harshansenadhir
  1. Not at all trying to scare you . Had I really wanted, would've elaborated the added excess torque on an axis of your wheel bearing due to large tires. Just kidding, there's not much of math here but an elaboration of the tire circumference which makes the difference to the speedo.
  2. trigger happy moron you meant? quoting Grace Augustine
  3. lucky you haven't changed the rim size. Difference between 155 and 185 is added 3 centimetres from one side to the other on a cross section of the tire. 1.5 centimetre on the radius and calculate the circumference difference. Not much, yeah? However if the rim size is increased from 13 to 14 means one inch means 2.5 centimetre roughly, be it a 14X185, then total difference across a radius will be 4 centimetres and circumference difference from factory setting would be high.
  4. You will outrun factory recommendation if you change tire sizes significantly, i.e change the rim size and balloon size significantly so to speak. Repercussions of such significant change will be differences in speedo meter and odo meter readings ( larger the size of the tire, smaller the reading simply), tire will rub against inner wheel arch even for slightest pay load, reduce life time of hub bearings, factory setting brake force might not sufficient to stop the vehicle and variations in fuel efficiency. Having said that, difference you mentioned is negligible and not very significant.
  5. my gut feeling is it should be either faulty sensor or most probably loose connection at either of ends. I personaly don't know about that place but if it was me, I would've taken it to an electrician preferably an ex-stafford guy
  6. Good point mate, but the difference between said two sizes is 10mm. Not a significant size diff to worry about inner side of the mud guard.
  7. baloon size of your tire will be increased means handling will slightly improve and fuel consumption will slightly increase.
  8. Did you check by replacing your sensor with a one known to be working? Because there are guys who tell you those things are good and working just by looking at it. Also try to source a working speedo cluster and plug it in and check. This way you can isolate the issue whether it's your speedo cluster or vehicle speed sensor or wiring loom. Cluster coil is not something you can buy over the counter and replace. It's a built in component inside your speedo cluster and it has a unique resistance in order to provide accurate reading of the speed of your vehicle (that coil is what makes the speedo gauge/needle move). Someone tamper this and replace this coil does not necessarily give you the accurate speed unless otherwise you need some speed on your cluster to please you. on an important note, you said your mileage/odo meter is also not working? if so definitely there's something wrong with the vehicle speed sensor or wiring which sends the signals from sensor to meter cluster. Simply because if the cluster coil has failed, then it only should affect the speedo gauge/needle and your odo meter will keep on ticking. What I don't know is whether, EK3 has an interfacing module which takes the signal from speed sensor and convert/normalize and sends to speedo cluster. If yes, this module too need to be checked.
  9. may be, but the point is not addressed by them. That is, how the cop prove that motorist was doing 72 or above? I have following concerns, 1. is he keeping an old reading value and showing it to me without clearing it up. 2. had he kept the gun at a standstill? if the speeding gun was moving towards my vehicle, the reading would've severely manipulated. 3. if all above was correct, calibration of the speeding gun and gun should be sealed and provided to courts as reckless driving offense does not have spot fine option. So if they're taking it to courts (as per the law, it has to be) the main evidence of the offense, that is speeding has to be provided to courts by sealing the speed gun and produce as supportive evidence. If that's the case cops cannot stop more than few motorists means this does not happen. As I pointed out they twist the law and taking the upper hand.
  10. need to add one more point. That is some maka baas fellows try to increase the ground clearance of the jeeps by increasing the curve of the leaf springs. This will make the ride very much bumpy and rigid. If you ever want to increase the height of the vehicle, do it by replacing shackles with lengthy ones and keep the leaf springs at the optimum setting.
  11. this is ridiculous, twisting laws for their advantage. If its reckless driving, cop has to define why he is charging for reckless driving and prove the case in courts. What these buffoons should've done was implementing speed zones properly and give them speed guns which can take a pic of the vehicle clearly showing the speed and mandate that they have to use it on a fixed tripod or something. If i get coped, i will demand a ticket for speeding indicting the speed, or clear definition why he says i was recklessly driving. Waiting for someone, preferably a lawyer or judge to challenge this.
  12. this happens for carb models and i heard many similar stories. However this car is an efi. So chances of such thing has happened is very less. Tcs, get your car checked at a competent garage where they can diagnose your car. check the throttle positioning sensor and idle up value specifically.
  13. not much info yet to judge properly. If the engine cut of is sudden it should be one of ignition components. Ecu and entire system including fuses, harness and plugs and wires to be checked. If it gradually lacking power and stops after rough idle it's most probably the feed pump or related circuit.
  14. what are the symptoms? Does engine check light comes up before engine gives up? It could be fuel feed pump, filter, ignition coil or engine management unit to be worse. Try out the simple things first, give a throttle body clean to start.
  15. LOL, well.. reading that as lower CC capacity aint that hard when you have the silvy emulation mode switched on.
  16. not entirely correct, you have to factor the weight of the vehicle into consideration (power/weight ratio). Imagine of a 2 ton vehicle fitted with 1100 cc engine, that'll return worse mpg than to a similar vehicle with 2000cc engine.
  17. sad to hear that mate, is it the blue 406 went under a van from behind by any chance? Thats the major accident i've hear recently of a 406. Btw, what are the parts you're looking for? May be i could help out with. Drop me a pm with your contact details.
  18. very well said mate. I couldn't have told it any better. But i doubt he would understand this with his sudda biased glasses.
  19. i for once thought you're with negative thinking and an extremist of it. But now i know that it's just about lack of understanding and issues in comprehending. Dude, get your facts organised and keep yourself updated, at least about what happens in sri lanka at least in automobile industry since this is an automobile forum. There were initiatives, rather boi approvals given for start up a land rover and jag assembly plant. At least before indians buy them over. Topic starter asking what has happened to that initiative, not a stupid question like why aston martin is not assembled in sri lanka as you might'Ve understood.
  20. Even the Micro or Wasana or any other assembly lines are not comparable with the mentioned brands, it's well known truth. Read the topic again, it says assembly, not manufacturing and that is very much feasible with todays context and that's where 12 million priced Sangyong is available at 7mil range. Same will happen to Land rover if it can be assembled locally.
  21. that's where whole thing gets started. We'll see what happens to these initiatives. But as you said this thread neither died nor enthusiasm on assembling thing has not deteriorated. Mind you, assembling and manufacturing are two different things, countries like ours could afford to assembling that's how Ssangyong and some another chinese brands are being assembled here. Even the topic is based on such projects focusing on low cost labour can be found in here.
  22. well, you seriously need to wake up and look around mate. All those commodities you mentioned are being assembled here. Ever heard of Unic TV? or TVS motor cycles ? and the mentioned countries made you laugh are doing better than what we are in current economic context.
  23. you wanna do it yourself? Give it a try but be carefull not to remove a complete layer of paints. Brasso will help to remove hairline sort of small scratches. However, if those scratches are deep, you can rub the scratched area using super cut or compound. But be very carefull when using compound, better if a pro can handle it.
  24. dude, you're looking at this assembling thing from a different angle. I don't see any reason as to why a manufacturer would move into this market, knowing that, it's us, local business has to drive such projects like what upali motors did. What about assembly plants exists in countries like kenya, nigeria? What they did was buying the production plant once production life cycle of the plant has been end where principles have recovered the initial investment and surplus. Such production plants they bought in 80's manufacturing vehicles to the date. Well i don't think positive thinking alone would do everything but definitely negative thinking at your level will not do any better even at personal development
