Everything posted by Hoonigan
Chinese Stereo Headunits
Apart from being the more expensive, I felt that DHL and Aramex pay a bit more when it comes to taxes (which you have to pay back to the courier). I've used DHL and Aramex on many occasions when the seller would not post directly to SL, ruling out regular post. Every single item shipped via DHL and Aramex got taxed and in the case of DHL carrying some suspension parts, were about to get taxed HEAVILY. On the other hand, via regular post, most packages were delivered to my doorsteps without a single rupee of tax. Some were reasonably heavy and/or medium sized boxes carrying things like motorcycle headlights and other car parts. The rare occasions I had to go to Central Post, my experience was similar to Crosswind's and Kirala2's. Be honest about it and if they see that you're just bringing this for your personal use, you'll pay a very reasonable amount and be on your way.
- Risk of caught in fire and Car Fire Extinguishers
I thought CO2 would suffocate the flame and put it out. For the possible fire types you would expect in a car, such as Fuel or electricity related, CO2 should be fine. Practically though, I have only come across the powder type that are specifically made for cars. But I wondered the mess it would make and could potentially cause issues in the eventual repair of the vehicle. What am I missing here?
Project Capri
Since my last update, I ran into some trouble getting the engine to run smoothly. Wouldn't start properly, when it finally did, wouldn't idle properly, had no torque (caused the clutch to burn out) and it was cracking spark plugs on a daily basis. After much frustration, found someone who is familiar with the fuel system (Bosch K-Jetronic) and the repair involved the 6 injectors being replaced, all 6 spark plugs being replaced with genuine NGK plugs, new air filter, new clutch and pressure plate and a list of other parts to clean up the cold start module and ignition system. After this, the engine was tuned up and it could easily break traction and leave 11s on the road despite the 255 rear tyres Retrofitted an AC and plumbed it to the two heater vents on the dash and tucked everything else under the dash so that the presence of an AC system is completely out of sight. Wired the AC to a simple on/off toggle switch (see pics) The whole upholstery was done from scratch. Nowhere fancy as Deans but the job turned out to be pretty good. I got the dash fascia laser cut out of black plexi. Rear seats were ditched and the SSCUS buckets went in the front. The steering wheel is a Grant Challenger piece. Finally had the car running this weekend on a Cars and Coffee SL Sunday run and covered around 60-70Km in light traffic and a little bit of 'spirited' driving. The car has buckets of torque low down and 3rd gear is really something else. The long run also revealed some issues I need to address. The rear drums lock up early and tends to slide the rear out clockwise and I felt a general lack of stopping power with the fronts as well. Rear leafs are nowhere near stiff enough and the gearbox hums in neutral and first. In closing, the car will continue to be worked on for years to come but this feels like a good time as any, to bring closure to this thread. In the three years I've spent so far with the Capri, I've made my fair share of mistakes and screw ups but each of them helped me learn something I didn't know. And more than anything, provided a much needed distraction during some tough times. All in all, I love owning this car, even with all the imperfections! All but one of the pics below are thanks to Cars and Coffee Sri Lanka. Thanks for reading gents!
While I was in Qatar, having a small fire extinguisher in the car was a legal requirement. Having one missing would cause you to fail the annual inspection and renewal of the licensing process. A fire can be caused by many things such as leaking fuel lines/fittings or short circuiting wiring. Had a incident a couple of months back with my project car where the starter motor wire was rubbing on the exhaust manifold and while heating up, melted the insulation and started to short circuit. Noticed it before anything escalated. While it's not something to lose sleep over, many cars from Lambos to Mercs to Toyotas have caught fire around the world for different reasons and it's definitely not a bad idea to have a small fire extinguisher in the boot. We used to carry the powder type canisters back in Qatar but CO2 makes more sense I think.
Budget Friendly 4x4- Single Cab
As others have mentioned, your money would be better spent on an older Jap than a Bolero. If you're looking for a cheap rig that you can take offroad, I've heard that the Suzuki Jimny is surprisingly capable. I have also seen some CJ and TJ Wranglers advertised for not a lot of money. And most of them are running Mitsubishi engines now so you can cross the engine swap off your list and focus on Suspension and Tyres.
is riding comfort depend on tyre Quality/brand
Short answer is yes. I had a set of crappy tyres (Don't remember the brand) on my car when I bought it as well. I replaced them with a set of Silverstones. While they aren't the best tyres around, they did make a noticeable improvement on ride quality. If you go for a decent brand and variant, you can find plenty of reviews online which can help you gauge factors such as comfort, wear, grip and road noise; specific to that tyre. This way you can make a more informed decision.
Installing halo rings
Suppose you mean halo lights? Depends on how your headlights are assembled. I did mine at home but in my case, the headlight lenses are 'clipped' on to the headlight so it was easy to get in there and fix the halos and run the wires. If the headlights are 'glued' together, there's heating and resealing involved (which is really easy to f*** up) so take it someplace reliable. Unfortunately I can't recommend a place as such. I do remember hearing that Sun Lanka or Bara Audio does this.
Importing a Dual Purpose Ute
Hi Hermano, welcome to SL and to the forum. I'd stick with your initial choice; the Hilux. It will fulfill all the requirements you have mentioned and definitely can take the beating the Sri Lankan back roads has to offer. Being a Toyota, agent support and parts availability should not be a problem. The alternative I can think of is the Navara but it's not the popular choice for whatever reason.
Advice on Trading a Jaguar S Type for BMW E38, E39, E60 or Jaguar XJ (X350)
No first hand experience with the bigger toys unfortunately. I personally prefer the smaller sedans like the 3 series and the C class. I feel that they are more engaging than their bigger brothers.(But my opinion is purely speculative) I own a fairly basic E46 with very little bells and whistles but I enjoy every drive I take regardless.
Since you seem to be keen on the exclusivity and have made your peace with the relatively high cost of ownership, the E38 and the XJ seem to be the upgrades from your S type. I'd go with the E38 of the two but I am a little biased towards Bimmers.
What is Best vehicle with the Best resale value ?
The Mini prices quoted these days are eye watering!
Fixing Different Size Pcd Alloys To My Car
There are adapters that can be used to change the PCD. it's trickier if you are going from 4 stud to 5 stud. Also note that you're adding about another inch to the hub so watch out for rubbing tyres. I re-studded my hubs to go from 4x108 to 5x120.7 but having done that, I don't think it's worth the trouble. Best thing to do is to find the correct wheels.
Plugging In An Efi Engine To My Carina At 170 (Carb)
You can retrofit an in-tank pump into the old tank. We did that with my Capri. OP, As others have mentioned, I think the best course of action is to rebuild the engine and carb you have and get it tuned properly. This will address all of the issues you have mentioned. This is especially the case if you only have a 2 year horizon with the car. You will be at the end of the two year mark by the time you sort out the little niggles that will keep popping up if you go with a conversion.
Buying a new smartphone
Bought the S7 Edge for the wife and there seems to be a huge improvement of battery life. My old Note 2 seems to be getting slower by the day, maybe I should get Cyanogenmod in there and see.
- Motor Tricycle
- Vehicle Valuvation By Autolankan's
Suzuki A-Star
And it's a fairly common practice for owners to quote higher economy figures to potential buyers.
Motor Tricycle
There's a chance that you will be able to find a sidecar stashed somewhere in a small shop in Kurunegala or Negombo if you go looking. I'd also check with Ceylon International Motor Company (Lal uncle's place in Madiwela). But I think you will have better luck fabricating one. Rhamzi Ahmed also built a a trike a while back using a Hayabusa, some parts off of a Ford Focus and custom fiberglass work.
Effect Of Not Having Radiator Fan Cover(Shroud)
The shroud ensures maximum possible airflow through the radiator. When the vehicle is moving, the additional airflow would compensate for this but as you have experienced already, the vehicle would have trouble staying cool when stationary. Kind of surprised you can't find a used one. Have you checked around Panchi or Delkanda? We built one out of steel for the Capri but that doesn't look half as neat as a factory shroud. But if you can't find one, that's an option.
Mini Q
I recently asked about an AC for the Capri and was told it will cost around 50K, didn't get a cost breakdown though.
Indian Or Japanese
For utility on a budget and as a first car, The Kelisa was mentioned on the forum several times with high praise. Maybe worth having a look at?
- Break Pedal Goes To The Floor
- Up Sizing Tyres - Pros And Cons
Mini Classic Efi Conversion
Any reason why you want efi? I will pass on a piece of information given to me by Supra-Natural. Do a little bit of reading into "Megasquirt". It is sort of an end to end efi conversion that you can possibly diy.
