sira
Everything posted by sira
  1. sira replied to sira's topic in Electrical problems
    Thanks guys
  2. Hi I'm hoping to install 80W x2 Amplifier to my Honda Civic 1998 model. Looks this Amp consume more power. What is the recommended amp operation time when the engine of off mode. I should start the car without jump start. in generally what will be the amperage of car amplifire Sira
  3. I do recommend Rohana kesbewa. you can speak to him any time and he will explain it. soem time soem of mechanics are reluctent to advise i know some of them. sira
  4. sira replied to sira's topic in OTHERS
    http://www.autolanka.com/ad.asp?ID=117804. i'm looking some thing below 1.4
  5. sira posted a topic in OTHERS
    Dear All I'm planning to buy ford car currently i got honda civic EK3. this dose normally 10Km/L and still enjoying the honda. however this is 98 and looking a car with ABS and air bag. Honda cars with those functions are expensive and cannot afford now. KIA, Hyndai , Ford 's are still ok. any idea ? please let me have your expert Knowledge Thanks Sira
  6. Hi Guys I'm hoping to change my car tyres to 14inch . Currently i got 185/70R/13. planning to 185/70R/14. so need to change the rim size too. Before that i'd like to know the pros cons will this change affected to 1. Pulling power of the car 2. Incorrect Speed and millage - because tyre size is big 3. Improve the handling? 4. Breaks any other improvement or harm Please let me see your views on this Car model - Honda EK3 Exi 98. Sira
  7. Guys Since this issue i visited to arount 5 mechanics and they all said that this is comming from the gear box. one mechanic said he can fix by putting a brass washer in , not head about this , any idea ? you know i saw another car today - EK3 99 having same issue and the owner said it is normal. so now i think this is the common issue in EK3. my count is 5 cars now. sira
  8. thank you for the advice i spoke to honda angent and one eng sait this coould be inboard joint may have worn any idea and how to test that. seems like ring a bell. because some time back one guy removed this inboard jouint with whole shaft and re-grrease them. that time i tested the that time weather it got a play . by holding the CV thread side and try to turn the inboard joint gear box side where the grooves on it. so there was no any play. now the honda said that grooves may have worn and thats why it got backlash with diven wheel ends how to test this sira
  9. Hi can you please let me know the diagnosis process to rectify the exat issue.
  10. Hi Sylvi No ia hev not received your PM . can you check the mail address sira_c
  11. Hi I lift the car and with the gear 1 and tried to turn the lest wheel. so i heard the sound. so there is no clutch invoulved this test i belive Sira
  12. looks unabele to PM you . please send me a mail to [email protected] and i'll send my contact
  13. Sylvi No hum. only click noice. can you jest tell me how they fix this? i beluive they need to dismential the gear box and get the driven wheel out - this is honda civic ek3 -exi -1998 or any other way Please let me know. i'll give you my contact number sira
  14. sira posted a topic in General Automotive
    Hi Guys I'm looking for used tyres for my car coz i'm going to sell this in few months time. where can i get them and how to check weather they are good or not Sira
  15. Guys As my mentioned on " EK 3 Click noice" the issue with the gear box final drive on differential carier. the issue call differential pinion backlash. do you know any body can repair this ? looks the total carier needs to be replaced. and how feasible of the repair Sira
  16. sira replied to sira's topic in HONDA SRI LANKA
    It is a new one. thiland stuff.
  17. sira replied to sira's topic in HONDA SRI LANKA
    The U mount- it was thiland. can cost was 3700. i found a place in delkanda - supream motors and they are open 365 days. prices are good
  18. sira replied to sira's topic in HONDA SRI LANKA
    I replaced all pully belts today by my self. while doing this i had to remove one of engine mount which near the main pully. it was totally damadged. i replaced with new one . now i can see there is less backlash noice comming on this car. get it checked your one also. sira
  19. Yes, it is . same wattage. do not use 95w or soem thing like that. this is wonderfull. by the way, you need to install relays initially. because my on got 1.5 voltage drop and this was fixed by installing relays. sira
  20. Dear All I’m planning to buy Honda motor bike – probably Honda Jade. Hornet is very expensive However i have heard some rumours that Jade is a Old model – 1998- 2002. But some of them are selling YOM 2006 and some of them are changing the chassis number too. 100->120 How can i check this thing, and can somebody advice me on this please. Thanks sira
  21. Dear All I’m planning to buy Honda motor bike – probably Honda Jade. Hornet is very expensive However i have heard some rumours that Jade is a Old model – 1998- 2002. But some of them are selling YOM 2006 and some of them are changing the chassis number too. 100->120 How can i check this thing, and can somebody advice me on this please. Thanks sira
  22. sira replied to kmcsb's topic in HONDA SRI LANKA
    Is this EK3? if then this issue is one of common . because the Idle up control valve get stuck some times. it needs to be cleanned. i do not think do a tune up for this small matter sira
  23. http://answers.yahoo.com/question/index?qid=20080217172933AAGjc1m
  24. sira replied to sira's topic in HONDA SRI LANKA
    Yea, i checked them ,. they were good Thanks
