whatever
Everything posted by whatever
  1. Why are Prius drivers so smug? http://youtu.be/CVdMySWfAIQ
  2. Your saving, if any, should be based the market value rather than an imaginary Rs.14 million value. Also, if possible, it is more realistic to estimate the total cost of ownership over a period of time rather than the saving only on fuel.
  3. I believe the distance you mentioned is to and from Kandy
  4. Sorry, I haven't put it correctly. What I mean is, regardless of the vehicle behind you dipped or not, driving with the center mirror in normal position in the night time is inconvenient. So the center rear view mirror is out of the question.
  5. Though the reflection from windscreen is not so strong, it's still disturbing for me. Whenever I turn on my head lights, I turn the center mirror to anti glare position as a habit. (When the center mirror is in normal position, even if the vehicle behind is dipped, it's still inconvenient in the night).
  6. The problem is, reflection is not only from centre rear view mirror. It may reflect from side mirrors and from your windscreen.
  7. whatever replied to wjkalana's topic in BMW
    BMW just can't set an arbitrary profit margin of 50% per unit, simply because they don't have a monopoly. Google it and you will find that the 5 series profit margin is around 8 to 10 % . Now the inserting part: In the financial report you mentioned, 51.3% is the increase in net profit with respect to the previous year. Simple grade 1 maths: 51.3 = (4907 - 3243)/3243*100. It is not the return on investment
  8. I agree with NPP. If any kind of market is crashed, price must be reduced by more than 25% and it must be very hard to find buyers even for the reduced price. You even can't say it a "correction". Proper term may be "slow down"
  9. You can easily follow the number 48 in that link: 48) Drive shoeless Some hardcore hypermilers drive in sock or bare feet so they can modulate the accelerator to the finest degree (particularly important when "driving with load" / "target MPG driving" at cruise....
  10. You can also try hypermiling : http://ecomodder.com...-ecodriving.php
  11. An article written by an Apple fanboy with full of lies and misinformation. It is not a review at all.
  12. Stig, sorry about dragging the argument... The ‘cut off’ thing that I’m talking about is not from a separate IC, but is an integral part of the charging system itself. First of all don’t assume that charging process is single stage process. There is a standard algorithm with at least 3 stages for lithium-iron batteries (initial low current, constant current and constant voltage). These chips have temperature sensor input as well. (When the temperature exceed certain level, holding the charging process is a part of algorithm) No charging system will let the Lithium iron batteries overcharge, because it is highly dangerous. Once it is cut-off, no current is flown to the battery (except for the negligible leakage current) and there is nothing to divert. My understanding is that, it is not necessary to keep charging extra hours when you are charging a lithium iron for the first time. (If possible please show me any literature which recommends this). It has no effect. Phone read the battery voltage directly through a ADC ( Analog to Digital Converter). And when it says full, it really is full. For example, iPhone uses LTC4066 chip. According to the datasheet, once the battery is fully charged, it shutdown the charging and the charging cycle will not begin until the voltage drop back to the recharge threshold. So long as the phone is connected to the charger, it draws the power from charger instead of the battery. So the chance is very little for voltage to drop back to the recharge threshold. Effectively, you are isolating the battery from the phone when it is fully charged and still connected to the charger.
  13. Well, I'm no expert in battery technologies. But your analogy of mug under a tap is relevant to the process called trickle charging, which does not use in Lithium iron batteries. Also check any data sheet of Lithium iron battery charging ICs and you will find that it has a "dead band'. i.e once the charger cut-off it does not start charging cycle until the voltage drop to a certain level. It will not overcharge no matter how long you leave it on the charger. I have charged all my previous phones in overnight, but never replaced the batteries. Still charging the iPhone in the same way, nearly 2 years now, no battery issue at all.
  14. Probably true. But there are two things preventing that. One is I use it as an alarm and the other is, I addicted to use phone in the toilet in the morning
  15. Yes. It takes long time. I usually charge it overnight and the battery can hardly last a day. Right now mine is 50% discharged in 7 hrs
  16. Are you sure? More or less constant speed on expressway will result in less power consumption. Regenerator is to recover a part of the energy loss but there is still a net energy loss.
  17. I doubt so. Now the game is Apple need to catch up with Android
  18. Lancer Ex GT is the 2L version of Lancer Ex. ‘Galant Fortis’ a JDM variant. Probably this is the JDM variant of Lancer Ex GT
  19. whatever replied to joybook's topic in TOYOTA
    Prius is best suit for taxis. Point A --> B
  20. I had a similar issue, though the noise was different and no drop in RPM. The culprit was AC compressor. Probably the dropping of RPM may indicate the overload caused by defective bearings in compressor.
  21. I did not understand what's so wow about having a 2L engine in a van, until i read the post bellow...
  22. whatever replied to Saturn's topic in General
    You can buy one of those ELM327 clones for about U$12 from ebay. ( I bought one and it works)
  23. If your HID bulbs are less than 55W (most likely it should), it will draw less current than before. HID lights are more efficient than halogens.
  24. There are no assembly plants in Singapore. It must be wrong.
  25. Malaysia produces and exports Oil. Oil price in Malaysia is way bellow the market price
