2006 Maserati Mc12 Corse
dillongt
65 Degree V12 w/Dry Sump Lubrication
position Mid Longitudinal
aspiration Natural
valvetrain Gear-Driven DOHC, 4 Valves per Cyl
displacement 5998 cc / 366.0 cu in
bore 92 mm / 3.62 in
stroke 75.2 mm / 2.96 in
compression 11.2:1
power 564 kw / 756 bhp @ Not Available rpm
hp per litre 126.04 bhp per litre
bhp/weight 630.0 bhp per weight
drive wheels RWD w/Bosch ASR
body / frame Carbon & Nomex Honeycomb Monocoque w/Aluminum Sub Frames
front brakes Brembro Carbon Discs
f brake size 380 mm / 15.0 in
rear brakes Brembro Carbon Discs
r brake size 335 mm / 13.2 in
front wheels F 45.7 x 35.6 cm / 18 x 14 in
rear wheels R 45.7 x 35.6 cm / 18 x 14 in
front tire size 245/35 ZR19
rear tire size 345/35 ZR 19
f suspension Wishbones w/Push-Rod Acuated Dampers, Coaxial Coils, Springs
r suspension Wishbones w/Push-Rod Acuated Dampers, Coaxial Coils, Springs
weight 1200 kg / 2646 lbs
transmission Paddle Operated Maserati Cambiocorsa Electronically Controlled Electro-Hydraulic 6-Speed
gear ratios 3.15:1, 2.18:1, 1.57:1, 1.19:1, 0.94:1, 0.71:1
