Dushyantha
Everything posted by Dushyantha
  1. so you'r gonna replace the coil because the rubber part is degraded . i think this can be repaired easily with a new rubber part without replacing the whole coil. If the coil is malfunctioning then of course you would have to replace it . but if its only the rubber part , then finding an alternative first would be better
  2. Did you replace the ignition coil? By damaged do u mean that the coil itself is damaged or is it the rubber part that goes inside the engine which is damaged?
  3. double post
  4. Usually the coolant level reduces a slight ammount over a long time. I think that mixing different types of coolants wouldnt be a problem unless its a hybrid. Why would you want to use a different brand?
  5. heres a list of things i have done so far after i started hearing the sound. checked the suspension mounts. - replaced worn out lowerarm balljoints. other bushes and balljoints were in good condition. since it was recomended by many places - replaced the hub bearings . (humming was still there comming from the front.) Checked transmission oil . had an ammonia like smell . other than that the level was fine and was thick like honey. checked the transmission mounts . OK swapped front tyres to back - no change in the issue . still the sound was coming from the front. went to an alignment place - Found that there was a broken steering rack boot which i replaced. gonna get the alignment checked out today .
  6. did u mean an injector cleaner ? super diesel is the same everywhere except for the slight change in quality due to how it is stored .
  7. Sorrry. My bad. I didnt mention it. Its coming from the front. Identical to hub bearing hum. Its a lancer cs3. FWD Hum increases as the speed increases and comes regardless of which gear or neutral its in and becomes unbearable at like 120kmph
  8. Replaced the hub bearings and the cv joints dont make any kata kata sound so arent worn out i assume
  9. yes . all that was done . and the hub bearings were not in the best condition so they had to be replaced anyways . i also checked the gear oil level which wasnt low .
  10. Hey guys Been having this problem for sometime where i can hear a hum like sound which you get when hub bearings are worn . Since hub bearings arent that cheapi first got my tyres checked out and they turned out to be fine . swapping tyres did nothing to change the sound . since the next normal culprit for this kind of hum are the hub bearings i was adviced to replace the hub bearings . got them replaced last week . but still the sound is still there . its exactly like the humming sound u get when the hub bearings are worn out . has anyone ever had this kind of experience before ?
  11. yes . eventually i discovered that although these have an obd port the communication protocol which is used by mitsubishis cannot be intergrated into cheap obd scanner circuits (something to do with the timing or frequency of the chips used in the scanners according to what i understood) .So using the MUT scanner which is there with the dealers is the only thing that can give heaps of data about the sensors and working of the ecu.
  12. the number after the W is what determines the viscosity . so theres not much of a difference between those two oils except for the way they are manufactured and the cold starting temperatures and stuff which in srilanka is not very important yes it would . a small oil burn if acceptable for an engine of that mileage . as i said earlier , using a higher viscosity oil on a worn out engine only solved problems temporarily an also cause more additional problems on the long run . things like the oil pump in your engine were not designed to pump oil of viscosity 50 so u wouldnt know what kind of problems would arise . use the correct oil and do an engine overhaul when the time comes . Thats the correct way to go . using a 50 oil on an engine designed for a 30 oil is not very wise . hence keep using the 40 oil and when you cannot run the engine anymore . do an overhaul .
  13. nop only the passenger side airbag inflator was replaced . looked something simmilar to this
  14. usually heavy/fragile/large items from ebay would cost much more because of the special shipping required . why not try something like this instead ? http://www.ebay.com/itm/Metra-Car-Stereo-Double-DIN-Dash-Kit-Trim-for-2004-2009-Mazda-3-Series-95-7504-/322174684055?fits=Make%3AMazda|Model%3A3&hash=item4b031b8b97:g:GsMAAOSwkl5XdEGC&vxp=mtr and fix a normal double din stereo .
  15. i had a fiat bravo but sadly . not anymore . the 300- or 301- you're talking about must have been a saloon model ryt ? spares for them ? u could get someone in panchikawatta to bring down parts for you . or personally import them. if you have someone with a fair bit of car knowledge in italy or UK then there are loads of wreckers where parts can be sourced . I do no know how different the petrol variant is from the diesel but 5-6 years back there were no cv joints lower arms shocks rackends , clutch plates and stuff for a fiat bravo in srilanka . ball joints can be repaired and used again for some time . same goes for shockabsorbers
  16. Thanks @Davy and @HashanJay for sharing the info . went there to replace my timing belt and got the airbag inflator also replaced while at it . They had to remove the whole dashboard , but didnt take much time .
  17. Hi . welcome to the forum . u should first do a search on google regarding how the thickness of oils are named .You wouldnt have to increase the oil thickness if there isnt any noticeable oil burning in the engine . But the answer to an oil burning engine is not increasing the oil thickness . The correct way is to use the specific oil recommended in the owners manual and when the engine starts burning oil it means that its time for an engine overhaul . by using a more thicker oil you can avoid the overhaul for some time because the thicker oil would compensate for the worn out parts . usually crank bearings and piston rings but keep in mind that not all parts in an engine wear out evenly . so by using a thicker oil to compensate for the worn out parts you would be creating additional problems to non worn out parts which would still be needing a much thinner oil than thats required for the worn out parts . Using a sae30 oil in brand new engines and then using a thicker oil such as sae 40 when the mileage reaches somewhere around 100000 is practiced by most people in srilanka . this may have worked for older engines which may be more tolerant to oil thickness changes . but modern engines designers design these engines now keeping in mind that the users would strictly follow the instructions given . so using a different thickness oil in a modern engine would be inviting trouble IMO . so using a thicker oil is what would make you engine prone to wear much quicker . if sae 40 was used earlier better continue to use the oil of same thickness . And the 0W , 10W , 15W part really doesnt matter in srilanka . the number after the w is what you should be looking at to get an idea about the viscosity of oil .
  18. Just a suggestion . since ur somehow going to tap into the wiring system. why not wire Your DVR to an accessory switched 12V supply and buy good 12v phone charger that goes in the cigarette lighter . that way you can get your DVR wires off the dashboard and also charge your phone with a more reliable charger .
  19. Dushyantha replied to rangana1's topic in PEUGEOT
    Spareparts are relatively higher when compared to a japanese hatchback of that range. More electronics that can go wrong than a jap of that year . so a road side mechanic wouldnt be able to sort out most stuff. The cheap OBD scanners wont work . so you would have to pay someone to check for any fault codes Comfortable than a Japanese car. would me more economical on fuel when compared with a Japanese of that range because of the complicated electronic stuff A Jap would be economical in maintenance and fuel combined. A Peugeot would be more comfy and would be economical on fuel but you would have to spend a little more on spares + u cannot abuse a peugeot and expect it to run like a slave . whereas a jap can be driven with doing the minimum basic maintenance.
  20. thats for a genuine mitsubishi part . take out the respective relay and visit a sparepart shop . am not sure about the price but it sure wouldnt be 6000rs
  21. Had this same problem once in a car where the car started heating up but there wasnt any oil in water or water in oil. and just like you i went and cleaned out the radiator and checked the whole cooling system .in the end it turned out to be a teeny weeny leak in the gasket . being a cheapskate i just replaced the gasket which solved the problem but i t came again after some time . in the end took the whole engine out faced the head . cleaned out all the coolant lines in the engine and fixed up everything with a new gasket and this solved the overheating and radiator pressurizing problem for me so urs might also be something like that . hope it helps
  22. Did the mechanic try clearing the code ? was it a permanent code ? The N light flashing would have made the auto gearbox not change gears and be at some default gear which explains the "When i accelerate car was moving slowly." does the gear still change with a DOCK sound ? maybe the ELC relay got stuck ? . However its hard to diagnose a problem which is intermittent . Try to somehow replicate that problem. If it doesn't come back forget about it Code 54 from the ECU would be No cam signal. i hav no idea why this is so . maybe its different for the TCU or maybe coz its a Launch x431 and not an MUT scanner
  23. https://www.facebook.com/chanaka.jinasena/media_set?set=a.10150239235090590.367519.618005589&type=3 interesting restoration
