Nissan Fb15 New Shell
interior is bit different and the biggest give away is the YOM on the seat belt
In Lithuania They Create Cars From Pu-foam
did some search around .. it's not cataloy as I guessed initially. It's more of a foam which use to make mattresses. http://en.wikipedia.org/wiki/Polyurethane also this guy got quite fame around on forums and blogs since 2008 or so. There's another sculpture made out of a beemer http://www.autoblog.com/2008/05/31/lithuan...-does-bmws-too/
no exact details than hearsay will try to locate a place from the source.
rear lights and the boot lid to be added to the list. I heard there are place and people doing this as new shell prices are way higher than the old FB15 prices. However still after the conversion there would be enough hints to identify that this is a converted new shell, so be aware that you'll only get a new look and you might not get the expected market price of a genuine new shell model
Engine Mis
not to mention some known 405's and '06 s burnt engine ecu modules at agents simply coz specially requested engine dressing regardless of warnings given by experts. Replacement costs were averaged at 200k.
Whistling Sound From Engine Bay On Kickdown
- Whistling Sound From Engine Bay On Kickdown
fairy god mother has installed a turbo while you're past asleep. out of jokes, what sort a whistling sound that is? I would rather look at any leaks/false air suction through the intake piping. Failing which i would look into belts.- Does Law About Speed Limits Valid Now?
good question whether we still want to pay a lawyer. I went through this procedure twice and both instances i appeared without a lawyer and said practically to save valuable time of honorary courts i accept that i'm guilt. Both instances i got 2500 fined. So there's no rule saying you should go with a lawyer.- A Place To Get Everything Done ?
search around this forum to gauge their level of service. At least that explains diminishing of expertise factor.- A/c For Bj 43
commonly used method is fix a hang-on type a/c unit which is 12v and wire from one battery. You would be able to source a matching used compressor either which will fix directly to your engine or will be able to fix using custom made brackets. If you fix a 12v system you'll have to change the battery which is being used for A/C once in every two months or so due to one battery being drained over the other. However having said that, if you can source an A/C cooler + blower unit of a Toyota Dyna which is 24v you will be able to use it directly on your 24v system.- Volkswagen Passat
I checked again with my mechanic, T-belt kit for Bora is said to be even lower than you've mentioned. But the same of Passat 2002 model is said to be over 65k, he further confirmed.- Volkswagen Passat
good we have an owner on board. One clarification; 20k is only for the T-belt or the T-belt kit ?- Volkswagen Passat
Good cars and usually comes fully loaded. Handling and performans of passat is also very good and turbo does a very good job in cranking enough power from 1.8 plant. But spares are tad bit expensive. To get an idea, timing belt kit alone is somewhere around 60k. My mechanic advised to keep at least a float of 200k liquid money when i was looking out to buy one. Mechanical parts are available but body parts are bit hard to find.- Bmw Owners Clubs In Sri Lanka ?
try removing the ground (-) and press the brake pedal about 3 - 4 times. This should do ECU resetting. However running the diagnostic and clear out all fault codes would be the ideal way to get rid of check light if all sensors, ignition system, fuel system works properly. Didn't you give it a try to purchase the diagnostic tool and the software btw?- Fb 15 Air Bag Issue.... (urgent)
QUOTE (Killer-B @ Mar 30 2010, 12:21 PM) <{POST_SNAPBACK}> An airbag is usually deployed if during a crash at a certain speed limit which is detected by an accelerometer otherwise not, some chemical inflates the air bag i think this chemical is triggered by heat which causes it to inflate the airbag. What do you mean a problem with the airbag? Does the airbag indicator show up? I dont think regular warm conditions have any effect on the airbag sys. Can you spot any signs of a collision in the car? I dont think airbag repair jobs are cheap, and also FB15's are one of the most common models in the market, so why not go for a another car if this one dosent have any specialty? anyways wait for some more comments from other guys and decide on this. Cheers! he refers to a facial damages of the passenger side air bag which happens mostly due to heat. The dashboard/covering material used to rip off a bit and causes this and it's mostly seen on non-tropicalized versions.- Happy Birthday Miniace!
belated b'day wishes mighty mini.. hope you had a blast it's being a holiday..- Tik-tik Noise When Switching On A/c
just check whether this is the inner bearing or the one with the pulley. If its inner one then there's a high chance of what he said to be true. However keep in mind that these guys are just lazy to repair compressors since complete used ones are up for sale at affordable price.- Happy Birthday Dilesh!
many happy returns of the day mate.. have a great one..- Car Around Rs.2laks For Campus Student?
Good write up.. felt sorry about your relatives, perhaps they got bad examples and havent had right people and right parts ? 504 would be a good option to this guy and I got infected with peugeot virus when i was an undergrad student and that was the only vehicle fitted my budget. I spent almost all money on buying it so literaly it ran for another one and a half year!! without even a service coz I couldn't afford . That's when I decided to keep it and buy more of the same coz it had proven a point, reliability. 505 does share the same platform to the latest 504s and so does the reliability, at least engine,drivetrain and suspension let alone electrics. Certain bells and whistles like vaccum operated A/C blower gates were giving issues, so most of them had those mechanisms removed well before it's life span.- Peugeot 406 Infrared Remote Lock Not Working
you're refferring to the remote key mechanism of late 405 and early 406 MK i. What's the issue with it ? Usually it's agents who can carry out/fix these type of repairs especially the infrared unit which is not programmable using Peugeot Planet unlike the RF type keys. Give this place a buzz and inform your issue, capable guy who doesn't rip off European owners Throve Automobile - 0773 841315- Tik-tik Noise When Switching On A/c
Let me get this straight, is it one time click noise as compressor engages or it continuous as compressor is being engage? If it's one time then it's the sound of electric clutch of compressor engages. If its continuous then it must be the bearing of the compressor pulley.- Dated Transfer Papers
they do but i don't give it a chance to lost in mail. So everytime i went through one day service i hand over documents at about 10 and collect the book back around 4 p.m- Dated Transfer Papers
further clarification on this, if the date of the transfer is within 06 months from current date, you can do it through one day service if you wish so. if the date is older than 06 months, it's mandatory for you to go through the normal process.- How Do They Assign Number To Vehicles
i'm sure this was discussed in details in this forum. Try little bit of searching. For the reg. numbers you asked for 31,32,64 and 65 are "diesel motor car" category. 325- is given for re-registered vehicles due to being ex forces or petrol to diesel conversions. 29/30 is diesel motor coaches and 38 is for petrol motor lorry category and 39 is given for petrol hearses AFAIK. I'm sure Miniace will further enlighten you on this.- Defender Svx 60th Anniversary
so its you? Pics please and some info within legality frame please. - Whistling Sound From Engine Bay On Kickdown
