Anju 119 Posted November 4, 2018 Share Posted November 4, 2018 Hello guys, Can anyone recomend me a place to repair sagging upholstery of my toyota allion 260 ? Thanks in advance ! ✌? Quote Link to comment Share on other sites More sharing options...
Sadik Posted November 5, 2018 Share Posted November 5, 2018 On 11/4/2018 at 1:46 PM, Anju 119 said: Hello guys, Can anyone recomend me a place to repair sagging upholstery of my toyota allion 260 ? Thanks in advance ! ✌? Expand For starters am a bit worried to see this in a 260.. Havent seen the glue coming off so fast? Has the vehicle being subjected to an impact / repair in this area? or perhaps a corrosion which is leaking water to the liner ? There are a quick DIY fixes, but i would suggest you going to a place like Nawala Cushion Works, take the entire headliner off clean and re-glue.If the cost is too high there are some DIY heating glue fixes which might do the trick. But pls inspect the respective area of the body Quote Link to comment Share on other sites More sharing options...
Anju 119 Posted November 5, 2018 Author Share Posted November 5, 2018 Hi, yes there was a wiring issue and the roof had been removed, this was done by toyota lanka. After one year only we got this issue. I will contact Nawala cushion works and see if there is any possibilty of repairing this. Thank you so much. On 11/5/2018 at 5:56 AM, Sadik said: For starters am a bit worried to see this in a 260.. Havent seen the glue coming off so fast? Has the vehicle being subjected to an impact / repair in this area? or perhaps a corrosion which is leaking water to the liner ? There are a quick DIY fixes, but i would suggest you going to a place like Nawala Cushion Works, take the entire headliner off clean and re-glue.If the cost is too high there are some DIY heating glue fixes which might do the trick. But pls inspect the respective area of the body Expand Quote Link to comment Share on other sites More sharing options...
