, yeah?
