Twin Turbo
    51
  1. Hi, I'd start with the idle speed. Are the injectors getting enough fuel at the right pressure? TT.
  2. Check if the engine oil is dropping? top up fuel from a different fuel station. TT.
  3. Anything's technically possiblle ,, you'll need to update the reg doc. the car's value might be ffected badly. TT.
  4. HI, sounds loike you have a worn trans. TT.
  5. Congrats on your new toy bro, 👍 better go with the dealer recommendations for engine oi. have you got any record of the timing belt replacement? TT.
  6. Simpler to buy an original, auto
  7. Hi, Check the ATF level
  8. Hi, put an injector cleaner into the tank, and follow istructions,.. good luck,.. TT.
  9. Hi, Vaccume the entire car and put moth balls under the carpets
  10. Not forgetting Working DualA/c
  11. Hi your brand of motorcar has an agent last known in Rajagiriya.try them, \ The Iri's will have too be sourced through a specialist or the net, but be prepared to pay Good luck.! TT.
  12. 1. Is the level correct when the engine is off?
  13. Injetion pump leaking.
  14. Flush the entire trans system and test
  15. Hi, get a reg system installed. Apart from eficiency, you'll not get into the law books. Q, Do you have A/c running? TT.
  16. The cheapest will be the net. or the dealer?
  17. Change the air filter TT.
  18. Hi and welcome to AL, Congrats on your new purchase, you must drive the car carefully at least first few thousand km's you'll get the best efficiency after abt the 15000km service. Enjoy ! TT.
  19. You neede a full engine check up, Get a mech to check mthe ign, fuel pump, air filter.
  20. Hi, Check if then motor is stuck
  21. Hi, The short answer to your long question will be, no. No point in trying to fiit a car trans to a van. instead, change the air filter,fuel filter, fill the fuel tank with super diesel, check the alignment, put 35 bpsi on n all 4 tyres, And change engine oil with a fully synthetic Diesel oil. Good luck ! TT.
  22. H, Taking the age and mileage of your car, Change engine oil - SAE30 Change brakie fluid. Get the ATF level / qulity checked TT.
  23. Hi Legal and insureance complience issues seen as it will be seen as a modidic aion from the manufacturer's factory supplied eqiuipment.; TT.
  24. .Looks good but,
  25. Hi, try poolishing, best replce the cause as the first corrective action. TT.
