Everything posted by MAS
Project Capri
Fully worth the wait :-)
Good Tinkering And Paint Garage In Colombo
I have read on AL (a senior member had recommended), there is a garage on Pepiliyana road, (between Pepiliyana roundabout and Gamsaba traffic lights). It is near to the bridge. However, there are two garages there. I think the one nearest to the bridge . I have never used their services.
Project Capri
If you don't mind, could you please share the costs involved in importing them through Kapruka. Thanks.
Fuel Pressure Test
How about anywhere around Colombo other than the agents ? I have a hard start issue after switching off the engine. Need to prime the fuel pump a few times to start. So I need to know if its the check valve (fuel pump), fuel pressure regulator or leaking injector.
Fuel Pressure Test
Anyone know of a garage around Dehiwela - Mount Lavinia that can do a fuel pressure test. This is for a Hyundai. THANKS !
- Quick Dent Fixing ?
- R18 Tyres
Shock Absorber Test Results
Which side would you give priority ? I cant afford 4 shocks in one go.
Car xxxx something, opposite Savoy.
I did a test at a shop in Wellawatte and it showed my rear shocks were imbalanced and was advised to replace. I did a 2nd test at a shop in Hyde Park and it showed my front shocks were imbalanced. Now I am totally lost :-) The shocks are on a Hyundai Tucson and they have done more than 60,000Km. I personally feel the rear stiff but not bouncing up and down. 28psi on the rears and 30psi on the front. Your comments and advice are most welcome :-) Thanks !
- Triumph T R Restore Project
Exhaust Leak
Where did you get it done at 7500? I also need to replace my entire exhaust (corroded).
Bg 44K Fuel Injector Cleaner
Thanks guys. This is what I plan to do also. 1. Run a fuel system cleaner 2. Ultrasonic injector cleaning
Thanks varunatech. Where can I buy this around Colombo? How much does it cost?
Hi, Please share your experiences with this product. Thanks
- Toyota Vios 2003 - “Ignition Knock”
- Hum From Ac Compressor
Yes, Sylvi. It is cooling ok. If you can, please let me know of a reputed AC repair/service place that will not break the bank :-). Thanks.
Hi, Wish everyone on AL a prosperous 2012 ! I get a hum from my AC compressor when the car warms up. It happens both when the AC clutch is engaged and disengaged. The sound will go away only if I switch off the AC. This started to happen a few weeks after all the 3 drive belts were changed. The belts have been rechecked and adjusted to the correct tension. I really hope I do not need to replace the compressor. Thanks in advance.
Ignition Knock
Sorry for the dumb question. I thought modern engines timing is not adjustable manually. That it is controlled by the ECU only
A Place For Tint Services (Labour Only)
Thanks guys !
Wellawatte
Hi, I got some pre cut tints for my vehicle. So need to get them applied. I doubt if KP will agree for only the labour charges (since I am providing the tints). Any other good place that is recommended? Thanks !
Importing An Lcd Tv
What was your duty free allowance at the time ?
Need Some Opinons On How To Get To Katharagama....
I went recently, around 10pm the dam section of the road was still open. Maybe they don't close it since the security situation has improved.
