Twin Turbo
    51
  1. The fact remains, ignorance is bliss.Our techs don't know the meaning of the word compatibility So they stick to matching colourss when it comes to things like ATF. (replace red with red)
  2. All manufacturers put their own proucts in their user manulas.as to bring more profits,.. P.s, A long time ago the former dealer Car Mart used caltex DEX3 in their Mazdda auto boxes.
  3. Answered your self you have, yor thed has been previously discussed at length wishing you pleasent motoring,.. TT.
  4. I stand corrected,..Didn't go into details as I've met people who have proudly driven till theeir t belt failed only to boast about it.
  5. How sure are you of the ,milage?/ Our car odo m eters are famous for running back when they are about to change owners Your car is 10 yrs old, recommend getting a qualified peson to open the timing cover and inspect. if in doubt, replace with tensioner. Note:The manuacturer, Maruti Suzuki India recommend 100.000km changes to the timing kit,..
  6. The micro is from China. Enough said,... Then comes a prof of BS, and says it's the best thing to come since the invension of the wheel.
  7. BULLSHIT COURTESY OF MAZDA MOTOR CORPARATION HIROSHIMA JAPAN,..
  8. Do you have a key to get the shape to cut a new one? 1.Give your dog some bones. 2. make a safe place to keep the key. 3. get a new key and get it cut and programmed.
  9. Cheers , TT.
  10. Looks like the grease monkey won, while the dude goes to his fav grease monky and done the job on the cheap,
  11. The oil awailable at the time may have been used,..yes the previous change was the ideal viscosity for your appplication,.just ask for the 10W40 next time,..
  12. ,..
  13. Good to see someone change ATF before the transmission blows up! Manufacturer recomends a few compatable fluids recomended here,. Remember Price isn't everything, see how smooth your transmission changes with fresh Fluid. youu may use automatic transmissions Transaxle, Automatic 2.5 liters 2009 Dexron VIBMW 7045ENissan Matic D, J, LT 71141, JWS3309Ford Mercon V, MB236.6, MB236.7, MB236.8, MB236.9, MB236.10Mitsubishi/Hyundai SPII , SPIIIHonda Z1Toyota T-IVVolvo1161540VW/Audi G-055-025-AZChrysler ATF, ATF3+, ATF4+ for automatic transmissions Transaxle, Automatic 2.5 liters TT.
  14. Have you checked/ cleaned the throttle body?
  15. Buying any used car is mostly like buying a lottery ticket. I'd go for the Corolla. Good luck.! TT.
  16. Your short list has car,4wd, petrol/ diesel, normal, flash ect,.. a complx mix impossible to narrow down,.. Have you considerd maintenance, insurance etc ?
  17. Get yourself a late mod fuel injected 318i with manual trans.Make sure it has the original alloys.
  18. Get a disc conversion to the front, and thicer shoes for the rear will be a temp fix.
  19. Congrats bro,
  20. The booster only pushes the master cylinder,..where's the noise?
  21. A question comes on the maintenance history os the car,.. When was the brake system last flushed? Could your wheel cylinders/pistons be at fault?
  22. Cheers ! TT.
  23. Un trained, over worked, under paid staff don't know any better, Once again a good car is let down by a crummy dealer.
  24. IT'S MADE IN THAILAND So don't expect Jap build quality.At the end of the day, all modern cars are good if properly maintained.+++++++
  25. It's a Daihatsu remade in Malaysia.
