Ripper
Everything posted by Ripper
  1. I'd say if you can afford the time... go for Formula world. I don't have experience with them but i was involved with them quite closely on some advertising stuff for them. They have all the high tech equipment and have factory settings for most cars if you need things to be aligned perfectly etc etc... and their painting process is also quite good... Don't think it's fair for me to put out all the info on them but if you make a visit there and talk the tech folks and have a look around i'm sure you'll be convinced in how they work and the quality of it all...
  2. Ripper replied to maikk99's topic in General
    sun*anka installs these things...you can either buy and intall then and there or buy and take it to them for installation... don't have experience with these guys on system installations but they seem to be installing quite a few kits on a daily basis... chances are that this topic was discussed before so running a search might get you more info
  3. you can't "chrome plate" plastic.. what you can do is paint it with "chrome look paint"... cant remember the name but once i saw a chrome "look" spray kits online... it's not cheap and i think "pimp my ride" fellas once painted a car using this paint...a civic if i'm not wrong
  4. yep...you'll burn bit more gas but i take better stopping power over a lil bit of fuel savings anyday
  5. yep...and most of us do
  6. i think IOC has got "branded" fuel in india. i've seen commercials marketing one of their products called "speed" or something these bloody marketers find novel ways to hit at our pockets If this shed was an IOC one...maybe they are selling these branded gas here too
  7. sounds like you've got yourself an XR in not so good shape. pulling wheelies on an XR is no biggie I don't do it that much now cos i've done complete 180 on my MTX and after so many wheelies i even had to replace the main drive shaft... the stock motor if put together to be as bullet proof as it can be. The Xr's have been winning the Baja1000 back to back cos these things don't breakdown at all. if you're having an oil leak most probably somebody has done some top-end work on the motor. the cylinder head is made of aluminium alloy...if you remove the cover when the motor is warm it might get warped and wont seal properly... and also if there has been a top end job done locally they might've re-used the old gasket kit since new ones are not available in SL... maybe the gaskets haven't sealed properly... XR's don't heat up and die like that...especially with the dry sump motor design the frame helps to cool down oil... i've ridden none stop to N'eliya on my first ride without a hitch... maybe your mechanic is right and it's leaking compression... don't know how to explain but leaking motors always get very hot pretty fast. start the bike up cold and spray some soapy water around the head gasket to see if air is getting blown out.... and also check and replace the oil filter if the previous owner has been an utter ass at taking care of a bike. Washing the air filter with petrol takes stupidity to a new level in my opinion... I think it's better you replace both filters, add new oil, new spark plug properly gapped before getting into anything serious cos those few things alone can keep your XR from doing what it does best good luck
  8. Ripper replied to jaga's topic in TOYOTA
    if i may ask, what the oil your mechanic used for those short interval oil changes?
  9. If your airfilter visually looks bad...chances are that an air hosing job won't clean it properly. this is me assuming you're on the stock paper filter. best bet is to replace the air filter if you think it's not in good shape. It's a little pricey but worth it... I think last time i bought one was for 3k or 4k...genuine honda stuff. Is the bike smoking? XR's can't smoke at all... If you check your plug...it's gotta be in a nice brown tan color... if it's white grayish...you're fuel mixture is too lean and the motor is running hot.. performance might be dropped a bit... if the plug is oily with black soot deposits etc... you're in a bit of trouble with possibly a compression issue...worn piston, non sealing valve guides etc etc The XR's we get to SL are from Japan...i know! DUH!!! But most web results you get for XR's are for the US model. JDM spec XR and US XR's are very different. US XR is more powerful if i'm not wrong cos even the diameters of their exhausts pipe is larger than that of the JDM model. So possibly the 48T might've been for the US model and not the JDM model... Still it doesn't explain your power problem when you say the low end and the top end is bad... what exactly is the scene? do feel the motor is stuttering and failing to rev up nicely? is the firing abrupt? Or do feel the motor is revving perfectly and smoothly but the bike fails to achieve proper acceleration?
  10. true true never new illegal possession of stuff applied to horsepower and other car mods... "Owners of imported sport compact cars had gathered" maybe they only want pumped up american muscle cars on their roads and not "imports"
  11. Ripper replied to Pb2k's topic in OTHERS
    hey dunno about other corolla owners but i aint getting antzy we have our reasons for driving what we drive love to be behind a Mclaren F1 if i could ever afford it about the road trip... i posted on the biker thread can we wait until this bad weather phase gets over...
  12. Ripper replied to jaga's topic in TOYOTA
    repeat post...sorry!
  13. Ripper replied to jaga's topic in TOYOTA
    check the 95 octane thread... i think this was discussed there pretty extensively
  14. you have pics of this or can you describe what/which part that has got scuffed
  15. 42T is stock if i'm not wrong so i doubt that's the case for lack of performance...50,52+ are only larger sprockets... I've also had 510 at the back and it doesn't affect speed that much... then again XR's are never about top end speed and if that's what you were looking for the XR is a wrong bike choice "the stock muffler is open,no quiet insert in it,so there should be a bit torque than the stock isn't it?" this is complete bull..whoever told you this go and bitch slap that bugger. 4 stroke motors need certain amount of back pressure and once you de-restrict your pipe too much you're cutting down on the low end torque for a lil bit of top end performance... i would check the air filter, sparkplugs...it should be CR9EH-9, check the spark gap, check the carb is the previous owner had chosen better economy over good performance. some fellows change the jets to smaller sizes for better fuel figures if all these fails check your clutch and try an oil change. fully syn oils meant for cars messes up bike clutch plates good luck
  16. well i thought it was sorta unfair to charge a person for having more power etc on their rides and accuse them for street racing when they haven't been caught while doing the act Just by owning a fully pumped up muscled car doesn't necessarily mean that person is a street racer
  17. just to make you feel bad I'm going out for the holidays with 2 buddies on a ride... we're leaving early morning 11th Friday...3am to be exact...riding straight to haputale...and spend the day riding around the area.... planning on heading to devil's staircase and spending the night at world's end lodge... finally we'll head to sinharaja, do some riding there and get back to colombo on the 15th should be fun especially if i can find a raincoat that does the job right for our day trip...sadly i don't know that many biker dudes anymore out of the few i know the hardcore fellas are only interested in multi-day trips the others see riding as just commuting so we'll have to find another one or two on AL Anybody out there interested to join an XR and a CBR for a day trip?
  18. Ripper replied to Pb2k's topic in OTHERS
    121 mafia?
  19. Ripper replied to Pb2k's topic in OTHERS
    i've also seen a white integra type R in very good shape blasting through colombo roads... the guy seems to be good with his machine nice to see an original type R once in while when there are hundreds of fake type R's with only decals
  20. funny enough this was the same story one of my friends was saying... he had replaced his stock winscreen with an aftermarket one after an accident and the glass was getting fuzzy in rain... he had changed back to an OEM one and saying now it's far better... sorta difficult to understand how this happen though
  21. he he...was pulling your fancy magnetic cable mate
  22. damn if this is the case i don't see our emission levels getting reduced cos by far the largest offenders group is diesel vehicles...especially those badly maintained commercial vehicles
  23. me ado Don umba apple walata gahala me paththe ehema enda epa harida :lol: actually you're the first guy i heard a bad review about the new mac book. I've been on macs since the days of the old 7220's and man i the only reason i like pc's is that you get lotsa games and a huge variety of softwares over the macs And performance wise...a similar specked mac will spank a pc anyday and the OS is much more stable over windows... Microsoft would've designed their software to work best with windows so those run on macs might not feel a huge performance boost. I work with lotsa editing softwares and those give you better performance on apple's ok ok... admittedly i'm a huge apple fan sorry to go OT
  24. he he ... no offense mate by when i saw your reply...rushed back to view this thread again thinking whether TOYOTA has started making notebooks
  25. actually there are at least two places who does hot dip galvanizing. One is a company called Lanka Transformers the other evades my mind. Good thing is that both the companies claim that they serve to both large orders and the smallest ones I remember this from rainbowpages or something like that... refer that under galvanizing... you can't miss it cos if i remember right it was quite a big ad
