Randeewa
Everything posted by Randeewa
Brand new Yes. Original not sure. All parts (shock mounts, Sway bar links, bushes shock bumper stoppers, lower arm bushes etc) came with Honda Sticker with Badge . but I am pretty sure not genuine. as per Hyaenidae's reply this will be s issue for me. Shocks are genuine Honda from Tech motors 42000 front each ( I don't like KYB Stiffness) rear around 30. Steering rack Used. Rs.30,000 but i replaced rack end and tie rod with new Honda brand cost 20,000.00 all 4 parts (Also may be not genuine).
Thank you for details. I think there is lot to learn from your reply to my mechanic. Specially about CV Axle
I have Honda Grace 2016 car with 105000 genuine mileage. few months ago some noises started when hitting pot holes and when driving damaged roads. when checking with my mechanic he suggested a full suspension repair as all parts are original and already completed 100000 km. all worn parts replaced including 4 shock absorbers with shock mount and related parts, Complete steering rack, balance bar bushes, two links, lower arm bushes, caliper pins, after repair he confirmed there are no any worn out parts generate noises. Unfortunately there is still knocking noise when hitting pot holes. mechanic failed to find any reason he suggest replace both front CV axles as there is play on inner CV joints.( He says bearing or CV cup worn out) 1. Is there knocking noise generate when hitting pot holes if inner joint worn out? 2 is this is a common issues for this particular car model and where would be the cause? Any one has a idea i highly appreciated
Anyone used or newly replaced this CWORKS brand shock absorbers? Its manufactured by Toyota but Made in China. How about Ride quality when comparing KYB? Anyone has idea or experience highly appreciated.
Nothing. I think Odometer has been changed 90% of Vehicles in Sri Lanka except few 1st owner home used vehicles. Just check on popular classified websites all most 10 to 15 years old cars odometer is lower than 100000 Km (80000Km is the most popular number). One guy i know do visits car sales and tamper odometers. So never rely on Odometer number. like experts mentioned do a full checkup if all things on good condition that what you can get. Probably running repairs will arise early than you expect due to lower odometer number and ready for it.
I have exact same experienced on my Honda Fit GP1 few years back. 100% agreed with for Ted's post. steering rack nut is in too tight due to Rack and pinon worn out. True when using few days will loose the wheel or you can loosen nut manually. But then Daka Daka noise will come again. After repair on my GP1 steering wheel was very tight and not returned. even heard grinding noise when turning. when loosen the nut manually noise came back. I will never Recommend repair racks best thing replace with recondition one. Following is my previous post about Aqua Rack. I have repaired Steering Rack of my Aqua twice. It was never workout for me. repaired rack only last few months only with very bad roads in Sri Lanka. If only Rack bush worn out repair by replacing bush will be Ok. But if Rack and pinion worn out it can never repair. Just waste of money. Only thing Replace with Brand new one or Good conditioned Recondition one as i did for my Aqua. Guarge Mechanics will say it can be repair you can run year or two blah blah never true. you will hear daka daka noise within few weeks or months when loosing tightened rack. This is experience from not only Aqua few of my previous cars Suzuki, Honda Fit, Prius all the same. If any one knows how to repair Rack and pinion repairing Rack will be Ok. Also if you are running good Carpeted Roads most of time repaired rack will last more period of time. and also check rack ends and Tie rod ends are tight. Note that repairing rack will cost you Rs.10K to Rs.12K and recondition rack of Aqua will cost Rs.20K to 25K.
Toyota aqua rack repair
Randeewa replied to Shasheem MOHAMED -COLOMBO-'s topic in General Automotive
I am not an expert. But this is from experience. I have repaired Steering Rack of my Aqua twice. It was never workout for me. repaired rack only last few months only with very bad roads in Sri Lanka. If only Rack bush worn out repair by replacing bush will be Ok. But if Rack and pinion worn out it can never repair. Just waste of money. Only thing Replace with Brand new one or Good conditioned Recondition one as i did for my Aqua. Guarge Mechanics will say it can be repair you can run year or two blah blah never true. you will hear daka daka noise within few weeks or months when loosing tightened rack. This is experience from not only Aqua few of my previous cars Suzuki, Honda Fit, Prius all the same. If any one knows how to repair Rack and pinion repairing Rack will be Ok. Also if you are running good Carpeted Roads most of time repaired rack will last more period of time. and also check rack ends and Tie rod ends are tight. Note that repairing rack will cost you Rs.10K to Rs.12K and recondition rack of Aqua will cost Rs.20K to 25K. -
Looking for help to figure out best tyre
Randeewa replied to shansilva's topic in General Automotive
I have used Dunlop LM705 (Japanese) on Honda Fit GP1 and Suzuki Swift Beetle 2008. May be Bridgestone better than Dunlop but LM705 is very comfortable and Very Quite. Therefore, durability may be less. but excellent Tyre if available on your size. -
Good explanation iRage. This is what most people need aware of. most of them think only the 'Made in Japan' printed is only good. 90% of them are not actual Made in Japan only the print. I think if the product is genuine (brand name) no matter where it is manufactured (if they follow quality standards).
Dunlop SP Sport LM705 (Japanese) superb Tyre for Honda Fit GP1. Very Comfortable, Quite, Durable.
Check noise only hear hitting bumps when steering wheel straight position (not turning right or left)
Hi all Yesterday i went to repair Power steering rack of a Toyota Aqua 2012 (Due to noise issue) First i went to new lathe work place to know it can be repaired guy says yes charges is Rs6500.00 for total repair (if pinion worn out it should also repaired + replace the Bush). then i went to totally new place to remove and fix the rack which was a place lathe workshop guy recommended. They remove rack just took 10 to 15 minutes using hydraulic jack and lathe workshop repaired rack within 30 minutes and the fixing again took 15 minutes. My problem is they charge Rs 6500.00 for only remove and fix the rack (Total cost is Rs13,000.00) and i feel i was ripped off by garage people. The last time i done this same job for Honda Fit GP1 (different places) rack repair cost was Rs2500.00+ remove fixing charges Rs.3500.00 Total Rs.6000.00 one and half year ago. Anyone who did a Steering Rack repair recently let me know is this charges reasonable? Thanks
Fuel Filter is located inside the Fuel Tank with pump right? What is the average mileage for cleaning Fuel Filter with Sri Lankan Dirty Fuel? (I mean the condition of the Fuel Sheds)
My brother recently brought Suzuki Swift 2008 (DBA-ZC71S. 1300CC) and there are some things to clarify. 1. When AC on the radiator fan noise is noticeably very very high is this normal of this model? 2. Engine heat is very very high more than other similar capacity cars (But heat gauge needle is in the center always). I used to own a Chevrolet Cruze and engine is M13A which also on Swift beetle older models never heat this much. (DBA-ZC71S has different engine and i need to clarify is this normal for this model? After 1/2 hour drive cannot even touch the bonnet stand. Fuel consumption is 6 to 8 without heavy traffic. I feel that there is some issue on cooling fan or engine cooling system. Any expert or Swift owners please reply me. Thanks
Good Info. Are the system reset on Honda Fit GP1 can be done by a scanner or disconnecting 12V battery or from both way will reset usable capacity?
Honda Fit GP1 is very good car to own and very trouble free Hybrid Car (may be it is mild Hybrid). Compare to other cars in this price range most of hatchbacks like Vitz, Passo, IST, WagonR, Swift, Mira, Alto including Hybrids and Petrol cars GP1 is way ahead in regard options, Comfortable, Driving Pleasure, even it way ahead with most popular Toyota Aqua. I owned GP1 one and half year now and it never give any single trouble for me. The price is GP1 is low presently and worth the every bit of money comparing above mentioned car prices (Some are very older than GP1 and still has very high price) If you refer Japanese website for recall it clearly mentioned the manufacture date range as follows. GP1-1200002 to GP1-1242186 May 10, 2012-August 2, 2013 When searching to buy a GP1 i found lots of cars 2012/2013 manufactured and falls withing recall range and all cars in 2011 out of range. So i went for 2011 minding safe side and regardless newest manufacture year. So try to avoid recall range (Except current owner repaired the oil burning issue and produce evidence of repair) When searching to buy a GP1 i found various trim levels and versions in GP1s (Basic model with less options like key starts, 10th Anniversary Model, Navi Premium Model, Fine Style Model, Anniversary and Navi Premium with Original Mugen Body Kits. etc. Navi Premium Model is the Highest grade GP1 and it has lots of extra options like 7 Speed Paddle Shift, Dual Multi function Steering Wheel, Intelligent Smart Key, CoolBox, Climate Control AC , Cruise control , Traction control , Alloy wheels , Fog Lamps , Seat Heaters,Auto Head Lights , Retractable winker Mirrors Original Honda navi premium Audio System with Reverse camera, DVD Bluetooth & Navigation. Windscreen & Side mirror heaters etc. Currently most of GP1s falls in same price range regardless above extra options. So try to find highest option out of recall range GP1.
[Solved] What is the difference between Honda Fit GP1 and GP5?
Randeewa replied to Klord's topic in General Automotive
I find that the driving the GP1 in the traffic is a bit hard until you get used to it, because when you leave the breaks the car feels like its in a hurry to go even without pressing the accelerator. Haven’t noticed that in the GP5. I don't have driven GP5 but about GP1 you are 100% correct. indeed i also found that the GP1 is hard to drive in traffic until you get used. After you familiar with GP1 for a long time it will be hard to drive other car. Also i have things to clarify about GP1. 1. At the very steep climb with 4 people if you break the car it is very hard to accelerate and get up. You have to reverse down and get pickup. then it will be ok anyone noticed about it? 2. Break and stop at climb when releasing break pedal car is reverse backward. you have to put handbrake or press gas pedal to stop reverse ( i didn't experience that much in any other car) like balancing clutch on manual car. Are above common things on GP1 and also with GP5?- 24 replies
- comparisson
- difference
(and 2 more)
I have faced similar issue last week. When i started my GP1 AC works fine after 10 to 15 Minutes drive suddenly AC completely stops working. I stop the car with engine running and checked no compressor on/off click sound or fan running. Then i tried AC on off manually few times and suddenly compressor start 2 times and stops not starts again. I took car AC repair guy and he checked and says Gas and other things are OK may be problem with electric issue. Then i went to my electronic guy and he inspect car with scanner and says AC Relay may be faulty and this is common issue for GP1. He changed the Relay AC works fine. (Relay is located in near AC compressor on engine bay). This was happened 3 days ago and still no issue.
- 17 replies
- refrigerant
- gas
(and 6 more)
toyota prius buying a toyota prius 2008 or aqua 2012
Randeewa replied to Rohitha1988's topic in General Automotive
This is very true. You will be save more money from your Vitz than Prius or Aqua. The reason is both cars are very old for Hybrids and you have to spend lots of money for maintenance and repairs. I was owns a 2008 prius. If you want upgrade from Vitz go for higher grade Petrol Car. If you badly need hybrid for save money from fuel go for Brand new Hybrid. -
No not engine oil burning issue. May be this is only for me. As per Mechanics opinion smell is coming from Hybrid Battery cooling system (Fan). and he says what exactly what you have posted "When the hybrid battery is low engine will try to charge it then performance go down".
Honda fit gp1\ aqua Vs Toyota vits 2015 unregistered\used IST
Randeewa replied to Toyot's question in Car Buying Information
Agreed with TheflyingFox and Matroska I have experience with both Toyota and Honda Fit. on Aqua you can never trust about battery other than full test with T......Lanka. On Honda fit Battery issues will be very less and must check for chassis number to avoid recall range. GP1-1200002 to GP1-1242186 GP1-8000002 to GP1-8000091 You can easily avoid above range by checking chassis number display on the to of the engine bay and also on passenger side door frame. I have checked 12 cars 8 is within the range and other 4 out of range. -
I have recently changed my 4 tires to Dunlop SP Sport LM704 (Japan) which is great tires (Comfort, Road Noise). On the tire it says Sumitomo Rubber Industries. Is Dunlop also Sumitomo or Dunlop use their rubber?
Is this true? Any one can confim it
