Sirimanna
Everything posted by Sirimanna
Abnormal engine sound : 2011 Lancer
Sirimanna replied to Sirimanna's question in Mechanical problems
No this is 2 L Engine 2011 Mitsubishi lancer es -
Nop, this happened when moving RPM around 1500-2000 around 50-60 speed -
Yes, it's as bad as that video. I think this is a common issue. As long as it doesn’t affect my engine, I’ll just go with it. I even went to a local Mitsubishi dealer, but they couldn’t find the issue either. 😞 -
Same issue discussed here, but no any proper solution, -
Nop, same like yours, its still not fixed even changed pulleys , same as your 1500-1800 RPM -
Nop, same like yours, its still not fixed even changed pulleys , same as your 1500-1800 RPM.. -
Hello everyone, please refer to the sound below. In my 2011 Lancer, when I drive at a constant speed, an abnormal sound comes from the engine area. I recently changed all the pulleys because of this. Any advice on this? https://youtube.com/shorts/G3uxYjSm6b4?feature=share https://www.youtube.com/shorts/G3uxYjSm6b4
Hi .. Thank you soo much for your comment.. yes this is from internet.. I have another car toyota vitz while I am doing service it from the compnay, I ask about my 141 from mechanic, this is what he said .. I sent an email to the Toyota main company .. and they sent the user manual in pdf format, it said . It's normal to burn so much oil.
Hi friend, I went to Toyota and they checked and said that one quart of oil in the range of 1,500 miles to be acceptable.. according to Toyota this is normal,, but i have no idea ...
Hello iRage.. its actually move in to lower dot of the stick every 5000KM.. please refer the image.. is it normal?
Hello, Friends, I got 2008 Corolla 141, recently i notice that it's burning oil. Every 5000 KM service oil level changed to lower level.. is this normal? Is there 141 users who are facing this same issue???
Hi, I checked them.. one of my friend said its because of water pump.. Still checking... Thxx
Hi friends , i got Toyota Corolla 141 and recently i heard bad noisy sound on the engine area. Where it comes from? any recommendation? Please refer below link for sound.. this is same as mine.. https://www.youtube.com/watch?v=RqtzWse-Jx8 Please help Thanks, Indika
Thank you friend appreciated your reply
Hii, i thought middle is in between for 5 bars.. that's why i am confused
Hi All, i just want to check that Corolla 141 2008 Temperature Meter value is little bit higher than mid point.. is it normal? Thank you
Hi All, Corolla 141 2008 which fuel type best, Octane 92 or 95? Thank you.
