Everything posted by john cooper
4Wd For 2 Million
if i said whole TD and SD series i think you will agree with me, as we have to include the bullet prof TD42 and SD22, 23 but not the CD series
Buying A Classic Mini
- You many ways to find the original book 1. It should say Austin mini, Morris Mini (Due to some printing mistakes or document issues this may vary) 2 Licence fee is half of the MM (Use to be Rs 350, and now i guess Rs700) and if its a MM or Austin 1100 or 1300 then Licence fee is different. - As Don said, to find if its a cut bud then need to put on a hoist and check carefully, but its hard to notice (coz some put a nice under coating) - Engine choice is up to the owner, i pref Carb model and mine is a twin carb setup, electronic is good but when it come to the maintenance parts are hard to find and expensive to fix, Carb setup we can go with twin carb or 1 webber or 2 webber and you can do lots of mods than the EFI when its come to the mini. regards JC
4Wd For 2 Million
What i found with duel batt model comes with the Winter package, so this got heated fuel line, back passanger heaters + some more options - and i found its easy to start may be coz of the Amp is higher than the single batt setup regards JC
Low Budget Car Option
- Ford is a famous brand in the world but not in SL (not sure now) they made good cars, i think Ford Laser is a good option for bargain hunters, as most of the parts been sheared with Mazda - I am not sure about the price range in SL but its more than a car for the price you pay for sure regards JC
- Experience With Local Agents
How Can I Avoid Body Scratches In A Black Colored Vehicle?
This warp is not famous in SL may be because its cheaper to repaint the car than wrap but its different in here also due to the weather condition in NZ paint or clear coat peeling is common so to prevent this its the best practice to do so + some like the matt black than the shine black so rather paint the whole car its a good option to wrap regards JC
This is a common issue with all the VEHICLES specially with the black body paint, i have used the transparent wrap on the silver truck and Matt black for the car i use daily. its a BIG cost at the first place but you gain a good price when you resell the vehicle. i used the below people in New Zealand to get this done. http://www.carfolie.co.nz I hope you can get a general idea from this link above, and hope this is available in SL Supermarket scratch, highway stone chips is common for most of the vehicles in NZ so its looks bad and also get rusted if it really bad, so with this just remove the wrap when you sell and you will see the original paint with no scratch marks. and also you can do the rubber spray on your alloy wheel to minimize the curb marks. Hope this help you..... regards JC
Happy New Year 2015!!!
Same to you lokka and all the AL friends regards JC
4Wd For 2 Million
My idea as per below, basically SURF with different grades SSR-V no red door lights and the spare wheel mount under the body SSR-X SSR-X Limited (For sure you get the recaro interior + red door lamps on this model and the back door mounted spare wheel) i have seen the adjustable shocks only on this model and the SSR-G model not with the other two SSR-G Privacy glass 2 tone paint winter pack and a double battery is a must on G grade not sure the adjustable shocks is from TEMS but its only with the SSR-X Ltd and SSR-G regards JC
4Wd For 2 Million
Some says 2L is solid as 3L but for me or for my mates its never been, Once old gentleman sell his truck to my mate and said "Pls dont overheat it and should be fine" but HOW? as my first and last 2.4 overheated. mine was overheated on highway and got a free ride from a tow truck back to home and few of my mates blows the head while enjoying...... factory exhaust pipe blocking the exhaust a lot and that make a huge pressure and raise the temp Main issue with ours temp gauge is not indicate the correct temp, indicates the half on the gauge but water is boiling on other side..... lol and same for my friends too. Not sure if its worth to fix as its gone cost as same as a 1kz engine to prevent the overheating issue with 2LTE 1. Replace temp gauge and sender 2. Replace with large bore exhaust 3" is nice 3. replace with a alloy large radiator + external fan and if its a auto gear pls use a external trans oil cooler regards JC
4Wd For 2 Million
2.4 model and the 3.0 models are looks same but if the truck comes with 2LT the chassis plate says LN130 and KNZ130 with the 1KZ-TE, Pls correct me if i am wrong
4Wd For 2 Million
never tested the 660 turbo BUT 1300 is a wee truck for 4wd
4Wd For 2 Million
Hello Hpmt I can confirm the idea from IRage about the x-trail, its AWD system is much capable than RAV4, CRV but second to the PAJERO IO, try find a short wheel base IO with Manual tans as io comes with a separate transfer case with C.Diff lock but 1 problem, Mitsubishi GDI engine is a trouble maker so if you are not sure about this stay away. Another good option is a Suzuki Jimny, This got all the characteristics that serious mudder needs, Solid axle, separate transfer case, proper low range gear, short wheel base, light weight and from 98 still the same body i am telling this with my experience and this will take you anywhere and you can find latest model Jimny under 20lks ( Try find a manual gear with latest engine after 2003) How about LJ70 short wheel,if you try hard you can find a body permit imports with a 1KZ engine i am sure you won't disappoint with LJ70 I have seen some recommendations with SURF, KZN130 with 1KZ engine is a good machine for off road stuff but make sure engine is 1kz not 2L turbo as its a running time bomb its not worth to fix the radiator + trans oil cooler + large exhaust to save a gut less engine, but not sure about its fit to your price range Hope this will help you regards JC
Santa Fe 2007 Petrol 2.7 Vs Diesel
Let me add little to the above, I have seen lots of Korean SUV's with tons of Km's but still with good punch, but this is something i heard about all the Korean build, most of them complained about the brakes and suspension parts. Compare to a Nissan, Toyota or Isuzu, long term Korean users have to change the brake rotters and the suspension parts very often. I am not a real fan of Korean SUV's coz Toyota trucks on my DNA lol, i like the Korean designs as they really nice, i am not sure about the after sale service in Sri Lanka for Korean vehicles but i don't think you will disappoint with the choice regards JC
- Nissan Note
Nissan Note
Hello Gavindu My daily drive to the office is a NISSAN NOTE AUTECH RIDER, but not a 2013 model hope its same, Fuel consumption is really good as i am getting 430 - 450km on short runs with A/C or heater for a full tank and about 550km if i am doing on Highway Maintenance is cheap, no cam belt. HR15 engine. Oil change every 10,000km with the filter, i have put k&n air filter and NGK iridium CVT oil change every 30,000km and now its 130,000km on the clock and good for another 130k Rider edition is handling better than the normal model as its with Autech 16" wheels and lowered suspension P.S. i am easy on the foot always and hardly use the sport mode + i am not in my mother land but hope above figures same Good Luck with "NOTE" hunt regards JC
Help Me To Buy A Car From Direct Auction
- This is what i am using in NZ to import and they got a branch in SL and very easy to deal http://www.jp-c.com/auction/ regards JC
Montero Sport 2009-2012 Modifications
or we call it CRASH BAR
Hello The Don I don't think any law issue for the roof box, but cops might fuss over minor points like this, We had the same roof rack on Delica P25 and never had any issue with cops for the rack, but had to go to the court for factory nudge bar regards JC
- How To Obtain A Gun Licence?
Need Help To Buy A Roof Box / Roof Pod In Colombo
Hello Aravinda My dad found a 1 from Kurunegala, not sure how much he paid and we installed this on our Delica P25, I got a 1 installed on my PRADO and it is handy during the holiday season. Try find it from "Thule" and you need the Roof rack also to installed this (Can get both from same brand). Make sure you get a padlock to lock the box......lol Anyway try Kurunegala or Wijerama for used if interested regards JC
Isuzu Bighorn Models And Todays Market
Forget to tell you one more - Please check the sticker under the bonnet next to the wiper motor (black sticker from isuzu) and this should tell you most of the details about the truck. just take a snap and all the codes will explain the options regards JC
Hello PrassanDs Before start this i have to tell you this, i am NOT sure about the market in SL BUT i am giving the below details from my experience as a owner. Currently i am using my 5th Bighorn and i love the truck, lots of grunt from legendary 4JG2 engine (3050cc) with intercool Turbo, very good for towing, 4WD and carry passengers. Now i am using 1994 irmscher which is design for 4WD than touring while Lotus Edition is more focus on cruising. Bighorn/ Trooper UBS55 with 2.8 4JB1 inercool engine which is my favorite but it too old now, UBS69 with 4GJ2 and after 1996 its with s*itty 4JX1 engine which gives more issues than anything else. As i heard injectors operates with the help of oil pressure and need to use specific oil. (never bother find more details) Factory irmscher come with Recaro interiors, Stabi control to engage/ dis engage sway bar for more suspension movement when 4wd, No side steps, no door visors or mud flaps (I had to put), and most of them are Manual gears Lotus edition is more comfortable than the other versions if the suspensions are in good order, and nice to drive long distance (No body pain even after 1000km in 1 day) But on Irmscher you need to drink some Venival gata compared to the Landcruiser LJ 78/79 bighorn is less body rolling but with Pajero Exceed its not even near. economical to drive (Auto 4th gear chage @ the speed of 60km) just the usual oil change and filter change. "fingers crossed" <a href='http://postimg.org/image/8kgvwyc7v/' target='_blank'><img src='http://s25.postimg.org/8kgvwyc7v/009.jpg' border='0' alt="009" /></a> <a href='http://postimg.org/image/d7mxypzkr/' target='_blank'><img src='http://s25.postimg.org/d7mxypzkr/082_2.jpg' border='0' alt="082 (2)" /></a> <a href='http://postimg.org/image/rtdymywd7/' target='_blank'><img src='http://s25.postimg.org/rtdymywd7/086.jpg' border='0' alt="086" /></a> Cheers JC
Ford F150 Raptor Svt @ Cms
I don't think this is something to "surprise" coz you can see expensive vehicles than this in SL so SVT RAPTOR is in SL we need to be proud
Happy Birthday Irage
Happy B'day bro......! Late wishes from JC
