ruwan67
Everything posted by ruwan67
  1. Waht is that black color tube crossing over the shocks
  2. Dear Done and others This is the way the forum should be!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! excellent I thought why I bought recondition than old if not I would have been able to learn by doing all the gagets Regards, RUwan
  3. This is the photo the importer + car
  4. Wed, 2007-11-14 03:14 Sunil C. Perera in Colombo Colombo, 14 November, (Asiantribune.com): A China made four seater electric car - Electricia - will roam on local roads within this year. Ecowheels Private Ltd, an associate company of Weightech has made arrangements to import this Plug and Run , No Fuel Car. Mr.Nissanka Ediriwira , Chairman of Ecowheels says the Ministry of Environment has shown a green light to provide concessions and the company hopes to display this 'City Commuter Car at the Ceylon Motor Show which is to be held on the 30 th of this month at the BMICH, Colombo . (Embedded image moved to file: pic00041.jpg)Mr.Ediriweera with Sri lanka's first 4-seater ElectriciaMr.Ediriweera with Sri lanka's first 4-seater Electricia According to the manufacturers this car does not need liquid fuel, oil or other expensive spare parts.T his car manufactured in China with the Japanese technology includes modern features comforts and a 3000 Watt Motor. "If charged for seven hours the car will take you 110 kilometers running distance, he said. After my proposal on using economic benifits of the electric car the President appointed a committee headed by Dr.A.G.T.Sugathapala , Head of the Mechanical Engineering , University of Moratuwa to obtain a detailed report, which clearly recommended electric cars. According to Dr.Sugathapala's report , in Sri Lanka the vehicle population has increased by ten fold during last 30 years .It assists the degradation of air quality specially in the urban sector. Dr.Sugathapala proposes that electric vehicles could safe guard the environment .Electric vehicles do not undergo any combustion process ..Mechanical power is directly derived from electricity .According to the report the electric cars has no tailpipe emissions , less maintenance , less spare parts , less noise while in operation and totally eco friendly. "I want to make some contribution to save foreign exchange to the country after the introduction of this "green car ".The government has moved to impose a green tax to protect the environment in it's effort to reduce Fossil fuel usage in Sri Lanka.At present the government charges 28% duty + other taxes on this car. I have made an appeal to the government to reduce these levies. Mr.Ediriwira said the first Electricia will reach Sri Lanka on 21 of this month and it costs 1.4 million rupees with current taxes. "I want to leave some thing to my country. as the first businessman to bring this four seater -Fiber glass body Electric car to Sri Lanka , thus helping to reduce the dependence on fossil fuels and reduce air pollution. He said the running cost per kilometer is very low around one rupee. Mr.Ediriwira was a senior Flt.Lt.of the Royal Ceylon Air Force and later became an entrepreneur after acquisition of the ownership of Avery in Sri Lanka . Now he represents the world's largest state of - the- art electronic scale manufacturers Metter Toledo. He has been in the weighing industry for over 40 years. - Asian Tribune -
  5. Dear Chinth_guy According to my recent, reading following sensor are used by ECU •Crankshaft Position Sensor - Determines timing for fuel injection and ignition of each cylinder and also detects engine speed. •Top Dead Center Sensor - Determines ignition timing at start-up (cranking) and when crank angle is abnormal. •Cylinder Position Sensor - Detects position of #1 cylinder for sequential spark ignition to each cylinder. •Engine Coolant Temperature - or ''ECT'' thermocouple input for engine coolant temperature •Intake Air Temperature Sensor - or ''IAT'' thermocouple input for intake air temperature •Map Sensor - Manifold Absolute Pressure Sensor, allows ECU to adjust Air Fuel Ratio based on density of intake air •Oxygen Sensor - Measures oxygen content of exhaust gas •Pressure Atmosphere - or ''PA'' or ''Barometric Pressure Sensor'' measures atmospheric pressure. •Tps Sensor - Throttle Position Sensor •Vehicle Speed Sensor - or ''VSS'' measures how fast axles are turning •Idle Air Control Valve / Electronic Air Control Vale - Or ''IAC/EACV'' Helps control idle Optional sensors: •Electrical Load Detector - or ''ELD'' present in most US cars to measure how much electrical load there is •Knock Sensor - A microphone-like device to listen for Pre Ignition, or knocking in DOHC Vtec motors. •Pa Sensor - Atmospheric Pressure sensor Tuning EFI is making the fuel map. Finally the ECU calculate the pulse-width, the time period, which on-off the petrol injector to maintain 14.5:1(idial) air fuel ratio( it can change to obtained max torque etc). This is doing by internal control software like PID controller. Due to non-linear behavior of the engine, we cannot fixed the single set-point for all RPM hence open loop set-points can be set for intervals of RPM (1000,1050, ……,4000) where the engine model can be assumed as linear for particular interval and intermediate is calculation by interpolation. If you think the ECU can find the correct injector pulse-width by it self (I believe it is possible with modern control systems like neural network)I suggest to run the engine for certain time with intervals of RPM like 500,1000,1500………. So that it can fined more accurate fuel map otherwise it will interpolate to find next value from what ever the far RPMs you tuned. How ever, on my experience with different machines, definitely the ECU will be taken wrong decision, if the sensors are not OK. So best thing is to re-calibrate or put all the sensors specially. Oxygen, temperature and pressure (analogue sensors) and do the tuning. Refer following web http://www.pgmfi.org/twiki/bin/view/Library/EcuSensors Regards, Ruwan
  6. Dear Friends, See the site which explain how to make you own body kit, lambo doors etc in your backyard http://www.chevroletcavalier.org/custom_body_kits.htm insted of sticking the aluminum foil there is a aluminum tape 2~4inch in the market Regards, Ruwan
  7. dear TSP See the modification if you Crx is the same http://img264.imageshack.us/my.php?image=hondacrxje2.jpg Regards, Ruwan
  8. Dear Dillon, What is the white color meter on the dash bord, what for? Its like lady in red Regards, Ruwan
  9. Ashoke thanks, As I was used old cars before it seems good comfort for me. During Kandy tour I was feel good specially back. I think seat feels bit hardy so I am gona to dress it with spongy seat covers. I found metallic read (for young boys) with reveres camera and LCD screen but bit expensive so I gave up. Be careful when you buy new one because some sellers give you 1.3L engine with 1.5 chassis. See the photos in the web first. If it is 1.5 front is fully compacted. Actually is as same as new Honda City(Indian), but is selling in Japan as fit area(Thailand) because Fit is famous in Japan and compliance with JP standards and market like Teak interior etc. Regards, Ruwan
  10. I think below are good links for ECU programing http://www.openecu.org/index.php?title=Main_Page http://pgmfi.org/ I just went through pgmfi it is excellent for new learner spacialy for HONDA guys and openecu.org for Mitsubishi Regards, Ruwan
  11. Dear Friends, This is my 4th vehicle two of them I drove in Middle East( petrel is cheaper than water) all were manual & no power steering but I was not car enthusiast and expert like you but now I am seeking knowledge from you and the webs. In real life in SL I fill the tank full and went to Kandy, Colombo & more in WALAWAL SAHITH PARAVAL in Jaela area until tank reach to ¼ and fill it full again and check the meter reading it was 14.5km/l and almost equal to the TRIP meter 15km/l. Recently I went through web found that engine and body earth is also effect to fuel economy if the resistance is increase it affected to sensors feadback so beater to check it it must be 0ohm. Regards, Ruwan
  12. if i reply for correct understanding of the requirement. There is a special primer coat call rust converter which is converted rust the corrosion in to filler so no need brushing and it seal the body. It is use for many places and I heard from the sales ref that it was invented by BMW. I forgot the company name but he told me he is supplying to dot-Dumi##a the car modifying guy. for cooling tower pips we purchased from Will Power the chemical supplier Regards, Ruwan
  13. ruwan67 replied to Sparky's topic in General
    Sorry rs.950
  14. ruwan67 replied to Sparky's topic in General
    Last time my AC guy bought 4x8ft 5mm for rs.1800
  15. Dear Friends, It is true that kmh Vs MPG and most car 50~60kmh is the best. But there is a relationship between RPM (revelation per minute) and fuel consumption, and it increases when idling (no work done)the engine at high RPM (increase the number of combustion in a less time) When you go in high traffic MPG(Total engine operate time)= MPG(Stayed time) + MPG(traveled time) In both states car engine is running so if you want to reduce the fuel consumption stop the engine when you stay in the road So; MPG(Total engine operate time)= MPG(traveled time) But practically we can’t do it unless the long stay like rail road crossing etc. If L gear has less RPM its combustion will reduce when stay (idling) so it increase the fuel consumption and contribute to MPG. In L it has high torque so you do not need any acceleration to give momentum and ECU I think is programmed L for good MGP for high torque rather do it manualy. Don’t bluff me for boosting My new car, I-DSI made record 26.2km/l see the below thread http://paultan.org/archives/2007/06/11/hon...nomy-challenge/ Regards, Ruwan
  16. ruwan67 replied to Sparky's topic in General
    There is special rubber sheet (5mm,10mm etc ) ,call Aero Flex, use for Air conditioning it has great suoundproofing and withstand to water & UV, heat insulation and fire. avaialble in FRP Traders I think in Bumbelapity see the Yelow page. I am nor expert but I think you can check the possibilty of application for the doors etc. Usualy outdoor sound level is 80dB and ask the Sales ref which thickness is need to reduce it to 40dB ( comfort sound level)
  17. It was my resent exp with new car(See my "Became Honda lover" post). When you put L gear the RPM usually reduce to 500 or less (less RPM less petrol; I have no idea about your car RPM) from D mode (RPM 1000~1500) and you don’t need acceleration in flat land just release the break. I got 8~10km/l in D and 13km/l in L when KOTA KOTA YANAKOTA. Regards, Ruwan
  18. Thanks ash better to change the mirror to 90 not only threewheeler but also pedestrian crossing the road ruwan
  19. Remove the Catelyst Converter and go with L gear in heavy trafic Those info is from readings and reason exp Regards, ruwan
  20. Dear Friends, Last Sunday I went to a funeral, and drive behind the cope for its last respect. As you know it was KOTA KOTA YAME with 0km/h. Thanks for CVT no acceleration but it was in Drive (D) mode of Auto gear the RPM is 1500.and need to pickup the every after stopping. The petrol consumption was 8~9km/l. I though to change the gear to L mode (low) and see. After that RPM was reduce to 0.5 and fuel economy was increased to 13.5km/l. I thing this is the best method during the high traffic in the City? Regards, Ruwan
  21. Dear Friends, Reasons for some low gpm due to failure of catalyst converter http://reviews.ebay.com/Reasons-for-cataly...000000002803746 regards, Ruwan
  22. Dear Zozozo, Some links regarding CVT http://paultan.org/archives/2006/02/08/hon...grade-exercise/ http://www.jatco.co.jp/ENGLISH/WHATSNEW/index.html Regards, Rwan
  23. Pls let me know how to upload the photos because it is not working Regards, Ruwan
