Everything posted by PerfMad
SUZUKI LIANA
I believe its the average fuel consumption.. whats the tranny ? and if you drive in colombo daily with traffic then, that's not a bad figure.. But there is no harm in doing an engine tuneup as well..
- Alternator current not enough
lubricating oil reducing
Thanks for the explanation and suggestions @Rumesh88
So if there is such issue, what are the things i should do to overcome the problem ? Sorry to take this thread into another way, i but i hope this might help the current thread as well
@Rumesh88 what does it mean if you see oil residue on the air filter ? (assuming engine isn't burning any oil nor any oil leaks)
I did the coil replacement as well (if im not mistaken) and it cost me somewhere around 7500 ~ (not exactly sure) because the part was given along with some other components as the shop owner told they won't sell only the coil. ( this is what my mechanic told) However my issue was alternator stopped charging at all, therefore once we check for the root cause it was found out to be blown coil pack (if i recall properly)
- Compressor thermal protector
Please use below link to see the location. Place is highly recommended since i've been going there for almost 13 years (whenever i get any AC troubles ) https://www.google.co.in/maps/@6.9020721,79.9056396,3a,75y,89.37h,88.6t/data=!3m6!1e1!3m4!1sskQsT9vSJKijAP2qBV2Yig!2e0!7i13312!8i6656?hl=en
Suzuki swift HT51S overheating issue
Great. keep us posted
Yes as @Twin Turbo mentioned get your cooling fan speeds, fuse/relays checked and radiator cleaned if its blocked
- Meter gauge fluctuation
Problem with Automatic Transmission
Thanks great news. Hope your problem is resolved by the way, cost of the repair depends on the repair job and wear of internal parts.. he costed me 80k for my CVT gearbox repair, and also suggested he rather wanted me to go for a recon one since i can find one for bit more less amount
Hi there Sorry to hear about this.. But i hope below thread will give you a headsup.
- Nissan N16 Automatic D Mode Problem
Hey Rather than looking for a gearbox replace, try changing the gearbox oil with a recommended brand for ur specific model.. Um not quite sure about the price as it may differ.. But i hope it should be not more than 10,000 .. please do check with the agents / or someone who uses the same model. May I know the Year of manufacture of ur car? Is it a CVT gearbox or conventional gearbox? If yours is a conventional gearbox, cost should be less... If its a CVT gearbox then oil cost should be somewhere within the budget i've mentioned..
Hi To me it looks like gearbox pressure isn't enough during cold start.. It takes time to build up the pressure inside the gearbox.. However when was the last time you changed the gearbox oil? how much have u done after changing oil (if u did change the oil) and whats the ODO meter reading now? If you haven't change oil, then i would prefer changing the oil and see whether you face similar issue.. If it does then its time for you to go for a gearbox overhaul or replace with a recon Cheers
Erratic shifting in drive mode
@asanka_rg any update ?
Machan check ebay.. Check whether below link is a fit http://www.ebay.com/itm/13420-65D00-Throttle-Position-Sernsor-Fits-Chevrolet-Tracker-Suzuki-Vetara-XL7-/281777024490?hash=item419b382dea:g:EtkAAOSwu4BV06s7&vxp=mtr
- Sudden burn smell from AC vents and head lights went off
Radiator fan issue Kia Rio
great
Hi Machan.. I have a City GD8 2004 model, i had an issue with the highbeam as well, and same as you root cause was switch has burnt really bad. However before replacing the switch make sure that you have used correct voltage bulbs (may be previous owner have increased it from 55-60 to 100). This is the main cause for such issue. If that's the case, either u can replace once with correct voltage / make sure to use relays. After that you can buy a switch. I found mine from Panchikawatta like almost 3 years ago or something around 7500 LKR. However the seller didnt wanted to sell just the switch as it came with whole steering column and it costed around 25-30k... But after having lengthy conversation he agreed to give it. but it took me like 5-6 hours to find a good one (as mine is like almost brandnew condition). I really cant remember the exact shop, but if you walk abit and ask from shops (stay away from kaakko) they will guide you to some resourceful places.. Im pretty sure tec motors must be having em, but should be within the limit of what u quoted.. I will update you on the shop if i get to find the receipt .. not quite sure where i kept it exactly.. However just give a call to Thilak on 0776330336 and see whether he has any (im not 100% sure about this no) but i have saved, and should be related to some seller who i bought switches for some reason :D) just give it a try and try ur luck.. Cheers
