Everything posted by vag2
Volkswagen Bora 2.0 Burning Oil
could be valve seals,piston rings. If it gets worse,recommend to put in the new engine,not try to repair the existing one. The workshops who do machine work with Japanese engines do not know how to work on these heads/blocks.
Kia Picanto 2017 fuel consumption?
what about body parts and spare parts availability?
- 17 replies
- kia
- picanto
- picanto 2017
- kia picanto
- Corsa1992 ax
Engine Stalling While Slowing Down
is there a pre-supply pump in the fuel tank? In diesel engines same symptoms come when the fuse or pump has issues.
- Vehicle Buy & Sell starter guide - In need of ideas and suggestions
- Kia Picanto vs Wagon R (both brand new)
Importing a Volkswagen E-Golf
great timing with power cuts to use the budget concessions ?
MG ZS 2018
yes,downsized engines dont give best mileage on the Highway compared to bigger engines. But should give better mileage in City than 5-6kmpl.(Maybe better after Break-in period?)
End Of The Road For Land Rover Defender (Dec.2015)
looks like Defender fans are going to get not One,but TWO possible candidates to choose from. Which one will be closer to the original? https://europe.autonews.com/automakers/ineos-will-use-bmw-engines-defender-inspired-suv
- Suzuki StingRay Seat Heaters
Budget 2019
its that time of the year again ?
Toyota corolla 121engine oil burning
Liqy Moly is a well known European product. But I don't think it will fix it if the piston rings are worn out or valve seals/O-rings damaged. But only a bit worn out,might expand the rubber parts and reduce oil burning.
TOYOTA PRIUS SECOND HAND
If you consider the additional costs and headaches that will occur for the maintainance of the hybrid parts, the vitz will be hassle free although smaller.
Vitz push start wont start
maybe the push start control unit? Get it scanned at the agents
BMW F10 VS Mercedes benz W212
I think Mercs hold well against time compared to the others,at least most models.
- What is the best SUV around 7 million?
Importing Engines?
I think @The Don helped another member to import a Volvo engine from UK last year. @sampath gunasekara
Need advice on 12v battery
get a battery scan done,cost only 100rupees. It will check not only the voltage,but also ability to hold charge (CCA) against the original specifications.
Is it micro panda better than maruti in terms of performance?
Is maradaane kaluakka better than Tunmulle Chooti akka? ? Getting serious, the Panda is like marrying a woman with 2 kids, while you may have small orgasmic moments, you will get screwed in places you cannot even think of, and getting parts is a big headache even at the agent.
Fuel injectors cutting off while coasting downhill in gear
This is not rocket science. Fuel quantity is based on Torque demand(calculated based on Pedal position,Vehicle speed etc) If theres no Torque demand, the Injector opening time will be reduced close to 0ms. On highend Euro or US cars however is a more advanced system,where the Control unit can deactivate some cylinders during coasting/cruising(4 cylinders of a V8 engine deactivated)
Japanese Car News
meanwhile, Mazda sticks to nonhybrids and focusing on improving gasoline engines. First gasoline with compression ignition released in US. http://europe.autonews.com/article/20181127/COPY/311279914?template=mobile02&X-IgnoreUserAgent=1
Engine knocking in civic SR
oh,boy. Hope a piece of gunk in the fuel tank doesn't come off by the "magic arishte" from Mr.Potato Estate and block your high pressure fuel pump /fine pitch injector nozzles.
Vehicle for 10 million
Thats common to all Japanese Common rail diesels,due to our hi-sulfur fuel quality. This issue in 2012ish Pajeros is with the Fuel pressure and Temperature sensors. When it comes the vehicle wont start. Temporary solution is to remove the sensor. The vehicle of our "Loku Hamuduruvo" is at the agents for months now.
Toyota aqua 2013 registered one. ( price will be 3.6M )
Don't just believe in the hybrid battery capacity report. Some garages fix a gadget that shows good battery capacity despite battery being dead. Also some places make cut and bud with other model batteries(Insight,FIT). So a thorough visual check of the battery is also needed.
