Ruslan
Everything posted by Ruslan
  1. Using their 512Kbps Unlimited package. didn't notice any slowness. took 4-5 hours to download DVD ripped movie which is 1.3GB and I'm in Mahragama.
  2. My neighbor owns X grade 121 Diesel. got a 3C-E Efi diesel engine which is the same with CR42 Townace.
  3. Ruslan replied to fookie's topic in TOYOTA
    Exactly, I've met many people with ruined suspensions because of these maka baases.
  4. Any reputed wheel alignment place will do that. make sure you removed battery terminals when you work around Airbag related area, just to be on the safe side.
  5. i think laptops coming under luxury items. but not the desktops and their parts. maybe that's why laptops in SL skyrocketed. and not the desktops. in US you can get Dell entry level notebook under $500/-
  6. Don't even think importing stuff through DHL Fedex too (Items like Cameras and phones). i ran into serious trouble with a phone. custom fellas wants me to get import export license and a permission from TRC and security clearance from Defense ministry since the Phone that i import got GPS in it. managed to re export it back and get it through a friend of mine from US when he's visiting SL. and i had to pay re-export charges for the courier.
  7. No idea mate, why dont you call them and ask. Contact number for parts should be on their site. www.toyota.lk
  8. Demonoid gone down as well. but i use thepiratebay.org
  9. Check your belts for any cracks, missing parts (on groves) if yes, then it's time for new set of belts. i think your car equipped with self adjusting belt tensioner that doesn't require to manually adjust. if not, slight adjusting will help you with the noise. and remember, if the drive belt is loosen, it will affect of your cars charging system, AC etc as well.
  10. At Toyota lanka, belt will cost you around close to 5-6000/-. it's the same "Mitsuboshi" branded belt. which is the OEM supplier to Toyota. so you better get it from outside reputed spare part outlet (matching Mitsuboshi belt) and get it replaced at local mech. I'm not sure but in my corolla it's single belt (1800CC uses a single belt but in 1500CC i think it's 2 belts, not sure). before hand make sure that it is the belts that make the noise
  11. check your belts/pulleys. dunno abt the 1500cc setup i think there should be 2 belts.
  12. Ruslan replied to jehan80's topic in OTHERS
    AC in vios and corollas are notorious for condenser and evaporator failures. if it switching on and off constantly then it could be a relay issue.
  13. Even in my car there was a noise before replacing the bushes. i think it's due to the road conditions. since you replace the bushes there is no need to worry for the moment. remember most of these cars are JDMs. and if you can carefully observe brand new imported Corollas and yaris equipped with slightly higher/different suspension setup than their JDM counterparts. hydraulic steering replacement is done purely because (i believe..), that there's lack of capable people/techies who can handle EPS related repairs effectively (rather than replacing the entire steering rack. which is costly).
  14. yep. as far as i herd this is a common among EPS systems. i know couple of blokes who replaced their EPS system with Hydraulic system because of this issue. even in hydraulic system be careful when you changing Power steering fluid. careful not to let air into the system as this will lead to ruin power steering vane pump. i had to replace my cars power steering pump because idiot at Auto mirage let air into the system when changing fluid and end up making noises and leaks.
  15. Manny happy returns of the day machan!..
  16. Driving a Corolla Luxel (Manufactured 2002) and ODO clocked at 136,000 K s. no hiccups nothing. still going strong. if the maintenance done properly (Oil changes , filters, recommended replacements etc) you can extract some good k s out from a petrol car.
  17. Hmmm.. maybe that's why ladies hate wearing seat belts.. That is sooo.. inconvenient... ha ha..
  18. but machan isn't it bad for cams? in a cold start it will take some time to reach the the head, since the oil is bit thicker than usual. most of the new motors recommended to put thinner oil i guess. (30). it's better to stick with good branded oil and stick with 3000-4000 k oil changes. newer VVt-i s nasty for sludge issues.
  19. Never heard of that before. mate, just do your regular services. change filters (Oil, air) at recommended durations (this is important to change around 4000-3000 K's to avoid sludge issues). chain will lubricate by the engine oil i think. so you don't need to disassemble head covers and screw your engine big time. as per VVTi said, tappet noise is normal when oil changing interval is near or in cold starts. Mobil Super XHP (New name is Mobil Super 1000 15W-40) is fine.
  20. Lol.. Undercoated undercarriage.. Ha Ha
  21. This comes real handy for small scratches under wheel wells and undercarriage. there were two products Wurth High Build Underseal Wirth Stone Gurad
  22. Machan, their main place situated at Nawinna Maharagama. price will be around 20,000/- for the whole thing. http://www.kleenpark.com
  23. try remove the added relay kit first. you better go to a good auto electrician to this.
  24. Hmmm.. it's more like indirect threatening saying "without us it's impossible even if the government put Military to continue operations at CPC"
  25. Oops! my bad then
