Hi friends!
My brother in law has a problem viewing AL classified images as no pictures appear on his PC ,instead a blank and not even links for the pictures.Other pictures appear as normal and can be viewed easily.This is affected in classified section only.Anyone got an answer?
MINIACE
Miniace ask your bro what browser he is using and whether he has enabled javascript,
it could be a security setting in the browser which might be causing this which might be blocking active content such as javascript
Hi friends!
MINIACE
Shane is correct, I also had same problem with ZoneAlarm(pro) firewall. If he is using the same just ask him to follow these steps
1. open Zonealarm firewall settings by double clicking the ZA short cut in the task bar
2. select "privacy" tab visible on the left side of this window
3. There will be a list of websites, frequently being used. Indeed www.autolanka.com should be there
4. click on it
5. then go to options and uncheck all boxes inside cookies, adblocking, and probably mobile code. Then the problem should be solved
cheers
vitz
I'm in agreement. Either the script blocker or the ad blocker in my Firefox blocks out the images. I check the classifieds using IE or a little plugin for firefox :D
