Charith H Jayasinghe
Everything posted by Charith H Jayasinghe
  1. So what was the issue? Did you checked your charging system as many suggested here?
  2. It seems senior fellows preferred manual alignment rather than so called computerised, why? Is it because of machines used?, or the technicians(who are pretend to be)?
  3. Uditha , N17 means are you referring N16 facelift version? Udditha, How about adding FB15 facelift (new shell) it also have good resale value. maintenance will be same as you mention.
  4. As komi said telling truth also good point but warranty claiming issue might occur as Sampath mention... so how about doing a spying visit before do so, to check how they respond to such situation?
  5. Can anyone suggest to buy place in to buy alloy wheels in Colombo(I'm not from Colombo) as I'm planning to do both alloy and HID projectors on same day. Please send a message at least if you cannot post here.
  6. iRage, Thanks, Those cup holders are not there. It's not in the spec even.
  7. Komi, Just asking, why did you do surgery in that area? Any ENT part? :-P hope this has happened while you were in Mannar.
  8. Schiffer, Can you please explain about ABS check noise? Is it the sound which occurs (which is heard like small electric motor runs for a half second) when key turn into Ignition?
  9. Excellent project Komi...
  10. If anyone there with retrofit HID projectors in Sri Lanka please upload a photo, specialy if you did that from Bara..
  11. Don, What's that penetrating oil means? Is it the spray of oil to underneath part? If that's so why some say don't do it cause it's harm to rubber bushes? What's your view? Seems like you prefer VIC filters. What's your view for oil filters over so called genuine?
  12. Still expecting all Auto Lanka.com Members to suggest to your opinions and share your fb15 modification here.
  13. Don, yes I red through your other articles, I won't go for flushing. I think Decarbonisation and throttle body also cleaned with MAF replacement. Also i changed Break oil and ATF(with sump plate removing) I'm not doing daily driving but only on my vacation once a month. In that I'm doing long trips (Total around 800 km) At the moment I'm using Mobil supper 1000x2 (mineral) last time I changed at 4500km, so what would you do? (I mean if you change full synthetic at 7k what for mineral) and viscosity is 15w40 (don't know for how long that grade) but manual recommended Mineral oil with 5W30 (preferred) and 10W30 & 10W40, true I've red your articles but please tell me what would you do? Cause I wanna make it to run optimum cause she's my first one. So I go for all necessary things as I'm not a regular user and so it won't hardly impact on my budget. Please comment.
  14. Well That's depend on stock light(if it with HID) other detail already described it this thread. At the moment I'm having that so called Rs 8000 one but cannot satisfy with it. Komi said B*r* Ste**in Dehivala have it. Going to check at the end of this month.
  15. Thanks iRage that VZ-R one looks so good and the above one too....
  16. Yes Don Recently done less than 8000 km back Both lower arms Front shocks Tie rod Even new radiator core replaced. New spark plugs replaced, LFR 5A (using octane 95) Fuel filter replaced And 3000 km back Fuel pump motor replaced, MAF Sensor replaced Engine mount replaced, AC Belts replaced Now ODO 94500km Other plan is to shift to fully synthetic from next service (Last time didn't do because some of some controversial documents on the Web of course I didn't have full access to AutoLanka.com. Now I feel better because now I can go for engine flush... Service, decarbonisation ( don't know much about, reading these days) before change for it. I'll get your advices after reading bit. Thanks Don
  17. Thank you. Previous owner also has maintained it well hope to keep it the same way. I've read most of the threads in Auto Lanka.com regarding maintenance. If a doubt come, I'll contact you.
  18. Sorry Don, I've been reading through Web most of the time, but these specific info I couldn't find clearly, sometimes broadly for whole engine series but still less about QG15. That's why I asked so that so that I will be not in doubt.
  19. Thanks DonThat issues came when I came across a octane 95 fuel thread there that issue take two aspects if it Become Either MAP or MAF Sensor. Thanks again.
  20. *Hi I'm new to Auto Lanka.com, *This is regarding to your opinions, experience, photos of modifying a Nissan UA FB15 (New Shell) sunny. * Why I posting this is, I recently bought above mentioned car as my first car. I think my home town area influenced Me to go for that. Wanted to make it looks exotic (not sporty) but most of fb15 out there are kept in stock (default) appearance. So far the advices I got is to keep the car same even without change the rim cup. * Therefore most of thing what I've done so far aim mainly interior and small exterior changes. Pioneer sub woofer, replaced other speakers, Display with blutooth with reverse camera, 3M tint with windscreen, Seat covers (only to protect originals plan to add good one later after all finis), Replaced Interior and front park light with white LED, Head light protecting tint, HID headlights, LED strip fixed to illuminate front middle floor of bumper(bulbs can't be seen out side) Future plans (wherever your opinions are needed to make it looks nice instead of kill) Projector head lamps with day time running lights (komi is helping me with this) Hid fog lights with ccfl halo rings Alloy wheels ( This is the most difficult part to choose) Spoiler (This is also too difficult to select, please upload photos if you can) What would you do if you had this type car? Please your opinions are highly appreciated.
  21. what is this mist thing? How does it work?
